khem
35
2024.02 - βLatiβ Latest
[2024.02] - 2024-02-29
Changed
- Update linux-raspberrypi to 6.1.74
- Fix VisionFive2 u-boot and linux kernel builds with GCC-14
- Fix support for large rootfs on tegra platforms
- Fix several packages to build with GCC-14 and clang-18
- Upgrade linux-yocto-dev to 6.8+
- Avoid using -march when -mcpu is chosen for armv8/armv9 architectures
- Update Golang to 1.20.13
- Update pseudo to pull in gcc14 fix and missing statvfs64 intercept
- Upgrade OpenSSL to 3.2.1
- Upgrade glibc to 2.39
- Upgrade binutils to 2.42
- Upgrade linux-yocto to v6.6.18
- Improve running default image ptests on RISCV
- Upgrade opkg to 0.6.3
- Fix build race in xfstests
- Fix compiler-rt sanitizers build
- Make clangd compilation optional
- Update LLVM to 18 RC2
- Upgrade openSSH to 9.6p1
- Update mesa to 24.x release
- Upgrade valgrind to 3.22.0
- Fix various python pieces to work with python 3.12
- Update layers for scarthgap release to be series compatible
- Switch meta-python repcipes to use pytest --automake enmass
- Upgrade linux-raspberrypi to 6.1.77
- Enable RTC in RISCV qemu kernel configs
- Fix yocto compatible status for meta-clang
- Fix dav1d build on RISCV
- Improve vscode IDE support
- Add images to enable BBCLASSEXTEND parallel execution for
meta-networking, meta-multimedia, meta-filesystems layers
Added
- New packages - python3-moteus, python3-google-auth-oauthlib, python3-janus
flatcc, python3-aiohappyeyeballs, bonnie++. e2tools, python3-strenum
python3-httpx, python3-httpcore, python3-sniffio, python3-anyio
python3-socksio, python3-pyyaml-include, whitenoise, wavemon, libdaq, snort3
sdmon, python3-looseversion
- Add cortexa78 tune files
Removed
- Remove meta-elm-binary layer, its not needed anymore for simpleIOT
- Delete LLVMVERSION
- drop using PYTHON_PN variable
- Removed recipes - libencode-locale-perl, libencode-perl
