BSP: update OP-TEE to 4.10.0, trusted-firmware-a LTS to 2.14.2 and
edk2-firmware to 202605 (meta-arm)
Tegra: update L4T from R36.5.0 to R39.2.0 (JetPack 7.2) with CUDA 13.2, cuDNN
9.20 and TensorRT 10.16, and switch Orin DEFAULTTUNE to aarch64
Tegra community: update PyTorch to 2.11.0 and torchvision to 0.26.0, and split
python3-cuda into python3-cuda-bindings, python3-cuda-pathfinder and
python3-cuda-python
i.MX: bump linux-fslc-imx BSP to LF6.18.2_1.0.0, imx-gpu-viv to 6.4.11.p4.4,
firmware-imx to 8.31 and Weston to v14 (meta-freescale)
Qualcomm: upgrade linux-qcom-6.18 to v6.18.30, u-boot to 2026.07, Adreno GPU
to 1.855.5, QAIRT SDK to 2.47.0, the iris video driver to v1.0.20 and rmtfs to
release 1.3, and switch Ride platforms to Gunyah virtualization (meta-qcom)
RISC-V: upgrade linux-mainline kernel to 7.0 (meta-riscv)
TI: upgrade Rogue GPU driver to 26.1 and BeagleBoard kernel to 6.12.57
Intel: restructure intel-oneapi-toolkit into a unified 2026.0.0.198 recipe
with mkl/ipp split into sub-packages
Raspberry Pi: upgrade linux-raspberrypi/6.12 to 6.12.87
Security: upgrade suricata to 8.0.4, clamav to 1.4.4 and crowdsec to 1.7.7
GitHub action that extracts release notes from an existing changelog.
Changes in this version:
[2026.09] - 2026-09-30
Changed
clang/llvm: upgrade to the 23.1.2 release and spirv-llvm-translator to 23.1.2,
replace the OE-specific clang test guard with an upstream backport and ignore
how TARGET_ARCH is computed in clang-cross (oe-core)
Upgrade systemd to 262, rust to 1.99.0, gdb to 18.1, u-boot to 2026.10,
openssl to 4.0.3, openssh to 10.6p1, gtk4 to 4.24.0, libsoup to 3.8.0,
glib-networking to 2.90.0, coreutils to 9.12, tcl to 9.1.0, git to 2.56.0,
qemu to 11.1.2, expat to 2.9.0, cmake to 4.4.4, harfbuzz to 14.6.0, systemtap
to 5.6, gnupg to 2.5.24, libpcre2 to 10.49, cups to 2.4.20, parted to 3.8,
bindgen-cli to 0.73.2, the Vulkan/SPIR-V stack to 1.4.363.0 and tzdata to
2026e, and move musl to the latest tip of trunk (oe-core)
linux-yocto: update 7.2 to v7.2.8 and 6.18 to v6.18.54, and bump
linux-yocto-dev to v7.3 (oe-core)
classes/pypi: normalise PYPI_PACKAGE and teach recipetool to set
PYPI_PACKAGE_SDIST when needed, with the recipes updated to match (oe-core,
meta-oe)
Replace dwarfsrcfiles with eu-srcfiles in the package class, fix elfutils’
handling of DWARF5 compilation units and deploy the image-buildinfo file
(oe-core)
devtool: ide-sdk can combine the shared and modified modes, export NFS in
shared mode, run shared recipe IDE hooks and let IDE plugins add packages to
rootfs-dbg; the rust SDK now installs target-specific environment scripts so
cargo builds for the target (oe-core)
Strip the build machine triplet from ruby’s rbconfig.rb and curl-config, take
the opkg default architecture from the target CPU, stage the X11 locale data
in the native and target sysroots and make sstate-cache-management find
work-shared stamps and skip unreadable directories (oe-core)
Bump bitbake to 2.20.0, rename the partial wget download on a checksum
mismatch and cache missing files in the mtime cache (bitbake)
Update TF-A LTS to 2.14.9 and fix the cot-dt2c parser, and backport the
Corstone-1000 security fixes to TF-M and update its TF-A to 2.15.0 (meta-arm)
Upgrade pipewire to 1.6.9, wireplumber to 0.5.18, wolfssl to 5.9.4, grpc to
1.84.0, wireshark to 4.6.9, nftables to 1.1.7, xfsprogs to 7.2.0, cryptsetup
to 2.8.8, fuse3 to 3.18.3, gimp to 3.2.6, imagemagick to 7.1.2-32, freerdp3 to
3.32.1, fastfetch to 2.69.0, nushell to 0.116.0, pahole to 1.32, unicode-ucd
to 18.0.0 and python3-filelock to 4.0.4, and fix the musl builds of a long
list of recipes including android-tools, sockperf, xfstests, tcpreplay and
xdp-tools (meta-oe, meta-python)
Re-enable gobject-introspection for libmodulemd and webkitgtk on clang x86-64
(meta-clang)
Update linux-qcom-next to qcom-next-7.3-rc2-20260928 and linux-qcom-6.18 to
v6.18.44, upgrade adreno to 1.887.3, add flashing support for open-firmware
boot on the IQ-9075 EVK and RB3Gen2 and fix FastRPC on the IQ-8275-EVK and
Monza (meta-qcom)
Generalise the TH1520 support (BeagleV-Ahead, LicheePi 4A) with AON firmware,
UBOOT_EXTLINUX and BOOTSTD_FULL, move the milkv-duo boards to upstream U-Boot
booting with extlinux and bump linux-mainline to v7.2.8 (meta-riscv)
Split tensorrt into full, dispatch and lean recipes, bump the linux-yocto
SRCREV_tegrameta for 6.18.54 and fix the tegra flashing helpers (meta-tegra)
Switch the rkbin firmware to SPDX LicenseRef licenses (meta-rockchip), set the
EdgeAI DSP firmware as default for am62dxx (meta-ti), fix the linux-intel
menuconfig link (meta-intel) and continue the check-layer and oelint cleanup
(meta-freescale, meta-freescale-3rdparty)
Mark the blacksail release series as compatible (meta-intel, meta-security,
meta-swupdate)
clang/llvm: upgrade to the 23.1.0 release, build openmp through the LLVM
runtimes entry point, disable clangd’s decision-forest completion model on
powerpc and ignore the tests that fail with the new version, plus the matching
build fixes for ovmf, pango, vulkan-samples, gettext and rust, which no longer
passes the removed x86 amx-tf32 feature to LLVM (oe-core)
rpm: upgrade 4.20.1 → 6.0.2, add an RPM format reader to libarchive and
disable its filter auto-bidding, drop the external dependency generator,
suppress the fileattr dependency generators, define _lib and _libdir for
rpmbuild, enable the DNF filelists to resolve file dependencies, handle the
RPM 6 non-zero exit on %post failure and bump abi_version (oe-core)
linux-yocto: introduce the 7.2 reference kernel recipes, update 7.2 to v7.2.2
and 6.18 to v6.18.48, remap the rust debug info paths and fix the BSP
configuration warnings (oe-core)
kernel: centralise the module installation path in
KERNEL_MODULE_INSTALL_PREFIX and re-sign the kernel modules after the package
stripping process, via the new get_ext_mod helper in lib/oe/kernel_module.py
(oe-core)
Rename bitbake’s lib/fetch2 to lib/fetch and invert the compat shim so
bb.fetch2 is now an alias of bb.fetch, switch the bitbake and oe-core code
over to it, and require bitbake 2.19.1 in sanity.conf (bitbake, oe-core)
devtool: ide-sdk gains runqemu slirp support, automatic image debug settings
written to a bbappend, VSCode IntelliSense for the rootfs-dbg sources and
automatically disabled ssh host key checking for loopback targets, and both
ide-sdk and deploy-target gain --package/–file-glob deploy filters (oe-core)
hashserv: use the new queued streaming API for the upstream unihash and exist
queries, fix the upstream get-unihash miss truncating the stream, and cancel
all clients on server stop via the new asyncrpc task group (bitbake)
runqueue: wait for the covered tasks before setscene, report the memory
pressure limit correctly, fix the check in process_possible_migrations and
drop a batch of unused attributes and dynamically created state (bitbake)
xorg: depend on util-macros-native explicitly in libxcb, xcb-util,
xorg-lib-common and xorg-driver-common, and drop the now redundant
dependencies from xorg-lib, rgb and font-util (oe-core)
glibc: pull in the stable 2.44 branch updates, and upgrade openssl to 4.0.2,
go to 1.27.1, mesa to 26.2.2, iproute2 to 7.2.0, nasm to 3.02, sysstat to
12.8.0, pango to 1.58.2, rpm to 6.0.2, appstream to 1.2.0, gnupg to 2.5.22,
libpcre2 to 10.48, expat to 2.8.4, libgcrypt to 1.12.3, libksba to 1.8.1,
libical to 4.0.5, librepo to 1.21.0, orc to 0.4.43, re2c to 4.6, debianutils
to 5.24, python3-pygobject to 3.58.0, python3-build to 1.6.0, python3-pdm to
2.29.0, python3-git to 3.1.61 and spirv-llvm-translator to 23.1.1 (oe-core)
Security fix for libssh2 (CVE-2026-58051), backport the RISC-V TLB page
flushing patches to qemu, avoid the CC-BY-SA-4.0 license for the lttng-tools
code packages and fix the run-postinsts removal on multilib images (oe-core)
Upgrade xterm to 411, uftrace to 0.20, libvpx to 1.17.0, catch2 to 3.16.0,
pstack to 2.18.4, uutils-coreutils to 0.11.0, glaze to 8.3.0, qpdf to 12.4.1,
imlib2 to 1.12.7, feh to 3.12.4, libtorrent to 0.16.21, libcloudproviders to
0.4.1, nanopb to 0.4.92 and xclock to 1.2.1 (meta-oe)
Upgrade python3-zeroconf to 0.151.3, python3-ipython to 9.17.0, python3-pylint
to 4.0.8, python3-coverage to 7.16.0, python3-regex to 2026.8.31,
python3-wrapt to 2.4.0, python3-orjson to 3.12.0, python3-msgpack to 1.2.2,
python3-mmh3 to 5.3.0, python3-tox to 4.61.2, python3-typer to 0.27.2,
python3-google-auth to 2.57.0, python3-engineio to 4.14.0, python3-ninja to
1.13.2, python3-kiwisolver to 1.5.1, python3-virtualenv to 21.7.8,
python3-charset-normalizer to 3.5.1 and python3-cmake to 4.4.3 (meta-python)
capnproto: build position independent code, disable GOST support in ldns,
install the bootimg utilities from android-tools, convert the python3-qrcode
optional dependencies into PACKAGECONFIG and fix the glaze install paths
Consolidate the RISC-V mainline kernel metadata into a single linux-mainline
recipe defaulting to 7.2 (updated to v7.2.2) and switch milkv-duo, eswin-ebc77
and the k1 machines over to it, switch orangepi-rv2 to mainline Linux, U-Boot
and OpenSBI, and deprecate orangepi-rv2 and eswin-ebc77 for Yocto 6.2
(meta-riscv)
u-boot-spl-spacemit: set EXTRA_OEMAKE for openssl 4.x, refresh the eswin-ebc77
patches and fix its ethernet, add an INSANE_SKIP to opensbi-dbg for
dc-roma-fml13v01 and update the linux-k3 SRCREV (meta-riscv)
rb1: switch to the new edk2-based downstream boot firmware release, upgrade
firmware-qcom-boot-glymur to v00084 and firmware-qcom-boot-iq-x7181 to v00019,
and add the SoC staging dtbo for iq-x5121-evk (meta-qcom)
gst-plugins-imsdk: upgrade 1.0.2 → 2.0.0, update kgsl-dlkm to v1.0.13,
backport the A722 GPU support patch, prioritise blacklisting iris_vpu so
qcom-iris loads on kaanapali and sm8750, and allow net_admin for the Qualcomm
module loaders in refpolicy (meta-qcom)
optee: use Type=notify for tee-supplicant.service, and improve the
tegra-helper-scripts for non-bmaptool flashing (meta-tegra)
linux-ti-staging-rt_6.18: add the ARM32 RT branch (meta-ti)
An oelint-driven cleanup across the layer, covering the mandatory and
out-of-context variables, the license remote files, the ordered DEPENDS and
the no-copy tasks (meta-freescale)
Update the submodule refs on the 6.11 branch (meta-qt6)
clang/llvm: upgrade to the 23.1.1 release, fix the builds of libcamera, pegtl,
pcapplusplus, dlt-daemon, thermald, bcc, castxml, bit7z and libfaketime with
clang/LLVM 23, work around a clang 23 hang in dovecot, and roll libclc back to
22.1.8 for mesa-pvr (oe-core, meta-oe, meta-ti)
OpenSSL 4: fix the builds of mariadb (AES CBC/CTR/GCM), synergy, imx-cst,
extract-cert, wvstreams, unbound, ntp, softhsm, ipmiutil, mercurial, trousers,
tpm2-openssl and ncrack, enable the OpenSSL engine stub API for
trusted-firmware-a and the Arm u-boot, and backport the OpenSSL 4 fixes to the
linux-ti-staging, linux-bb.org, linux-variscite, linux-orangepi, u-boot-ti, u-boot-bb.org, u-boot-variscite, u-boot-k3, u-boot-orangepi and
u-boot-spl-spacemit recipes (meta-oe, meta-security, meta-arm, meta-ti,
meta-variscite-bsp, meta-riscv)
linux-yocto: update 7.2 to v7.2.6 and 7.2-rt to v7.2-rt5, 6.18 to v6.18.52 and
6.18-rt to v6.18.37-rt6, fix menuconfig outside the Yocto environment and
avoid a spurious drm vblank-timeout warning (oe-core)
devtool: ide-sdk gains clangd support for VSCode IntelliSense (also for
non-clang toolchain recipes) with clang-format, LLDB attach mode, NFS rootfs
and a real hardware NFS export helper, runs do_install through BitBake and
accepts multiple --ide plugins; deploy-target can deploy straight into a local
rootfs directory, and devtool upgrade writes the changelog metadata as a JSON
sidecar (oe-core)
initramfs-framework: support LABEL with a root-only udev trigger, allow opting
out of the efivarfs mount and avoid external commands in the module loop,
cmdline parsing and rootfs resolution, with findfs enabled in busybox for
LABEL support (oe-core)
rust: upgrade to 1.98.1, land a series of reproducibility fixes (sorted
hygiene data, deterministic DocLinkResMap, build host triple kept out of cargo
metadata, cc object names hashed relative to their source roots), add
secure-plt to the generated powerpc targets and map the cargo vendoring
directory for the C compiler (oe-core)
Move python3-six from oe-core to meta-oe and drop the six dependency from
python3-dateutil, python3-ecdsa, python3-astroid, python3-html5lib,
python3-pywbem, python3-behave and some twenty other recipes, remove the
redundant PYPI_PACKAGE assignments across the layers, and parse pyproject.toml
and Cargo.toml with tomllib in the setuptools and cargo-update-recipe-crates
classes (oe-core, meta-oe, meta-python)
bitbake: restrict network access with landlock for tasks without network, show
the elapsed time on the knotty task progress bar, vendor tomli, support
submodules in BBIMPORTS and fix relative gitsm paths (bitbake)
Upgrade glib-2.0 to 2.90.0, ffmpeg to 9.0.1, gstreamer1.0 to 1.28.7, systemd
to 261.3, curl to 8.22.0, automake to 1.19, lame to 4.0, libpcap to 1.11.0,
util-linux to 2.42.3, xz to 5.8.4, libxml2 to 2.15.4, gtk4 to 4.22.5, librsvg
to 2.63.0, dpkg to 1.23.11, xdg-utils to 1.2.1, rpcbind to 1.3.1, libportal to
0.11.0, libgcrypt to 1.12.4, libucontext to 1.5.2, linux-firmware to 20260910,
tzdata to 2026d, bind to 9.20.29, ppp to 2.5.4, orc to 0.4.44, librepo to
1.21.1, python3-numpy to 2.5.3 and python3-lxml to 6.1.3 (oe-core)
Security fix for wget (CVE-2026-16599), add ptest support for wget, zstd and
python3-six, fix the m4, gettext, coreutils, util-linux, tar, gawk and python3
ptests, and fix the openssl and libmodule-build-perl build arch contamination
(oe-core)
GNOME: move gnome-shell, mutter, gdm, gnome-session, gnome-settings-daemon,
gnome-keyring, gnome-desktop, gnome-software, gnome-console and most of the
core apps to 51.0, along with gjs 1.90.0, mozjs 140, evolution-data-server
3.62.0, gvfs 1.62.0, libpeas 2.2.1, gexiv2 0.16.2 and localsearch/tinysparql
3.12.0 (meta-oe)
Upgrade postgresql to 18.6, nodejs to 24.21.0, zabbix to 7.4.14, fluentbit to
5.1.2, tailscale to 1.102.3, zfs to 2.4.4, bpftrace to 0.26.1,
vboxguestdrivers to 7.2.18, msgpack-c to 7.0.2, msgpack-cpp to 9.0.0,
microsoft-gsl to 5.0.0, accountsservice to 26.27.3, uutils-coreutils to
0.12.0, wireplumber to 0.5.17, webkitgtk3 to 2.52.6, spice-gtk to 0.43, rygel
to 46.0, ostree to 2026.4, valkey to 9.1.2, 7zip to 26.03 and thermald to
2.5.13 (meta-oe)
Upgrade python3-ruff to 0.16.8, python3-pybind11 to 3.1.0, python3-nanobind to
3.1.0, python3-pikepdf to 10.13.0.post1, python3-glances to 4.5.6,
python3-configshell-fb to 2.0.3 and python3-pywbemtools to 1.4.1 (meta-python)
polkit: patch CVE-2026-4897 and CVE-2026-85498 and split the systemd
service/dbus config into its own package, and switch lcms to meson (meta-oe)
Upgrade clamav to 1.5.4, suricata to 8.0.6, crowdsec to 1.8.1, sssd to 2.13.1,
ossec-hids to 4.3.0, krill to 0.16.0, tpm2-tools to 5.8, tpm2-pkcs11 to 1.10.1
and openscap to 1.4.4 (meta-security)
Revert the RB1 switch to the edk2 boot firmware, switch rb3gen2-core-kit and
qcm6490-idp to the KVM hypervisor, update linux-qcom-6.18 to v6.18.44 and
upgrade qairt-sdk to 2.50.0, minkipc to v1.2.10 and gst-plugins-imsdk to 2.0.2
(meta-qcom)
Add CVE_PRODUCT and CVE_VERSION metadata across the Jetson Linux, CUDA,
TensorRT, OP-TEE and EDK2 recipes, update TensorRT to 10.16 and adapt
tegra-sources to the bb.fetch rename (meta-tegra)
Switch orangepi-r2s to mainline Linux, U-Boot and OpenSBI, consolidate the k1
and k3 SPL into u-boot-spl-spacemit and allow the zicsr and zifencei
extensions in TUNE_RISCV_PKGARCH (meta-riscv, oe-core)
Upgrade the corstone1000 u-boot to v2026.07 and OP-TEE to 4.10.0, and add
EARLY_TA_PATHS for adding early TAs from bbappends (meta-arm)
Add the missing HiFiBerry overlays and create the groups used by the udev
rules (meta-raspberrypi)
Sync g2d with meta-imx lf-6.18.20_2.0.0, upgrade firmware-imx to 8.32 and
continue the oelint cleanup (meta-freescale)
Update the submodule refs on the 6.11 branch again (meta-qt6)
Switch the layer compatibility to the blacksail release series and drop
wrynose from CORENAMES ahead of its release (meta-yoe, oe-core, meta-oe,
meta-arm)
GNOME: move adwaita-icon-theme, epiphany and gsettings-desktop-schemas to 51.0
and at-spi2-core to 2.62.0.1, and improve the gnome_verdir() logic in the
gnomebase class (oe-core)
Upgrade nfs-utils to 3.1.1, libinput to 1.32.0, mesa to 26.2.3, ffmpeg to
9.0.2, harfbuzz to 14.5.0, cairo to 1.18.6, librsvg to 2.63.2, libsecret to
0.21.8.2, gpgme to 2.2.0, gnupg to 2.5.23, util-linux to 2.42.4, rsync to
3.5.1, ruby to 4.0.7, meson to 1.12.1, libdnf to 0.76.0, libsolv to 0.7.40,
libslirp to 4.9.5, barebox to 2026.09.0, linux-firmware to 20260916, gzip to
1.15, expat to 2.8.5, xxhash to 0.8.4, fastfloat to 8.3.0, stress-ng to
0.22.01, diffoscope to 330, repo to 2.68, python3-poetry-core to 2.5.0,
python3-urllib3 to 2.8.0 and python3-hatchling to 1.32.4 (oe-core)
Fix the kernel reproducibility issues in linux-yocto 7.2 and 6.18, fix the gcc
check for a working assembler --gdwarf-4 option, make the libtirpc TIRPC_1.3.7
symbol version conditional, add the missing commas in the udev-extraconf
rules, default qemuriscv to fw_dynamic.elf as the QEMU BIOS and skip the clang
selftest suites on qemuppc (oe-core)
Update linux-qcom-6.18 to v6.18.44, update the iq-x7181 boot firmware to
v00028 and skip blkid probing for the raw partitions (meta-qcom)
Add SD card boot support for beaglev-ahead and disable the RTOS core in the
milkv-duo FSBL (meta-riscv)
Add the oelint CI workflow and infrastructure (meta-freescale,
Mark the blacksail release series as compatible in the layer configs and add
the blacksail configs to the bitbake default registry and toaster fixtures
(bitbake, meta-raspberrypi, meta-rockchip, meta-ti, meta-odroid,
meta-variscite-bsp, meta-variscite-bsp-common)
Fix the gcc configargs.h build arch contamination and add context to the lame
patches (oe-core)
Upgrade glibmm-2.68 to 2.90.0, glibmm to 2.66.10, php to 8.5.11, x265 to 4.2,
ibus to 1.5.34 and canopenterm to 2.04, add repo.or.cz as a premirror for
ulogd2, libnftnl, libnetfilter-queue and libnetfilter-log, and fix sushi on
Wayland-only GTK4 (meta-oe)
beaglev-ahead: switch to mainline U-Boot, OpenSBI and linux-mainline, enlarge
the U-Boot area to 4 MiB and boot from the SD card if one is inserted
(meta-riscv)
Bump the corstone1000 TF-M to 2.3.0 and avoid its provisioning reset
(meta-arm)
Switch qcom-sm8750 to the armv8-6a-crypto tune, switch the IQ-9075 EVK + IFP
mezzanine to KVM by default and add the at24 and qca808x modules to
packagegroup-machine-essential (meta-qcom)
Bump max_leb_cnt for am335x-evm and am437-evm, add multimedia-layer support
with a platform specific pipewire configuration, and turn the u-boot OpenSSL 4
fixes into a build option (meta-ti)
Fix the stale PREFERRED_VERSION for libcamera-imx after the 0.7.1 bump
(meta-freescale), and continue the oelint cleanup (meta-freescale-3rdparty)
Added
Add ptest support for libpcap, psmisc and npth, the libtoml11 recipe, a yaml
PACKAGECONFIG for libubootenv, ldd in buildtools-extended-tarball and the
sqlite3 unlock notify API (oe-core)
Add the ptyxis, v4l2rtspserver, python3-ping3, python3-varlink,
python3-asyncvarlink and python3-construct recipes (meta-oe, meta-python)
Add the licheepi-4a MACHINE (meta-riscv)
Add HDMI, DLC panel and LVDS overlay support for shikra-evk (meta-qcom)
Add the linux-yocto 7.2 reference kernel recipes and a kernel-src SDK feature
to populate_sdk_base, and ship tools/include from kernel-devsrc for the
archscripts host tools (oe-core)
Add the python3-rtslib-fb recipe (meta-oe)
Add the python3-nvidia-ml-py 13.610.43 recipe (meta-tegra-community)
Add kas configurations for muse-pi-pro, milkv-megrez, mangopi-mq-pro,
freedom-u540 and dc-roma-fml13v01, plus a validate-bsp-coverage script and the
workflow that runs it (meta-riscv)
Add the DTSO and fit compatible for the rb3gen2 industrial mezzanine M.2
QCC2072 variant (meta-qcom)
Add smolkit, a low-footprint drop-in polkit replacement, plus the boardid,
loupe, glycin, gexiv2-0.14, gnome-online-accounts-gtk, tomcli, floret,
boot-time-analysis-tools, libcrypt-urandom-perl, libcrypt-openssl-bignum-perl,
python3-cucumber-expressions and python3-targetcli-fb recipes (meta-oe,
meta-python)
Add python3-tomlkit and libfaketime, both moved from meta-oe (oe-core)
Add an open-firmware iq-9075-evk variant booting through U-Boot SPL, CamX for
Purwa and support for building external device trees into the boot images
(meta-qcom)
Add the libpwquality recipe, moved from meta-oe (oe-core)
Add support for the Talos Lyra EVK board (meta-qcom)
Add the beaglev-fire MACHINE along with the hss-payload-generator-native and
gptfdisk 1.0.10 recipes (meta-riscv)
Add the firmware-ddr-training-th1520 recipe (meta-riscv)
Add TF-M 2.3 signing support (meta-arm)
Add the nxpaw693 SDIO module to firmware-nxp-wifi (meta-freescale)
Add a Boost PACKAGECONFIG to crow (meta-oe)
Removed
Removed the dwarfsrcfiles, python3-pytz and python3-dtschema-wrapper recipes
(oe-core)
Removed the milkv-megrez, nezha, mangopi-mq-pro, star64, visionfive, beaglev,
ae350-ax45mp and eswin-ebc77 BSPs (meta-riscv)
Removed the Vybrid recipes (meta-freescale-3rdparty)
Removed the makedepend recipe and the obsolete mesa build dependencies
(oe-core)
Removed the hackbench and cyclictest benchmark recipes again, and the
redundant python3-wheel-native dependency from python3-mako (meta-oe, oe-core)
Removed the linux-milkv-duo, linux-eswin-ebc77-mainline and linux-mainline-k1
kernel recipes, the linux-milkv-duo-dev BSP recipe and milkv-duo-bootfiles,
all superseded by linux-mainline (meta-riscv)
Removed python3-six (moved to meta-oe) and dropped ext3 from the qemu
MACHINE_FEATURES (oe-core)
Removed the python3-attrdict3, python3-pathlib2, python3-networkmanager,
mycroft and loudmouth recipes (meta-oe, meta-python)
Removed the openssl-tpm-engine and tpm2-tss-engine recipes (meta-security)
Removed u-boot 2025.10 (meta-arm) and the u-boot-spl-k1, u-boot-spl-k3 and
orangepi vendor recipes (meta-riscv)
Removed libpwquality (moved to oe-core) from meta-oe and the unused
orangepi-r2s-usb.wks (meta-oe, meta-riscv)
