khem
21
Repository: YoeDistro/yoe-distro · Tag: 2023.01 · Commit: c4a205b · Released by: github-actions[bot]
release-notes-from-changelog
GitHub action that extracts release notes from an existing changelog.
Changes in this version:
[2023.01] - 2023-01-30
Changed
- Switch to using ‘mickledore’ for LAYERSERIES_COMPAT
- Fix clang recipes to work without LFS64 functions
- Use gcc to compile pixman on aarch64
- Fix several recipes for 64bit time_t on 32bit arches
- Update musl to latest tip ( drops LFS64 interfaces )
- Use binutils objcopy in BSP linux kernel builds
- Use gcc for all u-boot forks
- Upgrade usbguard to 1.1.2
- Switch qemux86-64 to x86-64-v3 tune
- Include “c” in IMAGE_LINGUAS for glibc
- Upgrade ruby for 3.2.0
- Upgrade curl to 7.87.0
- Switch ostree to use fuse3
- Fix QT5 builds with 64bit time_t
- Update concurrencykit to latest to support RISCV
- Update nezha (rv64 board) support
- Fix EGT recipe to work with clang in meta-atmel
- Improve sstate reuse of llvm-project-sources
- Fix meta-freescale BSP recipes to work with clang compiler
- Fix various python modules to migrate from picobuild to python3-build
- Fix freedom-u540 opensbi dependency loop in meta-riscv
- Improve shutdown handling and lockfile handling in bitbake at exit
- Set ac_cv_sys_file_offset_bits=64 for musl builds globally, enables
64-bit off_t on autotool based packages
- Unify rust patches into rust-source.inc
- Update linux-yocto kernels to v5.15.87 and v6.1.5
- Add libgcc to uninative-tarball
- Fix several recipes to work with powerpc32 architecture
- Bump linux-libc-headers to 6.1
- Add webp packageconfig knob for libtiff
- Upgrade rust to 1.66.1
- Improve reproducibility in clang build
- Apply C++17 portability fixes in several recipes
- Fix C++11(Alignof) issues in several packages
- Update clang to 15.0.7
- Update bcc to 0.26.0
- Fix create-spdx handling for clang
- Fix several recipes to work with upcoming GCC 13 compiler
- Fix Upstream-Status format of several patches
- Use 6.1 kernel for Qemu machines
- Upgrade binutils to 2.40
- Upgrade u-boot to 2023.01
Added
- Added recipes - xdg-desktop-portal-gtk, eog
libdecor, biodbc, python3-build, python3-pyproject-hooks
python3-reedsolo, lvgl-demo-fb, nv-codec-headers, webp-pixbuf-loader
gnome-chess
- Add GLIBC_64BIT_TIME_FLAGS on ppc/x86
- Introduce v6.1 reference linux-yocto kernel recipes
Removed
- Removed recipes - boost-url, python3-strict-rfc3339, python3-picobuild
- Remove package_tar.bbclass from classes-global
khem
22
- Releases
2023.02 - “Zaghawa”
Latest
Compare
Edit: 2023.02 - “Zaghawa”
Delete: 2023.02 - “Zaghawa”
github-actions released this 1 hour ago
2023.02
7173709
[2023.02] - 2023-02-28
Changed
- Update busybox to 1.36, disable SHA accelarators for 32bit x86
- Bundle libc++abi archive into static libc++.a, improves static linking
- Bump kernel to linux-yocto 6.1 for odroid devices
- Add ptest support for python3-pillow
- Fix several recipes to build with upcoming GCC13 release
- Upgrade mongodb to 4.4.18 and fix build with ccache enabled
- Fix recipes to use target python config for target during cross compile
- Pass MAXLINELENGTH to scons invocation, helps with large cmdline lengths
- Upgrade rust to 1.67.1
- Upgrade linux-raspberrypi to 5.15.90
- Add ptest support to gnuTLS
- Upgrade linux-yocto/5.15 to v5.15.91, linux-yocto/6.1 to v6.1.9
- Fix Yoe Updater to use correct boot device after upgrade
- Upgrade glibc to 2.37
- Fix several recipes to work with upcoming gcc 13 release
- Improve on target locale generation
- Fix clang recipe for multilib build
- Enable PIC for static archives with clang runtime libs
- Fix several recipes to build with clang-16/c++17
- Add ptest for minicoredumper
- Add PACKAGECONFIG for video-codecs in mesa
- Provide missing tools during cross compiling openmp
- Sync dtc tree with kernel for nezha/riscv
- Add a PACKAGECONFIG for arm_neon in graphene
- Upgrade gstreamer1.0 to 1.22.0
- Update go compiler to 1.20.1
- Fix wireless on model 3B and Zero W
- Use LLVM_ENABLE_RUNTIMES to build llvm runtime libs
- Speedup nodejs native compilation by not during cross builds
- Improve idle thread exception handling in bitbake
- Do not use xz parallelism options with zstd
- Enable systemd-time-wait-sync.service when timesycd is enabled
- Improve build-appliance-image target
- Upgrade Upgrade to 13.1
- Fix QEMU build with 6.2 kernel headers
- Fix ffmpeg build with vulkan
- Improve resulttool reporting
- Upgrade musl to latest tip of trunk
- Fix Upstream-Status for several patches
Added
- New recipes
- python3-pycups, extract-cert, rtkit, system-config-printer
rpi-eeprom, libdeflate, python-daemon, smemstat, linux-serial-test
libgpiod v2.0-rc2, python3-gpiod, plocate
- Add initial support for loongarch64 architecture
- Add artifact signing infrastructure class ( signing.bbclass )
- Add weston kiosk shell
Removed
- Remove rock-pi-4 MACHINE
- Remove image SPDX and index from deploydir
- Remove clang-offload-wrapper from clang, gone in clang 16 as well
- Remove glib site cached values
- Removed recipes
khem
23
2023.03 - “Acıpayam”
Latest
Edit: 2023.03 - “Acıpayam”
Delete: 2023.03 - “Acıpayam”
github-actions released this 28 minutes ago
2023.03
955ef9e
[2023.03] - 2023-02-30
Changed
- Upgrade raspberrypi kernel to 5.15.103
- Upgrade linux-yocto to v6.1.20
- Upgrade openSBI to 1.2 and fix cyclic dependency for fitImage based boards
- Create machine-id with “uninitialized” text
- Upgrade simpleIOT to 0.9.0 release
- Refresh fixes for android-tools
- Upgrade linux-hardkernel to 4.9.337
- Upgrade nodejs to 18.14.2
- Enable mesa-demos build with userland graphics drivers on rpi
- Enable kms plugin for visionfive2
- Fix gdb intermittent build issue
- Allow overwrite of QB_CPU for qemux86
- Add PROVIDES and RPROVIDES for virtual/opencl-icd
- Enable --enable-new-dtags in binutils for DT_RUNPATH
- Add missing binutils dependency in glibc
- Yoe updater now supports tmpfs as well as persistent overlays
- Add yoe-installer-image to create SD card installer for eMMC
- Switch to using ext4.xz for rootfs in updater
- Update arm optee-os to 3.20.0
- Upgrade bpftrace to 0.17.0
- Fix serveral recipes in meta-freesclale to build world
- Enable parallel execution of ptest images and fix ptest dependencies
- Handle spaces within user $PATH in SDK installers
- Upgrade systemd to 253.1
- Upgrade visionfive2-firmware to VF2_v2.10.4
- Fix nodejs build on older build hosts eg. centos8
- Move android-tools from meta-clang to meta-oe
- Update openssh to 3.1.0
- Update matchbox recipes to latest
- Upgrade networkmanager to 1.42.4
- Upgrade clang to 16.0.0
- Fix building various packagegroups in meta-openembedded
- Use python3-unittest-automake-output in python recipes for ptest integration
- Fix qtpdf with clang-native from 16.0.0 release
- Update android-tools to 29.0.6.r14
- Disable warnings as errors when building glibc
- Update mesa to 23.0.0
- respect IMAGE_LINK_NAME in seftests
- Upgrade RPI kernel to 6.1
- Fix some linkshared regression introduced in go 1.20
- Upgrade openssh to 9.3p1
- Fix rpi specific vlc and ffmpeg with clang16
- Update clang to 16.0.1
- Fix libunwind compile failures on 32-bit arm with Clang 16
Added
- Add kernel specific KERNEL_OBJDUMP variable
- Add VOLATILE_TMP_DIR variable
- Add support for visionfive2 board
- Add recipes - python3-rich, xdg-dbus-proxy, libavif, dav1d
pgpool2, python3-unittest-automake-output, debugedit, reboot-mode
python3-executing, python3-pure-eval, python3-stack-data
exfatprogs
- Add yoe updater support for MX8-VAR-SOM symphony board
- Add ptest support for mbedTLS
- Add buildstats-summary script
- Add support for loongarch64
- Add find-debuginfo support back
Removed
- Removed recipes - quagga, jhi, exfat-utils
khem
24
2023.04 - “Balkhi”
Latest
Compare
Edit: 2023.04 - “Balkhi”
Delete: 2023.04 - “Balkhi”
github-actions released this last week
2023.04
1801832
[2023.04] - 2023-04-29
Changed
- Fix meta-clang towards meeting yocto layer compatible status
- Fix clang packaging issue where installing clang-tools
would pull in whole compiler
- Simplify imx-boot container
- Add 6.1 linux-ti-staging
- Update tzdata 2023c
- Make EXCLUDE_FROM_WORLD boolean
- Fix recipes to build with upcoming 2.72 autconf release
- Remove double protocol= from SRC_URIs in meta-oe
- Correct the license information for several recipes in meta-oe
- Update several gnome recipes to 44.0
- Add ptest images for meta-oe, meta-python, meta-perl
- Update rust to 1.68.1
- Add missing dependency on glib-2.0-native in several recipes
- Add fixes to several recipes to build with autoconf 2.72
- Update clang to llvmorg-16.0.1 release
- Fix bindgen-cli and python3-pyruvate to work with new crate
updated class
- Fix upstream patch status in meta-webserver, meta-perl, meta-xfce
meta-gnome, and meta-multimedia
- Improve cargo-update-recipe-crates to specify two different versions
of same crate in given recipe
- Use 3.20 version for OPTEE components
- Update VisionFive2 firmware to 2.11.5
- Upgrade pipewire to 0.3.68
- Fix recipes to build with multilib on
- Switch beaglebone and beagle-x15 to bb.org kernel/u-boot
- Add support for creating bootable SD card for visionfive2 board
- Use 6.2 for linux-ti-mainline kernel
- Use shlex instead of deprecated pipe in python scripts
- Upgrade u-boot to 2023.04
- Update ffmpeg to 6.0
- Update musl to latest trunk
- Update rust to 1.68.2
- Update FSL u-boot to 2023.04 release
- Update QT5 to v5.15.9-lts-lgpl
- Add new Assimp submodule to qt3d
- Fix visionfive2 wic file generation
- Upgrade systemd 253.1 → 253.3
- Fix several ptests to work on musl systems
- Fix runtime dependencies for clang scanbuild
- Update linux-yocto to v6.1.25, v5.15.108, v6.1.24
- Fix bunch pf ptests on musl to fix core-image-ptests-fast
Added
- Add new CVE database fetcher cve-update-nvd2-native
- Added new recipes:
- libpcsc-perl, polkit-gnome, libnfs, adw-gtk3, etcd-cpp-apiv3
- Add ptests for libtinyxml2, python3-lorem, python3-path and dc
bitwise
- Enable hashserve distro-wide for yoe
- Add support for Raspberry Pi Camera Module v3
khem
25
2023.05 - “Coopworth”
Latest
github-actions released this 2 minutes ago
2023.05
25573f9
[2023.05] - 2023-05-30
Changed
- Upgrade clang to 16.0.4+
- Fix stale SRC_URI locations in several meta-openembedded recipes
- Drop crosssdk suffix from virtual binutils, gcc, go and clang recipes
- Fix SRC_URI locations for several recipes in meta-openembedded
- Switch to using upcoming debian “bookworm” based container for building
- Enable LoongArch support in clang
- Upgrade lvgl recipes and support wayland and fbdev backends
- Fix buildpath QA errors in many meta-openembedded recipes
- Fix recipes to build without gobject-introspection-data
- Upgrade Gstreamer to 1.22.2
- Update musl to 1.2.4
- Add CPE_NAME to /etc/os-release
- Set minimum required target kernel to 5.15
- Upgrade rust compiler to 1.69.0
- Upgrade QEMU to 8.0.0 and fix ppc32 emulation bug
- Default to https git protocol where possible in SRC_URI
- Add --libfiles option to llvm-config
- Add systemd unit file for etcd
- Uprev libplist to 2.3.0, fix several dependent recipes to
support API changes from 2.3.0
- Fix rpi-libcamera-apps recipe for ARM64
- Fix linux-bb.org to build with gcc 13
- Fix several recipes in meta-oe to remove TMPDIR in output packages
- Update libfmt to version 10 and fix dependencies to support new APIs
- Use autoconf-archive-native as m4 macros dependencies during build
instead of target autoconf-archive during build
- Enable zbb manip extensions for rv32/rv64 in ffmpeg build
- Fix few of buildpath issues in meta-openembedded recipes
- Simplify MACHINEOVERRIDES definitions for rpi
- Add missing run-time dependencies in several ptython module recipes
- Mandate gobject-introspection-data DISTRO_FEATURE
- Let clang override the llvm provided by OE-Core
- Remove unused patch files in core and meta-openembedded layers
- Add ptest support to hiredis and uprev to 1.1.0
- Upgrade go compiler to 1.20.4
- Upgrade binutils to latest top of 2.40 branch
- Upgrade zfs to latest master which is 2.1.11+
- Requires gobject-introspection-data DISTRO_FEATURE in dependent recipes
- Update curl to 8.1.1
- Update busybox to 1.36.1
- Upgrade to GCC 13.1
Added
- New recipes
- etcd, python3-tomlkit, python3-pytest-mock, python3-calver
python3-trove-classifiers, python3-platformdirs, python3-uswid
python3-pefile, libcbor, psutils, libpaper, serial, libisoburn
libisofs, paprefs, openfortivpn, networkmanager-fortisslvpn
mbpoll, python3-bleak
Removed
- Drop MIPS Edgerouter support
- Removed recipes
- xorriso, python3-async, linux-yocto 5.15
- Drop lzop from linux-imx defaults
khem
26
2023.06 - “daglic”
Latest
Compare
Edit: 2023.06 - “daglic”
Delete: 2023.06 - “daglic”
github-actions released this 44 minutes ago
2023.06
a2a2f92
[2023.06] - 2023-06-30
Changed
- Add missing run-time dependencies in several python recipes
- Stop using PYTHON_PN in several python recipes
- Add 44.2 gnome recipes
- Fix REQUIRED_DISTRO_FEATURES gobject-introspection-data in several recipes
- Upgrade linux-yocto/6.1 to v6.1.35
- Document SPLASH_IMAGES variable
- Do not search host paths for find_program() in cmake.bbclass
- Don’t force PAHOLE=false in linux-yocto
- Upgrade OpenSSL 3.1.1
- Enable fullscreen and disable startup-msg in psplash
- Fix spdx license parsing
- Make built-in libtraceevent plugins from perf cohabit with external libtraceevent
- Fix vulkan-samples build on 32-bit platforms
- Make OpenSBI FW_TEXT_START=0x40000000 specific to jh7110
- Use python3 in oe-stylize
- Upgrade wireshark to 4.0.x
- remove -fcanon-prefix-map in scp-firmware recipe
- Use IMAGE_LINK_NAME in updater and yoe-initramfs-image
- Upgrade gstreamer1.0 to 1.22.3
- Update rust to 1.70.0
- Switch meta-qt6 to 6.5 branch instead of 6.5.1 point release branch
- Update clang to 16.0.6 tag
- Fix enabling lld as distro linker in clang.bbclass
- Upgrade go compiler to 1.20.5
- Fix recipes to build issues found using lld linker
- Drop setting ARM_INSTRUCTION_SET explicitly, it can build in thumb mode
and upgrade to 8.2.7
- Use BFD linker for libgcc and glibc explicitly
- Replace Yocto .h by .png splashscreen in psplash
- Add weston user to wayland and render groups
- Upgrade libubootenv to 0.3.4
- Fix several recipes to link with LLD linker
- Use llvm-strip system-wide for STRIP utility for RISCV targets
- Fix ntpd systemd service type forking → simple
- Fix OpenSBI build for visionfive2 SBC
- Upgrade GDB to 13.2
- Drop using tunctl in runqemu/qemu-helper
- Upgrade python to 3.11.3
- Upgrade mesa to 23.1.1
- Fix gn to build with gcc-13
- Backport fix for linking failures using LLD linker for RISCV
- Migrate to use markdown format for READMEs in meta-openembedded
- Fix vpu and pvr-graphics build and packaging issues on visionfive2
- Bump LLVM in core layer to 16.0.6
- Fix several recipes to build when LLD is default distro linker
- Add Upstream-Status tags to meta-openembedded, meta-rpi, meta-odroid
meta-freescale, meta-clang and meta-yoe layers
- Add support for mbedTLS v3.x
- Bump QT6 packages to 6.5.3
- Fix weston booting issues on visionfive2 SBC and update to use
StarFive SDK v3.0.4 components
- Improve patch-status layer filtering in insane.bbclass QA checks
- Update rpi kernel to 6.1.34
- Enable glx/opengl support in gstreamer1.0-plugins-base
- Update python3 to 3.11.4
Added
- Added recipes - python3-ninja-syntax, python3-lazy, python3-classes
python3-pypng, stopit, vulkan-validation-layers, python3-meson-python
- Add support for loongarch64 to initramfs
- Add QT6 layer and enable it for var-som-mx8
- Add LGPL-3.0-with-zeromq-exception to common-licenses
- Add python_mesonpy class
- Add new project for VisionFive2
- Add support for Variscite VAR-SOM-MX8M-NANO
- Add layer- override support
- Enable largefile and 64bit time_t support systemwide for 32 bit platforms
Removed
khem
27
2023.07 - “exmoor”
Latest
Compare
github-actions released this 4 minutes ago
2023.07
63c5485
[2023.07] - 2023-07-31
Changed
- Fix parallel build issue with external modules on visionfive2
- Move xcb-util-cursor from meta-oe to core layer
- Upgrade ostree to 2023.5
- Upgrade bcc to 0.28.0
- Update visionfive2 SDK components to V3.1.5
- Upgrade openCV to 4.8.0
- Upgrade bpftrace to 0.18.0
- Upgrade linux-raspberrypi to 6.1.38
- Update linux-yocto 6.1 to v6.1.38 and 6.4 to v6.4.3
- Upgrade bluez5 5.66 → 5.68
- Enable JIT on RISCV64 for webkitgtk
- Add -Wl,–undefined-version when using lld for few recipes
- Upgrade opkg to 0.6.2
- Upgrade go compiler to 1.20.6
- Improve pybootchartgui rendering
- Add -mbranch-protection=standard for all aarch64
- Configure gcc without --enable-standard-branch-protection
- Upgrade qemu to 8.0.3
- Upgrade linux-firmware to 20230625
- Add rust selftests
- Fix network restrictions for glibc-testsuite ptests
- Add the disable-wifi overlay for RPI machines
- Improve glibc testing over nfs root
- Upgrade GCC to 13.2 release
- Upgrade autoconf to 2.72c
- Fix freertos-variscite compile failure when do_compile is rerun
Added
- Added recipes - python3-pyqt5, python3-pyqt5-sip, python3-pyqt-builder
wtmpdb, lastlog2
- Yoe logo in psplash
Removed
khem
29
2023.08 - “Faeroes”
Latest
Compare
2023.08
dab87cc
[2023.08] - 2023-08-31
Changed
- Move projects to toplevel conf directory
- Implement new project detection logic in envsetup
- Upgrade Simple IoT to v0.12.2
- Fix dependencies for yoe-kiosk-browser
- Convert CVE_CHECK_IGNORE to CVE_STATUS in meta-openembedded
- Fix cross builds for python3-pyaudio
- Enable wayland/x11/opengl configs based corresponding distro features in mesa-pvr
- Move libadwaita to core layer
- Move gcr3 to meta-oe
- Upgrade systemd to 254
- Upgrade FSL graphics stack to 6.4.11.p1.2 BSP release
- Use libgpiod 1.x for VAR-SOM based projects e.g. var-som-mx8
- Switch Qemu based projects to use QT6 instead of QT5
- Upgrade musl to tip of trunk
- Upgrade binutils to 2.41 release
- Fix syntax error in image_types_sparse
- Bump libcamera to latest tip of trunk
- Fix conversion errors in cve_check
- Fix poco ptests run
- Fix ptests runs on qemu inside container
- Do not use lld on riscv with binutils 2.41
- More LLD fixes e.g. elfutils and gnu-efi
- Use yoe-kiosk-image instead of yoe-qt5-image for CI
- Bump libcamera-apps to latest
- Do not use internal assembler with clang for qtbase
- Restart yoe-kiosk-browser service on failure
- Update linux-yocto/6.4 to v6.4.11 and 6.1 to v6.1.46
- Pass /dev/vhost-net to build container from envsetup
- Upgrade openssh to 9.3p2
- Upgrade go compiler to 1.20.7
- Fix recipe_sysroot_check_ld_is_lld to not trigger on allarch recipes
- Fix rust features for vfpv3d16
- Adjust commman to work with interface renaming with
kernel 6.4 and systemd 254
- Switch RPI4 to use QT6
- Wrap more bitbake commands in container e.g. bitbake-getvar
- Enable i2c and disable rpi boot logo for rpi4-64
- Add needed host SDK bits for QT6 to yoe-kiosk-image
- Define SRCREV_FORMAT for recipes with multiple git SRC_URIs
- Upgrade to glibc 2.38
- Upgrade openSSL to 3.1.2
- Fix unnessary clang rebuild when enabling MULTILIBS
- Add ptests to librelp and run them by default in meta-oe ptest image
- Upgrade mariadb to 10.11.5
- Fix musl build for riscv32
- Allow building some native recipes with ccache
- Do not use LLD linker to build go-runtime on aarch64, subsequent
apps linking with this go-runtime crashes go linker
- Switch from GNU-TLS to openssl transport by default on rsyslog
- Update to latest on QT6 6.5 LTS
- Improve taskhash reproducibility in bitbake/siggen
- Add new srcrev fetcher API to fetch2
- Disable perl support in perf
- Do not define TESTIMAGE_AUTO for qemu machines
- Fix allarch override syntax in cmake class
- Fix recipes to work on arm without neon systems
- Update contribution guidelines
- Upgrade cmake to 3.27.4
- Increase python thread stack size to 2M on musl
Added
- Added recipes
- webkitgtk3, libnvme, python3-telnetlib3, mstpd, bolt
python3-types-psutil, python3-types-setuptools, qad
ttf-google-fira, python3-oauth2client, python3-schedule
spice-guest-vdagent, aml, phodav, gnome-boxes, libosinfo
gnome-remote-desktop, libcacard, usbids, qcbor
python3-sdbus, libfaketime, python3-piccata, python3-gspread
- Add script to generate kernel CVE_STATUS entries for linux-yocto
- Add packageconfig to support colored logs in journald
- Add DOCKER_PORTS variable in setenv to forward ports between docker and host
- Add GCP fetcher to list of supported protocols
- Add yocto sstate mirror as default backup for public sstate feeds
- Add MESON_TARGET to meson class which can be defined in recipes
- Add DOCKER_EXTRA_ARGS to envsetup to pass custom options to docker
- Add vfat image type
Removed
- Remove version-going-backwards from build QA errors
- Remove unused AUTHOR variable from recipes in meta-openembedded
and core
khem
30
2023.09 - “Galway”
Latest
Compare
github-actions released this yesterday
2023.09
cc16647
[2023.09] - 2023-09-30
Changed
- Reset DOCKER_REPO inside interactive docker shell
- Add glibc 2.38 stable updates
- Switch glib-networking to use gnuTLS for TLS needs
- Fix KCONFIG_CONFIG_COMMAND in menuconfig task
- Fix python, tcl ptest runs on musl
- Fix multilib builds of few packages in meta-oe
- Fix several packages to build for non-neon arm targets
- Fix multilib support in clang to search lib32
- Fix fetching bcc recipe to not modify .gitconfig on build host
- Explicitly disable JIT in webkitgtk for armv7* with softfp
- Fix rust targets for ppc64 architecture
- Improve loongarch support in go compile and gcc toolchain
- Update linux-yocto/6.4 to v6.4.14 and 6.1 to v6.1.51
- Upgrade qemu to 8.1.0
- Review CVE_STATUS for kernel vulnerablity list
- Fix several ptests in core to work on musl
- Upgrade weston to 12.0.2
- Switch to using “nanbield” layer series compat
- Update VisionFive2 SDK to V3.6.1
- Fix -fstack-protector GCC on aarch64
- Mark RISCV32 incompatible architecture in goarch.bbclass
- Upgrade coreutils to 9.4
- Add ptest support to mariadb
- Enable 64 bit shell arithmetic in busybox, helps 64bit time_t
- Fix build race in piglit and groff
- Use mtime checks instead of inotify in bitbake
- Use 64 bit integers across all targets in perl
- Upgrade clang to 17.0 major release series
- Upgrade gnome recipes to 45.0
- Update linux-raspberrypi kernel to 6.1.54
- Update OpenSSL to 3.1.3
- Improve oeqa/runtime/parselogs
- Enable yocto sstate feed server
- Upgrade to systemd 254.4
- Reduce debuf info size of webkitgtk3 and webkitgtk
- Fix mesa to build with LLVM 17
- Fix recipes to build with kernel 6.5
- Add missing upstream status for all recipes in meta-openembedded
- Update nodejs to 20.5.1
- Bump VF2 SDK to v3.7.5
Added
- Added new recipes
- microcom, vsomeip, libei, python3-apiflask
python3-webargs, python3-flask-httpauth, python3-apispec
python3-flask-marshmallow, webrtc-audio-processing, python3-flask-jwt-extended
tecla, python3-pyu2f, python3-uritools, python3-beartype, musl-legacy-error
python3-spdx-tools, python3-flask-cors, python3-boto3, python3-botocore
python3-nacl
- Add gpt-hybrid partition layout to wic
- Enable generating spdx manifest by default
Removed
khem
31
2023.10 - “Hampshire”
Latest
Compare
2023.10
0576c8a
[2023.10] - 2023-10-30
Changed
- Upgrade clang to 17.0.3
- Fix libcgroup and kernel-selftest to build with lld linker
- Fix ptest images to match core layer naming convention
- Fix ptest reporting issues in meta-oe packages
- Upgrade mason to 1.2.2
- Upgrade u-boot to 2023.10
- Add 6.5 kernel and switch to using it as default for qemu machines
- Add kernel-selftest to slow ptest image for x86 and enable bpf tests
- Upgrade cryptodev to build with kernel 6.5
- Use ttyrun to get getty on busybox init and sysvinit init systems
- Add static-passwd and static-group files for meta-openembedded layers
- Fix ptest failures in poco, libtevent, and libnet-idn-encode
- Add ptests for libldb, cjson, re2
- Upgrade linux-yocto recipes to v6.1.57, v6.5.7
- Upgrade go compiler to 1.20.10
- Upgrade curl to 8.4.0
- Fix ptests for python3-py-cpuinfo and python3-pytest-mock
- Add ptest for libtext-diff-perl
- Update QT6.5 to latest
- Upgrade openSSH to 9.5p1
- Update dtb path for qemuarmv5 in linux-yocto 6.5 onwards
- Fix pvr drivers to work with musl on visionfive2
- Fix pvr visionfive2 drivers on musl
- Update nodejs to 20.8.1
- Make systemd packaging more granular
- Replace RUNTIME variable with TC_CXX_RUNTIME
- Do not set powersave as the default CPU governor in linux-raspberrypi
- Update simpleIOT to 0.13.1
- Switch to using QT 6.6
- Update ostree to 2023.7 and add ed25519-openssl support
Added
- Added recipes - tayga, ttyrun, python3-arrow, python-git-pw
- libexosip2, libosip2, pcapplusplus
- Add bblock feature to core
- Add Yoe updater support for VisionFive2 board
Removed
- Dropped recipes for linux-yocto/6.4, po4a, debsums
- Remove bitbake-whatchanged bitbake utility
- Drop DEPLOY_DIR_TAR variable
khem
32
2023.11 - "Istrian
Latest
Compare
github-actions released this 24 minutes ago
2023.11
3303d87
[2023.11] - 2023-11-30
Changed
- Revive patchreview script
- Add python_hatchling support to recipetool
- Upgrade QEMU to 8.1.2
- Drop dependecy on libcroco in openbox and gnome-shell
- Update QT6 to 6.6.2
- Upgrade clang to 17.0.5
- add nativesdk version of acpica
- Use correct targets for rust binaries in meson
- Update openSBI to 1.3.1
- Update linux-yocto/6.5 to v6.5.9 and linux-yocto/6.1 to v6.1.60
- Fix arm arch mapping issues in libdnf
- Fix ODROID-C4 broken SD cards by dropping use of IMAGE_NAME_SUFFIX
- Upgrade linux-hardkernel-4.9 to latest upstream
- Fix WKS_FILE assignment which lets it use yoe wks template now
- Pin minimum kernel to 4.9 for C4
- Fix librsvg for RISCV32 architecture
- Fix libarchive build inconsistency w.r.t. libb2 presence
- Fix ptest-packagelists for RISCV32
- Fix spidev-test on kernel 4.9
- Add ptest support to nlohmann-json
- Use meson as default buildsystem for gnomebase.bbclass
- Adjust recipes in meta-openembedded to work with meson defaults for
gnomebase.bbclass
- Obsolete dleyna related recipes
- Update linux-raspberrypi to 6.1.61
- Add systemd startup to yoe-kiosk-browser to run it usin linuxfb
- Add G31 mali driver and make it work with ODROID-C4
- Update rpi-config to tip of tree
- Fix mesa-gl build with LLD
- Drop PE, PR from /usr/src/debug paths in recipes from multiple layers
- Use nonarch libdir for tmpfiles.d in multiple recipes
- Process installed dependencies in deterministic order during staging
- Add sysvinit to distro features when using busybox init system
- Fix mesa for ODROID-C4 with G32 Mali userspace driver
- Upgrade gstreamer to 1.22.7
- Add minimal configuration for VS Code
- Add htop to yoe-simple-image
Added
- Add nanopi-m4b machine
- Added recipes for:
- python3-pcodedmp, python3-olefile, python3-oletools
- python3-multivolumefile, python3-pymemcache, python3-jsbeautifier
- python3-inflate64, python3-colorclass, python3-rarfile
- reptyr, python3-unoconv, python3-screeninfo, python3-zopeevent
- python3-flask-restx, exiftool, python3-pdm, python3-pdm-backend
- python3-wand, python3-py7zr, python3-pyppmd, python3-pybcj
- bindfs, kmsxx, python3-file-magic, btop
- Add KAS support in meta-riscv
- Add handler to create go recipes Add go-vendor class
- Add recipetool handler to create go recipes
- Add initial support to use RISCV64 build host
- Add websocket support and SQLalchemy hashserv backend in bitbake
- Add new project for orin nano tegra board
- Add initial support for Milk-V Duo board
- Add new project for NVIDIA jetson orin-nano
Removed
- Remove ${CCACHE} from FORTRAN compiler in bitbake config file
- Removed recipes - libcroco, netkit
- Drop obsolete SERIAL_CONSOLES_CHECK for all machines
- Dropped recipes:
khem
33
2023.12 - “Jezerskosolflorinavska”
Latest
Compare
github-actions released this 3 days ago
2023.12
1fd638d
[2023.12] - 2023-12-30
Changed
- Fix mesa-gl conflict with mali-g31 driver KHR/khrplatform.h header
- Enable utmp support in busybox on musl systems
- Support qemu for cmake via cmake-qemu.bbclass
- Update clang to 17.0.6
- Disable lld for x32 ABI, it does not have support
- Upgrade autoconf to 2.72d
- Unset CMAKE_CXX_IMPLICIT_INCLUDE_DIRECTORIES in cmake
- Upgrade rust to 1.71.1
- Update go compiler to 1.20.12
- Update linux-yocto versions to v6.1.68, v6.5.13
- Prepate several recipes for working with python 3.12
- Fix meta-tegra to build with musl
- Use clang to compile openSSH again
- Fix build issues in bpftrace ptests
- Add ptests for c-ares
- Switch to 6.1 kernel for linux-starfive from 3.9.3 SDK
- Ensure features don’t get backfilled for nativesdk
- Switch to using zstd compression in core layer
- Update gdb to 14.1 release
- Fix several packages to use right basename POSIX or GNU option
Added
- Added recipes - monocypher, xorg-docs, xcursor-themes
python3-maturin, cyaml, pkcs11-provider
- Devtool now supports git submodules for SRC_URI
- Add python recipe writing support to recipetool
- Add python maturin support
- Add project for jetson-orin-nano with NVME boot media
Removed
- Removed recipes - vte9, systemtap-uprobes
- Remove unused SRC_DISTRIBUTE_LICENSES variable
- Drop removed IMA option from linux-yocto
khem
34
2024.01 - “Katahdin”
Latest
Compare
2024.01
85d3116
[2024.01] - 2024-01-31
Changed
- Fix llvm-config to work in cross-compilation environment
- Fix several recipes to work with python 3.12
- Update rust compiler to 1.74.1
- introduce 6.6 reference kernel and make it default for Qemu machines
- Update linux-kernels to v6.1.70 and v6.6.9
- Require bitbake 2.7.1 minimum
- Update mesa to 23.3.2
- Update visionfive2 firmware to JH7110_VF2_6.1_v5.10.3
- Disable mongodb build until its ported to python 3.12
- Add udev-bash-completion package to systemd
- Upgrade reference u-boot to 2024.01
- Use pkg-config in the meson cross files
- Backport opkg fix to drop --numeric-owner parameter
- don’t exclude gtkdocize in autotools class, fix several recipes
to inherit gtk-doc
- Distable incompatible-function-pointer-types warning as error
with clang 17 on python3-lxml and python3-kivy
- Update VisionFive2 u-boot to JH7110_VF2_6.1_v5.10.3
- Fix evolution-data-server fallout with inherit_defer
- Add check for rv32 musl support being absent in Core layer
- Undo the musl/rv32 host compatible check in meta-riscv
- Update weston to 13.0.0
- Update autoconf to 2.72d → 2.72e
- Fix openssl build on riscv32
- Update to python 3.12 major release
- Improve go-vendor support in recipetool
- Add build time QA check for “virtual/” in RPROVIDES and RDEPENDS
- Fix the mozjs-115 build on ARMv5
- Update linux-yocto versions to v6.1.73, v6.6.12
- Upgrade uftrace to 0.15.2, adds support for rust and python
- Add ptest support for xz
- Upgrade rpm to 4.19.1
- upgrade systemd to 255.1
- Upgrade Qemu to 8.2.0
- Update QT6 to 6.6.2 and add build fixes to QTWebengine with latest clang
Added
- New recipe - ssd1306, dropwatch, python3-apscheduler
- Added machines - orangepi-5-plus, rock-4c-plus, rock-3a, roc-rk3308-cc
roc-rk3328-cc, Raspberrypi5
- Add Darwin platform support to cmake class
- Add a new
inherit_defer keyword support to bitbake
- add devtool support for multiple source in SRC_URI
- Add new project for rpi4 32bit machine
Removed
- Removed recipes: zvariant, polkit-0.119, mozjs-102, python3-jsonrpcserver
python3-oslash, python3-kmod, python3-xmlrunner, linux-yocto/6.1
khem
36
2024.03 - “Massese”
Latest
Compare
2024.03
7021d6d
[2024.03] - 2024-03-31
Changed
- Adjustments for bmap-tools → bmaptool rename
- Major update of clang compiler to 18.1.2
- Add fixes to build recipes with clang-18
- Upgrade vlc to 3.0.20
- Fix reproducibility issues in gnome recipes
- Fix several recipes to work with libxml2 2.12+
- Upgrade PHP to 8.2.16
- Upgrade systemd from 255.1 → 255.4
- Bump Go compiler to 1.22
- Upgrade GDB to 14.2
- Update linux-yocto to v6.6.22
- Add ptests to several python recipes
- Upgrade LVGL to 9.0 major release
- Upgrade to using QT 6.7.1 in yoe-kiosk-browser
- Update to use 6.1 kernel on all IMX8/IMX9 projects
- Fix var-som-mx8 project to use 6.1 kernel
- Generate versioned shared libraries from LVGL
- Upgrade frr to latest on 9.1 stable
- set TNSPEC_BOOTDEV_DEFAULT for jetson-orin-nano-devkit
- Upgrade some portions of Gnome to 46.0
- Add linux-raspberrypi 6.6 LTS kernel recipe and default to it
- Update meta-tegra to use R35.5.0 nvidia SDK
- Upgrade golang compiler to 1.22.1
- Update to LLVM 18.1.1
- Fix vala to work with gtk < 4.14
- Use +nocrypto with -mcpu compiler options for rpi3/rpi4
- Fix qttools 6.x build with clang
- Update simpleIOT to 0.15.3
- Fix libcamera crashes due to clang patches
- Fix musl builds for openflow, liburing, tracker-miners, libcamera
plocate
- Bump linux-raspberrypi to 6.6.22
- Add rpi hifiberry-dacplusadc overlay
- Add apache preset mpm=prefork by default
Added
- Add new recipes
- python3-wsproto, python3-httptools, python3-a2wsgi
python3-a2wsgi, python3-responses, python3-pytest-localserver
python3-tomli-w, python3-invoke, python3-icecream
python3-types-python-dateutil, python3-freezegun
buildtools-imagemagick, spandsp, sngrep, bluez-tools
freerdp3, python3-dbus, msgraph, gtk4mm, aer-inject
microsoft-gsl, libcpr, gnome-user-share
- Add genericarm64 MACHINE
khem
37
2024.04 - “Norfolk”
Latest
Compare
github-actions released this 11 hours ago
2024.04
d03af18
[2024.04] - 2024-04-30
Changed
- Upgrade webkitgtk3 to 2.44
- Fix packaging conflicts between mesa and mesa-pvr for RISCV64
- Upgrade linux-yocto to v6.6.23
- Upgrade gstreamer to 1.22.11
- Fix openssl crash on aarch64 w/o crypto instructions
- Accomodate llvm in readelf and objdump commands in oe packaging
- Enable OPTEE for var-som-mx8 project
- Upgrade Golang to 1.22.2
- Upgrade webkit to 2.44.0
- Fix ptests for several meta-openembedded recipes
- Update QT6 to latest 6.7
- Upgrade clang compiler to 18.1.3
- Switch to use http/https instead of ftp in SRC_URIs
- Update linux-variscite to include DT fix to enable PCIE
- Upgrade clang to 18.1.4
- Support 6.6 kernel and u-boot 2024.04 on upstream odroid machines
- Update several gnome components to 46.1
- Add GPT partition names to partitions on rockchip machines
- Fix ptest runs for pv, psqlodbc, unixdoc, ostree
- Add fido2 support to openSSH
- Make predictable name mac policy opt-out in systemd
Added
- New Recipes
- highway, libjxl, python-libusb1, libfido2, avro-c++, python3-flexcache
python3-flexparser, composefs, aravis, ydotool
Removed
- Removed recipes
- libxml++, python3-websockets
khem
38
2024.05 - “Ossimi”
Latest
Compare
2024.05
7a20b85
[2024.05] - 2024-05-31
Changed
- Upgrade GCC to 14.1 major release
- Enable LLD linker as default for RISCV
- Upgrade strace to 6.8
- Upgrade clang compiler to 18.1.6
- Upgrade nginx to 1.26.0
- Fix several recipes to build with GCC-14
- Refactor composefs recipe
- Fix visionfive2-pvr-graphics sysvinit support
- Fix milkv-duo support in meta-riscv
- Update recipes in multiple layers for UNPACKDIR migration
- Update recipes to move away from S = WORKDIR assignments
- Introduce GO_SRCURI_DESTSUFFIX for go based recipes
- update Simple IoT to v0.16.0
- default
IMG_VERSION to Yoe release: 2024.04 → 24.04.x
- add
ca-certificates to yoe-simple-image
- Upgrade valgrind to 3.23.0
- Upgrade QT6 to 6.7.2
- Upgrade vulkan SDK to 1.3.283.0
- Upgrade spirv-llvm-translator 18.1.0
- Fix renaming of network interfaces on rpi projects using systemd
- Upgrade go to 1.22.3
Added
- Introduce UNPACKDIR bitbake variable
- New recipes
- glib-testing, opentelemetry-cpp, malcontent
python3-dasbus
Removed
- Removed recipes
- orrery, libtirpc126, usbinit, libomxil
- Drop using LLVMVERSION
- Drop unused 5.15 linux-raspberrypi version
khem
39
2024.06 - “Pagliarola”
Latest
Compare
github-actions released this 14 hours ago
2024.06
38167c5
[2024.06] - 2024-06-30
Changed
- Fix libclc build
- Bump fsl kernel to 6.6.32
- Disable -Wincompatible-pointer-types as error in few recipes
- Upgrade libcamera to 0.3.0
- Adjust several recipes to build with libtool 2.5
- Update linux-yocto/6.6 v6.6.32
- Upgrade QEMU to 9.0.0
- Upgrade OpenSSL to 3.3.1
- Update wayland to 1.23.0
- Bump QT to 6.7.3
- Fix kernel build for Jetson orin-nano
- Update clang to 18.1.8 release
- Upgrade libgpiod-1.x to 1.6.5 and fix build with musl
- Upgrade fwupd-efi to 1.6 and move py-pefile to meta-oe
- Allow using LLVM libc++ with GCC compiler
- Move fmt package from meta-oe → core layer
- Fix libstdc++ unicode header typo regression found with clang
- Update rpidistro-ffmpeg to 5.1.4
- Fix contains reference to TMPDIR [buildpaths] warning in several recipes
- Upgrade PHP to 8.2.20
- Upgrade go compiler to 1.22.4
- Add PACKAGECONFIG for bpf-framework to systemd
Added
- Added new recipes for - sexpect, trompeloeil, cabextract
udpcast, python3-typer, magic-enum
- Add ptests support for python3-dasbus, python3-flask
- Add support for BeagleV-Ahead SBC
- Add support for jetson-agx-orin-devkit
Removed
- remove g77/f77
- drop the old 1.4 bootstrap C version for go compiler
khem
40
2024.07 - “Qinghai”
Latest
Compare
github-actions released this 5 hours ago
2024.07
99efec8
[2024.07] - 2024-07-30
Changed
- Fix several packages to build with clang fortify and glibc 2.40
- Add ptest support for unbound
- Stop overriding unprefixed *FLAGS variables for native and nativesdk
- Update linux-yocto/6.6 to v6.6.35
- Use objdump instead of readelf to compute SONAME during image generation
- Adjust metadata to remove True option in getVar calls
- Fix exceptions with -mbranch-protection on ARM64/Libc++
- Enable build-id for systems built with clang compiler
- Upgrade QEMU to 9.0.1
- Update MACHINE in jetson-agx-orin-devkit
- Always use lld linker with clang for qt6 recipes
- Ignore various issues fatal with gcc-14
- Upgrade linux-raspberrypi to 6.6.36
- Pin runtime type to GCC runtime in cuda-gcc and define TOOLCHAIN variable
- Upgrade Go compiler to 1.22.5
- Upgrade systemd to v256
- Upgrade util-linux to 2.40.1
- Enforce default remote name to “origin” in git fetcher
- Enable GTK in OpenCV with wayland as well
- Switch Jetson platforms to use Yoe distro with wayland instead of EGLFS
- Update blueZ to 5.77
- Upgrade GDB to 15.1
- Enable kprobes in tegra kernel
- Add python3-cuda to tegra based images
- Do not manage wifi with systemd-networkmanager
- Disable audit subsystem in kernel for tegra platforms
- Add networkmanager and wireguard to all yoe images
- Fix busybox/tc compilation with 6.9 linux kernel headers
- Fix buildpaths QA error checks in several meta-oe recipes
- Fix several recipes in meta-oe for correct UPSTREAM_CHECK vars
- Update OpenSSH to 9.8p1
- Upgrade to glibc 2.40
Added
- Added new recipes - libabigail, include-what-you-use, dediprog-flasher
- Added DEBUG_LEVELFLAG variable to contain default debug level e.g. -g1, -g, etc.
- Add packageconfig knob to control tegra gallium driver in mesa
- Add nospdx class
- Add and switch default SPDX version to 3.0
- Add meta-tegra-community layer
Removed
- Drop generating a static libpython
- Remove /etc/ethertypes in iptables
- Drop obsolete debug compiler option -feliminate-unused-debug-types
- Drop deprecated configs from android-driver.cfg for rpi kernel
khem
41
2024.08 - “Rabo Largo”
Latest
Compare
2024.08
7e0dc54
[2024.08] - 2024-08-31
Changed
- Fix native builds for sanitizer version of compiler-rt
- Upgrade linux-yocto 6.6 to 6.6.45
- Update linux-kernel-headers to 6.10
- Update linux-yocto/6.10 6.10.3
- Fix clang compiled apps reproducibility issue w.r.t. clang version
- Switch several python recipes to use PEP-517 build backend
- Fix buildpaths build QA error in several recipes
- Add UPSTREAM_CHECK_COMMITS to meta-openembedded recipes
- Upgrade go to 1.22.6
- Upgrade rust to 1.79.0
- Upgrade GCC to 14.2
- Upgrade binutils to 2.43
- Set CVE_PRODUCT in several recipes
- Use imx-boot from NXP 6.6.23-2.0.0 BSP
- Pin weston to 12.0.4.imx for IMX
- Upgrade systemd to 256.5
- Upgrade rust to 1.78
- Fix reproducibility issues in several meta-openembedded recipes
- Set umask to 0022 on build directories on bitbake invocation
- Upgrade binutils to 2.43.1
- Fix QT 6.7 builds with Clang-19
- Upgrade libxml2 to 2.13.3 and address ABI breakges due to it in meta-oe
- Fix several multimedia recipes to work with ffmpeg 7
- Fix recipes to work with fmt 11.x
- Correct LICENSE field of several recipes in meta-python
- Upgrade musl to latest on trunk 1.2.5+
- Upgrade automate to 1.17
- Add swupdate OTA support on tegra platforms
Added
- Introduce 6.10 reference kernel
- Added vex class for CVE management
- Added recipes:
- drgn, vdpauinfo, python3-psycopg, libplacebo, cpuset
Removed
- Removed VOLATILE_TMP_DIR and VOLATILE_LOG_DIR bitbake variables
