kraj released this on Feb 4 · 51 commits to master since this release
- Make meta-python dependency optional for meta-raspberrypi
- Upgrade raspberrypi-firmware and linux-raspberrypi to 5.4.79
- Fix zsh support in envsetup
- Fix install conflicts between canutils and can-utils recipes
- Refactor cdrkit and extend to build native version
- Update linux-at91 to linux4sam-2020.10-rc5
- Bump egt to 1.1-rc
- Bump linux-fslc to v5.10.6 and linux-fslc-imx to v5.4.88
- Update u-boot-toradex to 2020.07
- Fix RB5 board support
- linux-raspberrypi use linux-yocto tooling
- Fix X11 and wayland image builds with userland graphics
- Use relative symlinks for anything pulled from PREMIRRORS in fetchers
- Sam-ba is upgraded to 3.3.1
- u-boot-at91 updated to linux4sam-2020.10
- Added firmware for BCM43456
- linux-ti-staging updated to 5.4.78
- Update linux yocto to v5.4.87 and v5.10.4
- Assorted package version updates and reprodubility improvements
- Make busyboxinit work as an alternative to sysvinit
- Use util-linux provided fsck/fdisk in Yoe updater/installer
- Update go to 1.15.6 and disable internal linker for native apps
- Switch pulseaudion to use meson build system
- Update rust to 1.47 and enable separate build directory when using cargo
- Update clang to 11.1.0-rc2
- Update to qemu 5.2.0
- Add linux-intel-rt recipe for 5.10 and switch it as default kernel
- Switch odroid machine defaults to use 5.10 kernel
- Drop odroid-c2 from u-boot-hardkernel
- Upgrade XFCE to 4.16.0
- Assorted recipe upgrades
- Drop several old algorithms in OpenSSL
- Add finer packaging of sudo/iproute2/procps/net-tools
- Upgrade binutils to 2.35.1
- Upgrade mesa to 20.3.2
- Fix meson to work in nativesdk environment
- Add LFS support in bitbake fetcher
- Update Freescale EULA to v17
- Add new board i.MX DXL EVK
- Add i.MX 6ULZ EVK board
- Update gstreamer to 1.18.3
- Update bash to 5.1
- Fix ccache usecases, disable for native recipes
- Add support for VHD/VHDX rootfs in runqemu
- Upgrade linux-raspberrypi to v5.4.83
- Upgrade musl to 1.2.2
- Upgrade timezone data to 2021a
- Upgrade mariadb to 10.5.8
kraj released this 10 hours ago · 4 commits to master since this release
- Upgrade autotools to 2.71
- Disable sanitizer builds in compiler-rt
- linux-fslc updated to v5.10.18, linux-fslc-imx updated to v5.4.100
- Fix qtwayland for mx6 and mx7 machines
- Enable DRI swrast driver for NXP BSPs
- Weston updated to 9.0.0
- Update linux-intel-rt to v5.10.12 and linux-intel/5.10 to v5.10.14
- Do not pin gcc for odroid-c4-hardkernel
- Upgrade binutils to 2.36.1
- Upgrade glibc to 2.33
- Update clang and llvm to 11.1.0
- Update to go 1.16 release
- Update busybox to 1.33
- Update python3 to 3.9.2
- Fix recipes to work with autotools 2.71, binutils 2.36
- Add 5.10 recipe for linux-raspberrypi and make it default
- Add overlays for pi 400 and cm4
- Fix compile issues in LTP, linux-yocto-5.10 for RISCV32
- Upgrade rust to 1.49.0
- Upgrade linux-yocto to v5.10.16 and v5.4.98
- Upgrade glslang to 11.1.0 and fix shaderc
- Detect code changes in submodules while using externalsrc
- Upgrade cmake to 3.19.3
- Various recipe version upgrades
- Use bitbake 1.49.2 and add support for BB_DEFAULT_UMASK
- Fix riscv32 u-boot, tcf-agent, and rust builds
- Use rust 1.49.x
- Update linux-ti-staging and u-boot to latest
- Fix glibc for faccessat2 seccomp filters
- Fix security flags and compiler opt level
- Upgrade u-boot to 2021.01
- Fix pseudo to handle faccessat
- Add recipe for libclc
- Merge llvm-common into clang
- Update linux-altera-lts_5.4 to 5.4.84
- Drop support for GCC 9.2 arm toolchain
- Pseudo fixes for glibc 2.33
- Update go to 1.15.8
- Update musl to latest master
- Fix various recipes for deterministic builds
- Add missing ‘or-later’ GPL license mappings
- Fix glibc multilib headers
- Use uboot 2021 release on odroid machines
- Fix bitbake providers processing
- Fixes for powerpc64 architecture in Core
- Enable gdbserver for riscv architecture
kraj released this 2 hours ago
- Add Tinkerboad support
- Add Azure Storage fetcher implementation
- Add qemuppc64 machine
- Add REQUIRED_VERSION to bitbake
- Add NanoPi-M4 machine in rockchip soc layer
- Update go to 1.16.2 and remove go-dep
- Let linunwind on musl use libucontext
- Move qemuriscv32 machine as core machine
- Fix SRCREV for linux-altera-lts-5.4
- Compile musl on riscv64 when using meta-clang
- Update clang to 12.0.0-RC2
- Add recipe for spirv-llvm-translator
- Add opencv_4.4.0.imx recipe
- Bump linux-boundary to 5.4 2.3.0
- Bump linux-fslc to v5.10.25 and linux-fslc-imx to v5.4.107
- Upgrade linux-yocto to v5.10.25 and v5.4.107
- Update openSSL to 1.1.1k
- Fix libtool race running autoheader before autoconf
- Update linux-ti-mainline to v5.11
- Fix qtwebkit build with riscv64
- QTbase fixes for build with GCC 11
- Fix recipes in meta-openembedded to work with GCC 11
- Fix sdcard_image-rpi to work with latest dosfstools
- Add adafruit python3 modules for raspberrypi
- Fix rust compiler and libstd-rs to work on riscv64/riscv32
- Disable CPU ISA level requirement check in glibc
- Add PSEUDO_IGNORE_PATHS foor SDK and image types
- Fix musl and busybox for RISCV32
- Fix systemd-container recipe
- Update Clang to 12.0.0 RC3
- Prevent fetching git hook during do_configure for ceres-solver
- Fix meta-qt5 recipes to compile with GCC 11 and RISCV fixes
- Fix a regression in glibc w.r.t. _SC_LEVEL1_ICACHE_LINESIZE
- Add QB_GRAPHICS option to runqemu tool
- Add options to turn --enable-poison-system-directories fatal in GCC
- Reduce linker memory usage while building webkitgtk when using BFD linker
- Assorted XFCE package upgrades
- Fix several recipes for ppc64le
- Add imx-boot-container class to provide boot container for iMX
- Drop gatesgarth from compatible releases for layers
- Fix webkitgtk/JSC stack size on musl, add option to compile for size
- Update vulkan packages to 1.2.170.0
- Detect code changes in submodules when using externalsrc
- Fix bitbake documentation
- Update openSSH to 8.5p1
- Update gstreamer to 1.18.4
- Fix CPU tune file for rpi0w
- Fix compiler-rt for armv6/rpi0w
- Update rust to 1.51.1
- Version upgrades for several recipes
kraj released this 10 days ago · 27 commits to master since this release
- Add RISCV based BeagleV as supported board
- Add support for linux-starfive-dev kernel
- Fix xwayland dependency for weston in meta-freescale
- Add progress handler for S3 copy
- Upgrade imx firmware to 8.10.1
- Fix recipes for building with -ffile-prefix-map
- Upgrade to GCC 11.1.0
- Upgrade GDB to 10.2
- Fix patchelf note section alignment issues in uninative
- Upgrade mesa to 21.0.3
- Improve reproducibility for libjpeg-turbo
- Enable -Wdate-time to detect use of DATE TIME macros
- Enable long options for enabled applets in busybox
- Improve ptests for libpam and bash and valgrind
- Switch clang to use Dwarf-5 by default like GCC 11
- use 0x80008000 as the UBOOT_ENTRYPOINT for mx6ul, mx6ull and mx6ulz
- Update linux-fslc-imx to v5.4.122 and linux-fslc-lts to v5.10.40
- Add linux-fslc 5.12.7
- Enable serial and usbhost machine features for NanoPi-M4
- Bump linux-ti-mainline to 5.12
- Fix reproducibility for busybox
- Update linux-yocto trains to v5.4.119 and v5.10.38
- Fix kernel configs for qemuriscv32 to support only 1GB physical mem
- Fix SVN fetcher’s parsing revision of SVN repos with redirects
- Update external-arm-toolchains to latest
- Add src files to nativesdk rust
- Use bb.utils.rename() instead of os.rename() in scripts
- Bump minimum required bitbake version to 1.51
- gdk-pixbuf updated to 2.42.6, glib-2.0 to 2.68.1, strate to 5.12
- Upgrade webkitgtk to 2.32.0
- Fix qtwebengine to build with gcc11 and upgrade to use chromium-87
- arm/trusted-firmware-m is updated to 1.3.0
- Upgrade XFCE components - xfce4-panel, xfce4-clipman-plugin,
xfce4-systemload-plugin
- Fix CVE checks in QEMU, openssh, logrotate, jquery
- Upgrade busybox to 1.33.1
- Fix recipes to build with new definitions of SIGSTKSZ in glibc trunk
- Fix trusted-firmware-a for rockchip using GCC11/Clang12
- Backport DWARF-5 support for gold linker
- Update btrfs-tools to 5.12, ffmpeg to 4.4 and epiphany to 40.1
- Enable RISCV64 port for baremetal sample application helloworld
- Enhance yoe-sdk-image to include tools to build kernel on-device
- Update go to 1.16.4
- Update meson to 0.58.0
- Upgrade python to 3.9.5
- use 4 cores in qemu guests
- Update some of gnome components to facilitate 0.40.x release series
- Update bluez and wifi firmwares for RPI to rpt8 and rpt11 respectively
- Upgrade qemu to 6.0.0
- Handle sstate manifest ‘corruption’ issue
- Remove mklibs feature and support from core
- Fix default gcc search paths for musl configs and relocatable SDK fix
- CVE fixes in several packages
- Add compiler-rt-sanitizers, clang based sanitizers
- Upgrade uninative to 3.2 (gcc11 support)
- Fix
__NR_fstatat syscall name for riscv/musl
- Upgrade U-Boot to 2021.04
- Fix clang static analyzer viewer for missing python module
- Update arm trusted-firmare-a to version 2.5
- Update gcc11 to latest on upstream GCC 11 release branch
- Update glibc to 2.33.1
- Enable memory tagging in glibc on aarch64
- Update systemd to 248.3
- Allow using gold linker with gcc-cross-canadian in SDK
khem
6
2021.09 (jacob)
kraj released this 19 minutes ago
- Implement data partition resize feature in yoe updater
- Add initial support to generate SBOMs
- Set precise BSD linceses in recipes in OE-Core and meta-openembedded
- Let updater machine files be defined in layers outside meta-yoe
- Fix bpftrace build with clang 13
- Avod task graph corruption when trying to avoid deadlocks in runqueue
- Drop obsolete oe_machinstall function utility
- Update simpleIOT to v0.0.34
- Fix fcntl in pseudo with glibc 2.34
- Add selinux packageconfig for tar,findutils,coreutils
- Allow upstream for local hash equivalence server in bitbake
- Make externalsrc work with reproducible_build
- Ensure XZ_THREADS doesn’t change sstate checksums
- Add packageconfig for wheel-group in systemd
- Avoid problems with recipes using SRCPV when fetching sstate
- Enable ftps in wget fetcher
- Add tpm2 packageconfig to systemd
- Prepare bitbake for python 3.10 compatibility
- Enable lima with rock64
- Change one of licenses from expat to MIT in ffmpeg
- Fix qtwayland build with clang
- Fix missing pkgconfig inherit in QT5 recipes
- Use uuid instead of hard-coding root device for rockchip devices
- Remove obsolete intltool-native dependency from recipes
- Add missing pkgconfig inherit in oe-core and meta-openembedded
- Remove useless class from meta class, reduces amount of sstate needed
- Ensure task checksums reflect site files
- Delete dead entries from site files for Orbit2 and libidl
- Delete site file extentions from meta-openembedded layers
- Fix vboxguestdrivers build on kernel 5.14+
- Let user specify target for vk-gl-cts
- Switch linux-yocto defaults to 5.14 kernel
- Use 5.14 as default kernel for odroid
- Allow shutdown/database flush of pseudo server at task exit helps builds
using containers for build machines
- Fix clang SDK builds when using llvm runtime
- Fix openCV dnn with protobuf-3.18
- Assorted python module updates
- Recipe Updates
- simpleiot - 0.0.33, go - 1.16.7, unclutter-xfixes - 1.6
- uhubctl - 2.4.0, nlohmann-json - 3.10.2, monit - 5.29.0
- libwebsockets - 4.2.2, cjson - 1.7.15, wireshark - 3.4.8
- gsl - 2.7, xf86-video-nouveau - 1.0.17, ctags - 5.9.20210905
- avro-c - 1.10.2, ntopng - 5.0, ndpi - 4.0, redis - 6.2.5
- libjcat - 0.1.8, libeigen - 3.4.0, libbytesize - 2.6, dash - 0.5.11.5
- crash - 7.3.0, spdlog - 1.9.2, fmt - 8.0.1, msgpack-c - 4.0.0
- poppler - 21.09.0, poppler-data - 0.4.11, lockfile-progs - 0.1.19
- libqmi - 1.30.2, dfu-util - 0.11, cppzmq - 4.8.0, mosquitto - 2.0.12
- fuse3 - 3.10.5, lttng - 2.13.0, linux-yocto/5.10 - 5.10.63
- linux-yocto/5.13 - 5.13.15, libxmlb - 0.3.2, dnf-plugin-tui - 1.3
- zchunk - 1.1.16, xterm - 368, unbound - 1.13.2, dnsmasq - 2.86
- postgresql - 13.4, libbpf - 0.5.0, ndisc6 - 1.0.5
- clang - 13.0.0-rc3, linux-raspberrypi - 5.10.63, libgcrypt - 1.9.4
- span-lite - 0.10.1, protobuf - 3.18.0, fio - 3.28, apache2 - 2.4.49
- nghttp2 - 1.45.1, samba - 4.14.7, gd - 2.3.3, poco - 1.11.0
- cppzmq - 4.8.1, byacc - 20210808, systemtap - 4.5-latest
- libc-headers - 5.14, valijson - 0.6, sassc - 3.6.2, sanlock - 3.8.4
- libsass - 3.6.5, snort - 2.9.18.1, smcroute - 2.5.3
- unionfs-fuse - 2.2, libqb - 2.0.3
- New recipes
- python3-pytest-subtests, python3-kivy, pahole, smarty
- libjs-jquery-icheck, chipsec
- Removed recipes
khem
8
2021.11 (langhe)
Latest
kraj released this 38 seconds ago
2021.11
02ed066
- Use https protocol in github SRC_URI
- Use branch setting in git uris explicitly
- Update clang to latest on 13.x release branch
- Fix recipes to not install /var/log /var/run during build time
but create them at runtime
- Fix mdns on musl
- Fix Gnome recipes in meta-gnome
- Update musl to tip of trunk which has qsort_r now
- Add a new build QA check to check for empty folders
- Fix recipes e.g. mctp, sdbus to compile against 5.15 kernel headers
- Update gdb to 11.1
- Show warnings for append/prepend/remove operators combined with +=/.=
- Specify protoc explicitly when building protobuf-c, helps cross compile
- Use https protocols for github SRC_URIs in meta-raspberrypi
- Introduce Linux 5.15 based linux-libc-headers
- Fix recipes to work with 5.15 headers e.g. ppp
- Update linux-yocto v5.10.79, v5.15.2, v5.14.18
- Drop using lnr in favor of ln -rs in recipes
- Fix wic image generation by reverting to using os.rename
- Add uninative mirror on kernel.org
- Build target qemu on musl targets as well
- improve SDK’s wrapper to make Wraps work in meson
- Use wayland distro feature for native builds
- Fix task-depends.dot for multiconfig targets
- Adjust recipes using meson to work with meson 0.60+
- Upgrade linux-raspberrypi to 5.10.81
- Fix parselogs regular expressions for 5.10 kernel
- Add Pi Zero 2 Wifi 64bit yocto machine in meta-raspberrypi
- Upgrade php to 8.x
- Upgrade linux-staging-ti to 5.10.65
- Drop compatibility mappings and dbus dependency in core packagegroups
- Support read-only rootfs in QEMU machines
- Refresh PREMIRRORS/MIRRORS settings in metadata, some of them were stale
- Update rust to 1.56.1
- Update patch status, many of them are submitted upstream
- Use https:// instead of git:// for github.com SRC_URIs in meta-qt5
- Fix github SRC_URIs to have explicit branch names
- Use usermode qemu to run minilua during php8 build
- Change the default cipher to AES-256-GCM for openvpn server configurations
- Fix rust runtime library and librsvg on riscv32/musl
- Add sanity check for allarch packagegroups
- Use bullseye branch for linux-firmware-rpidistro package
- Set precise BSD license for meta-openembedded recipes
- Remove introspection as this is not valid meson 0.60+ option
- Fix missing installation of cups sysv init scripts
- Upgrade and fix freerdp 2.3.0 → 2.4.1
- Fix mozjs on centos7 build hosts
- Add Wi-Fi/BT drivers for CM4 and Pi 400 to Raspberrypi4 machine configs
- Upgrade mesa to 21.3.0
- Fix OEQA warnings for append operators combined with +=
- Improve rust support in meson based builds
- Upgrade go to 1.16.10
- Support rootdev identified by partition label in wic
- Do not use CET on i586 and c3 tunes
- Switch TI SOCs to use PVR graphics
- Fix PVR drivers to work with 5.10+ kernel
- Add ar wrapper for determinism for native/cross recipes
- Add needed sysroot dependencies for repo fetcher
- Fix launching weston without keyboard and mouse on BBB and RPI
- Update Go to 1.17 release
- New recipes
- ntpsec, mozjs-78, gtk4, python3-imgtool, fwupd, fwupd-efi
- python3-pytz-deprecation-shim, python3-aiosignal, python3-frozenlist
- python3-charset-normalizer, python3-cchardet, python3-email-validator
- python3-gcovr
khem
10
2022.02 - “Navajo-Churro”
[2022.02] - 2022-02-28
Changed
- Upgrade simpleiot to 0.0.42
- Enable network during compile/configure step of simpleiot
- Build kernel with initramfs for sifive/unmatched
- Use renamed terms for variables for inclusive language changes
- BB_ENV_PASSTHROUGH_ADDITIONS
- LICENSE_FLAGS_ACCEPTED
- SKIP_RECIPE
- CVE_CHECK_IGNORE
- LICENSE_EXCLUSION
- Use yocto URL for testing CONNECTIVITY_CHECK_URIS
- Switch to kirkstone ( yocto 3.5 ) codename across layers
- Only allow network access in do_fetch tasks
- Cleanup use of distutils in oe-core, replace with setuptools
- linux-yocto updated to v5.10.99, v5.15.22
- Update busybox to 1.35 release
- Enable threading in perl
- Update various gnome recipes to 41.1 release
- Upgrade strace to 5.16
- Switch raspberrypi4-64 to cortexa72 tune
- Upgrade ffmpeg to 5.0
- Upgrade meson to 0.61.1 and fix packages to build with this version
- Update PHP to 8.1.3
- Upgrade gstreamer to 1.20.0
- Use arm BSPs to use linux-yocto 5.15
- Update clang to 14.0.0-rc1
- Use LLVM binutils by default e.g. nm, strip, objcopy, objdump etc.
- Set precise BSD license in various recipes
- Upgrade glibc to 2.35
- Upgrade binutils to 2.38 release
- Upgrade gdb to 11.2
- Upgrade go to 1.17.7
- Upgrade musl to tip of master/f8bdc3048216f41eaaf655524fa286cfb1184a70
- Upgrade weston to 10.0.0
- Disable sse4.1 and sse4.2 in openCV on x86
- Upgrade linux-firmware to 20220209
- Bump bitbake version to 1.53.1
- Use 5.15 as default kernel for RPI machines
- Add support for gtkmm4
- Disable optimizations for libvorbis,x264,dcadec,graphviz on mips to avoid clang bug
- Migrate many python recipes to use wheels packaging format
- Upgrade ruby to 3.1.1
- Move distutils bbclasses to meta-python
Added
- Add example to generate username/password in image and local.conf
- Add recipe for python3-gammu, duktape, python3-picamera, seatd
googlebenchmark, python3-pytest-xdist, python3-pytest-xdist
python3-pytest-qt
- Introduce cortexa73-crypto tune
- Add the support for the Neoverse N2 core
- Add tune include for armv8.5a
- Add setuptoools Rust plugin
- Add class for PyO3 cross-compilation
- Add crate fetcher in bitbake
- Add recipe for 5.15 LTS linux-raspberrypi kernel
Removed
- Prelinker support
- Drop the redundant cortexa72-crc tune
- Remove recipes for mailx, libjs-jquery, python3-anyjson, python3-nose
- Remove libsegfault and catchsegv
- Remove bogus CMAKE_LDFLAGS_FLAGS definition from cmake toolchain file
khem
11
Repository: YoeDistro/yoe-distro · Tag: 2022.03 · Commit: baeae56 · Released by: github-actions[bot]
release-notes-from-changelog
GitHub action that extracts release notes from an existing changelog.
Changes in this version:
[2022.03] - 2022-03-30
Changed
- Fix multilib support in clang based toolchain
- Improve llvm-config detection logic in cross builds
- Enable llvm runtime for ppc32
- Disable altivec intructions when using clang on qemuppc
- Fix python module recipes to support PEP-517 packaging
- Update nodejs to 16.14.0 LTS
- Fix gyp to work with python 3.10+
- Upgrade linux-raspberrypi 5.15 to 5.15.30
- Bump riscv linux-mainline to 5.17
- Update linux-yocto to v5.10.107, v5.15.30
- Update SRC_URIs for brcm firmware in meta-riscv
- Show warning for obsolete license usage
- Improve deterministic builds for perl, quilt, and cups
- Upgrade SQlite3 to 3.38.0
- Replace non-SPDX license identifiers in OE-core
- Use SPDX license identifiers in recipetool
- Enable networking in all icecc tasks
- Rework INCOMPATIBLE_LICENSE wildcard and variable handling
- Improve ssh fetcher to support path handling
- Use SPDX license identifiers in all meta-openembedded layers and meta-intel
- Fix recipes in meta-openembedded needing legacy setuptools support
- Reduce default dependencies for native sysroot, drop libarchive and util-linux
- Drop opt-1 and opt-2 pyc files in native python to reduce number of files
- Fix build race in binutils/assembler docs
- Improve eSDK layer path assumptions to support more layouts
- Enable systemtap for RISCV64
- Use SPDX license naming convention in meta-clang, meta-odroid, meta-riscv
- Enable riscv64 builds for bcc,libbpf
- Remove depenendency for virtual/libgl where possible, use virtual/egl
- Fix recipes to build without X11 in distro features
- Improve PYPA_WHEEL detection for wheel packaging and cleanup pip_install_wheel
- Upgrade go to 1.17.8
- Upgrade rust to 1.59.0
- Update cmake to 3.22.3
- Add AGPL-3.0 wildcard to expand_wildcard_licenses
- Upgrade QT5 to v5.15.3-lts-lgpl
- Improve pip_install_wheel to not need PIP_INSTALL_DIST_PATH and PYPA_WHEEL
- Bitbake fixes for toaster support
- Fix several recipes for ppc64 builds
- Upgrade gstreamer to 1.20.1
- Fix global ppc/ppc64 sitefiles for musl and glibc differences
- Bump bitbake to 2.0.0
- Fix more recipes to use branch and protocol parameters in github SRC_URI
- Move petry python packaging infrastructure from meta-python to core layer
- Fix qemuppc64 recipes and booting with 5.15 kernel
- Adjust recipes for renaming flit_core → python_flit_core
- Fix rust packages to build for riscv32 and musl
- Update systemd to 250.4
- Fix several recipes to build when LIBDIR != lib by default, fixes ppc64
- Convert virtual/libgl to virtual/egl dependencies where possible
- Upgrade libtool to 2.4.7, needed few recipes to re-generate macros
- Fix rust toolchain for SDK environment
- Fix weston 10.x build for TI socs using sgx driver
- Add GLES3/GL headers to SGX DDK
Added
- Add poetry_core helper class for supporting poetry for python packages
- Add snapshot checksums for powerpc64le hosts
- Add support to build on FIPS enabled build hosts
- Added setuptools3_legacy bbclass to keep pre PEP-517 behavior
- Add nativesdk support to cargo and rust compiler tools
- Add Dockerfile in bitbake repo for building PR service
- Add MOUNT_COPYBIND_AVOID_OVERLAYFS env var to skip OverlayFS
- New recipes
- hstr, python3-qface, python3-path, python3-antlr4-runtime
- python3-crc32c, gosu,
Removed
- Drop AVAILABLE_LICENSES variable
- Remove the available_licenses() function from license.bbclass
khem
12
Latest
github-actions released this 5 hours ago
2022.04
dac745d
[2022.04] - 2022-05-01
Changed
- Use clang for python3 compilation and many other recipes
- Use internal version fo ffmpeg for omxplayer
- Update linux-rapberrypi to 5.15.34
- Add ability to specify CPUs to add to the isolcpus list for rpi-cmdline
- Upgrade uninative to 3.6 with gcc 12 support
- Upgrade linux-yocto/5.15 to v5.15.36, linux-yocto/5.10 to v5.10.112
- Fix gcc thread sanitizer against glibc 2.34
- Update python3 to 3.10.4
- Update tzdata to 2022a
- Fix specific version handling for ipk and deb package types
- Upgrade gtk4 to 4.6.2
- Various python module recipe upgrades
- Gnome and XFCE recipe upgrades
- Enable usrmerge feature distro wide
- Switch default docker build to use bullseye/debian-11
- Enable overlayfs to mount r/w parition on rootfs
- Bump simpleiot to 0.0.45
- Enable persistent logs across reboots
- Build own bmaptool-native and remove depending on build host for it
- Assorted recipe major version upgrade
- Allow auto detection of the correct graphics options in runqemu
- Use https with github for SRC_URIs in meta-riscv
- Fix several recipes to compile with GCC-12
- Upgrade Go compiler to 1.18
- Upgrade OpenSSH to 9.0p1
- Fix nativsdk builds for LLVM runtime
- Fix several recipes to buils on ppc/ppc64 with clang
- Fix several recipes to build properly with usrmerge distro feature
- Upgrade GCC to 11.3 release
- Fix several recipes to build with out X11
- Upgrade glibc to latest bugfixes on 2.35 release
- Upgrade rust compiler to 1.60
- Upgrade Clang to 14.0.3
- Enable xz compression in kmod
- Switch linux-raspberrypi to have compressed kernel modules
Added
- Add recipes for OpenThread
- Add recipes for idevicerestore, libadwaita, frr
- Add support for nezha-allwinner-d1 machine
- Add os-release-initrd package
- add UBOOT_ENTRYPOINT to match LOADADDR in linux-raspberrypi
- Add MCP3008 ADC overlay for RPI machines
- Add tune include for armv8.4a
- Add tunes for rv64 without compressed instructions
- Introduce git intercept script due to fakeroot issues in devshell
- Add recipe for musl-locales
Removed
- Drop meta-96boards layer, its unused
- Remove recipes for rpi-hwup-image and rpi-basic-image
- Drop GOBUILDMODE
- Remove invalid GLIBC_EXTRA_OECONF for ppc32
khem
13
2022.05 - “Qashqai”
Latest
github-actions released this 2 days ago
2022.05
0f34c2d
[2022.05] - 2022-05-31
Changed
- Update meta-ti recipes to SDK 08.02.00.005
- Let the user drive the update interval for CVE database
- Correctly handle file names containing colons in bitbake
- Fix firmware autoloading for rpi by creating
brcmfmac43455-sdio.raspberrypi,4-model-b.bin symlink
- Update qemu to 7.0.0
= Upgrade musl to tip of trunk
- Upgrade 250.5
- Use arm-versatile-926ejs KMACHINE for qemuarmv5
- Make git intercept global
- Upgrade GCC to 12.1
- Add openssh-sftp-server to openssh RDEPENDS
- Upgrade linux-firmware to 20220509
- Upgrade linux-raspberrypi to 5.15.38
- Various native recipes fixed to bulld with GCC 12
- Upgrade GDB to 12.1
- Build bash to use proper getcwd() on musl
- Fixes for meta-qt5/meta-intel build failures seen with GCC-12
- Enable using private fonts in wxwidgets
- Fix rare sysroot corruption issue during staging
- Add fspassno parameter to partition in wic
- Fix osc fetcher to support quering latest revision
- Update clang to 14.0.4
- Update mariadb to 10.7.4
- Move lzop from core to meta-oe
- Upgrade QT5 to latest 5.15.4 and fix with musl
- Disable lzo support by default in various recipes
- Fix native builds to use right linker paths in go bbclass
- Update linux-yocto to v5.10.114, v5.15.38
- Upgrade gstreamer to 1.20.2
- Upgrade go to 1.18.2
- Upgrade setuptools to 62.3.1
- Upgrade curl to 7.83.1
- Various recipe version bumps
Added
- Enable updater support for raspberrypi2 machine
meta-raspberrypi now supports enabling 1-wire bus on GPIO4 with
ENABLE_W1 = "1" in local.conf
- Add meta-python to meta=gnome layer dependencies
- Add support for building python recipes which use hatchling
- Add recipe for cpulimit, openzfs, ulog2, libcoap, btrfsmaintenance
python3-web3, python3-lru-dict, python3-eth-account, python3-eth-abi
python3-parsimonious, python3-eth-rlp, python3-rlp, python3-hexbytes
python3-eth-keyfile, python3-eth-keys, python3-eth-utils
python3-eth-typing, python3-eth-hash, python3-decouple
python3-cytoolz, python3-toolz, python3-inotify, nodejs-oe-cache-native
overlayfs-progs, overlayfs-tools, python3-uinput, xfstests
python3-editables, python3-hatchling, python3-pathspec
python3-setuptools-scm-git-archive
Removed
- Remove meta-networking dependency on meta-python by re-arranging
recipe locations
- Drop GPL-3.0 license from libgcrypt
- Remove uclibc remnants from DISTRO_FEATURES
- Removed recipes: speedtest-cli
- Remove libsrvg rv32 patch
khem
14
2022.06 - “Rygja”
Latest
github-actions released this 2 hours ago
2022.06
4e011c1
[2022.06] - 2022-07-04
Changed
- Bump bitbake to 2.0.1
- Build clang_rt.profile compiler-rt library when possible
- Use nftables instead of iptables by default in networkmanager
- Bump riscv linux-mainline to 5.18
- Update perl to 5.36.0
- Update systemd to 251.2
- Add zstd dependencies in gcc recipes
- Set RebootWatchdogSec to 60s as watchdog in systemd
- Major version upgrades for multiple recipes
- Compile ptests with parallelism, disable packages where it fails
- Fix networkmanager build when ppp is enabled
- Upgrade PHP to 8.1.7
- Switch polkit back to mozjs from duktape
- Upgrade strace to 5.18
- Upgrade alsa recipes to 1.2.7.1
- Upgrade major versions of assorted recipes
- Upgrade go to 1.18.3
- Upgrade mesa to 22.1.2
- Fix udev-extraconf lvm automount
- Upgrade python to 3.10.5
- Add support for Ignored CVEs in cve-check
- Enable xwayland in weston init
- Enable gnu-efi for riscv64
- Add SDK support to image-buildinfo
- Fix systemd to build without utmp support
- Upgrade linux-yocto to v5.10.119, v5.15.44
- Enable MDIO bus config in linux-yocto
Added
- Added recipes
libavtp, libtomcrypt, flite
- Add QB_KERNEL_CMDLINE to runqemu
Removed
khem
15
2022.07 - “Sakiz”
Latest
github-actions released this 1 hour ago
2022.07
fb41efb
[2022.07] - 2022-08-19
Changed
- Update clang to 14.0.6
- Fix compiler-rt build for ARMv5
- Fix native and nativesdk builds for armhf targets
- Fix absolute interpreter paths in php, libdbi-perl, libparse-yapp-perl
libdev-checklib-perl
- Update mariadb to 10.8.3
- Update qtwebengine to v5.15.10-lts and use chromium-87
- Update reference kernels linux-yocto/v5.10.134 v5.15.59
- Add recipe for linux-yocto 5.19
- Update gstreamer to 1.20.3
- Add selftest for shebang overflow
- Upgrade openssl to 3.0.4
- Fix multiple recipes for too long shebang
- Filter build paths on statically linked go arches
- Fix reproducibility issues in perf, gperf
- Fix recipes to build with kernel 5.19+
- Update wayland to 1.21.0
- Upgrade rust to 1.62.0
- Add ptests for curl
- Switch glmark2 build system to use meson
- Distribute sample-config-files with openvpn
- Remove logs from ltp installs, disable -mfpmath=sse on x86
- Fix kernel source handling when not using externalsrc
- Use the python3 ThreadPoolExecutor instead of the OE ThreadedPool
- Fix missing MLPREFIX in debug mappings in gcc runtime
- Use picobuild in python_pep517 class
- Backport a fix for gcc bug 105039
- Upgrade glibc to latest 2.35 branch and binutils to 2.38 branch tip
- Add PACKAGECONFIG for capstone in ruby recipe
- Fix gcc-runtime build when using gold linker
- Fix bunch of recipes to remove buildpath QA warnings
- Upgrade python3-picobuild to 0.2 fixes build of some of the
python_setuptools_build_meta inheriting recipes
- Add many unrelated/patched CVEs to ignore list in meta-oe
- Disable cache for g-ir-scanner in gobject-introspection-data class
- Fix newlib and baremetal toolchain builds when using gcc-12
- Update go to 1.19
- Update u-boot to 2022.07
- Update meson to 0.63.0
- Fix rust SDK generation
- Fix sanitizers build with glibc 2.36
- Fix several recipes for mount.h conflict in glibc 2.36
- Fix supplier field in create-spdx
- Use tools from cross-binutils in wic operations
- Fix LTP build with ld-is-gold in DISTRO_FEATURES
- Rework rust recipes to facilitate nativesdk builds
- Fix glibc builds with DEBUG_BUILD turned on
- Override LIC_FILES_CHKSUM for starfive_v2021.04 u-boot
- Update linux-raspberrypi to 5.15.56
- Backport patch to fix CYW43455 and various CVEs for bluez-firmware-rpidistro
- Fix the buildpaths issue in several recipes
- Fix insufficent entropy in sigtask file names
- Fix many packages for configure tests failing with clang-15
- Add fixes for packages to build with glibc 2.36
- Address linux 5.19 fails in multiple recipes
- Add memory pressure regulation in runqemu
- Update OPTEE to 3.18
- Specify -ffile-compilation-dir to omit absolute file paths in debug info
- Remove-libtool inherits from recipe namespace
- Update rust to 3.62.1
- Upgrade glibc to 2.36
- Resolve relative prefix-map filenames and symlinks in GCC
- Prepare several recipes to build with upcoming clang-15
- Switch debug source handling to use prefix map
Added
- Added recipes: libspiro, python3-picobuild, python3-oslash
python3-jsonrpcclient, python3-aiodns, python3-pycares
waylandpp, python-requests-unixsocket, sshpass
- Add support for visionfive board in meta-riscv
- Add QA check for shebangs
- Add buildpaths to WARN_QA by default
- Introduce UBOOT_MKIMAGE_KERNEL_TYPE
- Add cpu/io pressure regulation to bitbake runqueue
- Implement recipe and global classes in bitbake
- add Andeas RISCV ae350-ax45mp machine support
Removed
- Remove obsolete PEP517_BUILD_API
- Remove the ThreadedPool implementation in oe/utils
- Remove recipe for xf86-input-keyboard
- Remove historical movement of libz.so to /lib
- Remove CMAKE_ASM_FLAGS variable in toolchain file
- Drop v5.10 reference linux-yocto kernel recipes
- Remove largefile distro feature
khem
16
2022.08 - “Targhee”
Latest
github-actions released this 3 days ago
2022.08
0bee51b
[2022.08] - 2022-08-31
Changed
- Switch to poky for providing core layer and bitbake
- Fix fluentbit builds on 32bit machines without 64bit atomics
- Upgrade binutils to 2.39 release
- Clean sourced from workspace after devtool finish
- Update python3-setuptools to 65.x
- Add support for config snippet includes to ssh and sshd
- Address recipes with -Wimplicit-function-declaration as error in
pedantic-errors with clang 15
- Update optee to 3.18
- Fix klibc with 5.19 kernel headers
- Fix RWX permission error in optee
- Update pipewire to v0.3.56
- Update u-boot and kernel recipe for starfive
- Upgrade gcc to 12.2.0
- Updated linux-yocto to v5.15.62, v5.19.3
- Fix rng-tools to drop wrong dependencies which delayed boot
- Fix several recipes for musl builds missing -D_GNU_SOURCE
- Several fixes for clang-15 found errors
- Enable SDL backend for host QEMU to allow UI option along with vnc
- Disable O2 in systemd when using clang for now
- Do not use llvm-strip system-wide for now due to bugs
- Enable installing libc++.so as linker script
- Fix libgcrypt ptests and install
- Update glibc to have mount.h conflicts solved on 2.36 release branch
- Fix several recipes to compile with clang-15 on musl
Added
- Add recipe for mdio-tools, usbmuxd, libusbmuxd, libimobiledevice,
libplist, gst-editing-services, uutils-coreutils, python3-asgiref
- Added clang-native class to build native compoennts with clang
- Add test for debuginfod
Removed
- Drop has-elf-tls option from rust-target-config
khem
17
2022.09 - “Uda” Latest
github-actions released this yesterday
2022.09
0ff0992
[2022.09] - 2022-09-30
Changed
- Move clang-native.bbclass to classes/ folder to unbreak other layers
- Fix function used in AC_CHECK_LIB multiple recipes, do not use ‘main’
- Fix type mismatches in multiple packages found with clang-15
- Add missing headers for function prototypes in many packages
- Fix buildpaths issues in several more recipes
- Pass -D_GNU_SOURCE to packages needing gnu extentions on musl
- Always set CC and LD for the kernel build
- Fix i686 toolchain relocation issues in gcc-multilib-config
- Fix npm to use https rather than http fetcher
- Fix rust crossbeam-utils for arches without atomics
- Update rust to 1.63.0 and fix build on musl
- Rework llvm handling in mesa
- Add llvm-config wrapper to improve flags handling
- Fix many recipes to build with clang-15
- Define wayland packageconfig for opengl-es-cts,vulkan-cts
- Major version upgrade for assorted recipes
- Upgrade bpftrace to 0.16.0
- Add rpidistro VLC and ffmpeg build
- Update K & R stype functions in autoconf
- Avoid bad checksum race issues in wget fetcher
- Add no-dns-fallback packageconfig to systemd
- Upgrade major version of clang compiler from 14.0.6 to 15.0.0
- Use gcc to build openssh and webkitgtk for now
- Move python3-lxml from meta-python → core
- Update raspberrypi-firmware to 20220830 snapshot
- Fix target rust with LLVM runtime
- Do not package gprofng.rc in binutils-cross-canadian
- Address sox intermittent build issue
- Fix wireless on Raspberry Pi 4
- Prefer += instead of :append operator in several recipes in core
- Fix weston and gstreamer-plugins-base imx recipes to build with clang
- Fix llvm-objdump crash seen on aarch64/musl golang compiler
- Fix xserver builds on IMX8
- Limit rpidistro-vlc,rpidistro-ffmpeg to rpi machines only
- Fix bunch of CVEs, refer to commits for details
- Update mozjs-91 91.13.0 and fix build with python 3.11
- Update clang to latest on 15.x release
- Fix buildpaths warning on more recipes e.g. exiv2, fltk
- Ubreak opensbi dependencies being added to u-boot for non-riscv
machines
- Enable ZSTD as default compression backend for opkg for yoe
- Enable clang for more applications which were marked non clangable
Notable recipes e.g. u-boot, python3
- Update simpleIOT to 0.5.0 release
- Fix compiler-rt-sanitizers builds on non-x86 builds
- Fix Yoe graphical images with musl to work on IMX8 devices
- Fixes for logger debug() calls
- Fix gcompat on aarch64
- Upgrade mesa to 22.2.0
- Mark simpleIOT builds on riscv32 incompatible since golang support does
not exist yet
- Fix recipes in meta-arm to build with clang-15
- Update clang to 15.0.2
- Logic in gtk-icon-cache class fixed for GTK4
- Update tzdata to 2022d
- Update rpm to 4.18.0-release
- Fix weston imx version packageconfig appending syntax error
Added
- New recipes
- Add layer setup tool in OE-Core
- Add documentation for numa machine feature
- Add support for a ARMv8 machine supporting multiple Raspberry Pi boards
- Add yoe-ptest-image target for ptests
- Add enable_loopback_networking() function in bitbake utilities
Removed
- Remove ypbind-mt on musl
- Remove unifex recipe
- Drop capstone support in ruby
- Remove mozjs-78 recipe
- Drop sqlite2 recipe
khem
18
- Releases
2022.10 - “Valachian”
Latest
Compare
Edit release
Delete release
github-actions released this 26 days ago
2022.10
6f91b40
[2022.10] - 2022-10-30
Changed
- Bump LAYERSERIES_COMPAT to langdate ( yocto 4.1 )
- Enforce using libgcc for fmt package for float128 support
- Allow creating src-pkgs when using clang compiler globally
- Update clang to 15.0.2 release tag
- linux-starfive-dev bumped to 6.0.0
- Tweak libcamera to build for Raspberry Pi
- Build u-boot-starfive outside source tree
- Improve manuals with reference to familiar tasks
- Assorted package version upgrades
- Update clang to 15.0.3
- Fix bpftrace on RISCV64
- Fix linux-hardkernel 4.9 with GCC 12
- Update documentation for oe-core
Added
- Add ptest support for bpftrace
- Add new recipe - rpi-libcamera-apps, python3-pytest-json-report
Perfetto, md4c
Removed
- Removed recipes: onboard
- Remove -ffile-compilation-dir from global clang options
khem
19
2022.11 - “Waziri”
Latest
Compare
Edit release
Delete release
github-actions released this 11 hours ago
2022.11
176b43d
[2022.11] - 2022-11-30
Changed
- Upgrade clang to 15.0.4
- Upgrade Nodejs to 16.18.1
- Fix libpcre dependent packages build e.g. ettercap
- Upgrade various python package versions
- Add opengl to REQUIRED_DISTRO_FEATURES for various packages
- Fix several packages build with python 11
- Enable ipv6 support in nginx
- Add build support to build golang compiler on ppc64le
- Add savedefconfig task in u-boot
- Upgrade openssl to 3.0.7
- Upgrade rust to 1.65.0
- Upgrade weston to 11.0.0
- Add libsoup-3.0 dependency to webkitgtk
- Upgrade systemd to 251.8
- Fix uboot on ae350-ax45mp
- Enable glvnd support in mesa
- Add selinux PACKAGECONFIG to several recipes in core
Added
- Added recipes - gtk-vnc, libglvnd, python3-brotli, minio
jwt-cpp, spice-gtk, python3-kmod, python3-aioserial
- Add libc testsuite for musl
- Add 7-Zip support in conversion types for image_types
- Add crate in own-mirrors
Removed
khem
20
2022.12 - “Xalda”
Latest
Compare
Edit: 2022.12 - “Xalda”
Delete: 2022.12 - “Xalda”
github-actions released this 20 hours ago
2022.12
5c025e9
[2022.12] - 2022-12-31
Changed
- Update clang to 15.0.6 and fix build for 32bit LFS64 systems
- Fix compiler and binutils tools options for kernel and u-boot
- Add protocol= explicitly to github SRC_URI for linux-odroid
- Add opengl to REQUIRED_DISTRO_FEATURES in recipes from meta-oe
- Add ipv6 in PACKAGECONFIG to libwebsockets
- Rename gcr to gcr-3 to accomodate gtk4 and dependencies
- Move GTK4 support to core from meta-oe/meta-gnome layers
- Improve reproduciblity patch in go compiler
- Avoid host contamination in go cross SDK compiler
- Update minimum python version needed to 3.8 on build hosts
- Fix several recipes for lfs64 support
- Ports gtk3+ to use meson
- Update rust compiler to 1.66.0
- Conevert bitbake to use argparse
- add -DUSE_X11 Flag to qtbase to work with latest mesa
- Use python3targetconfig in recipes to use right python for target
- Fix waf-samba to use target python3-config
- Fix openCV build with ffmpeg 5.1+
- Update qemu to 7.2.0
- Update cmake to 3.25.1
- Use rm from HOSTTOOLS in rm_work explicitly
- Update wireplumber to 0.4.13 and use dbus defaults
- Update XFCE recipes to 4.18.0 release
- Update python to 3.11.1
- Add rust to SDK toolchain language selection
- Update systemd to 252.4
- Fix several recipes to work with LFS64 functions removal from musl
- Update several gnome recipes to latest
- Update go compiler to 1.19.4
- Fix rust recipes to work with musl without LFS64 functions
Added
- New recipes - xdg-desktop-portal-wlr, basu, gnome-software,
xdg-desktop-portal, editorconfig, python3-rapidjson, tuna,
sip, python3-uefi-firmware, python3-linux-procfs, python3-schedutils,
gcr-4, python3-watchdogdev, appstream, libtraceevent, libtracefs,
flatpak, flatpak-xdg-utils, libslirp
- Add time64.conf to enable 64bit time_t on 32bit glibc systems
- Add x86-64-v3 tunes (AVX, AVX2, BMI1, BMI2, F16C, FMA, LZCNT, MOVBE, XSAVE)
Removed
- Drop OEBasic siggen from sstate signature
- Remove RRECOMMENDS to rng-tools for sshd package
- Remove SERIAL_CONSOLE variable
