2023.12 - “Jezerskosolflorinavska”
Compare
github-actions released this 3 days ago
release-notes-from-changelog
GitHub action that extracts release notes from an existing changelog.
Changes in this version:
[2023.12] - 2023-12-30
Changed
- Fix mesa-gl conflict with mali-g31 driver KHR/khrplatform.h header
- Enable utmp support in busybox on musl systems
- Support qemu for cmake via cmake-qemu.bbclass
- Update clang to 17.0.6
- Disable lld for x32 ABI, it does not have support
- Upgrade autoconf to 2.72d
- Unset CMAKE_CXX_IMPLICIT_INCLUDE_DIRECTORIES in cmake
- Upgrade rust to 1.71.1
- Update go compiler to 1.20.12
- Update linux-yocto versions to v6.1.68, v6.5.13
- Prepate several recipes for working with python 3.12
- Fix meta-tegra to build with musl
- Use clang to compile openSSH again
- Fix build issues in bpftrace ptests
- Add ptests for c-ares
- Switch to 6.1 kernel for linux-starfive from 3.9.3 SDK
- Ensure features don’t get backfilled for nativesdk
- Switch to using zstd compression in core layer
- Update gdb to 14.1 release
- Fix several packages to use right basename POSIX or GNU option
Added
- Added recipes - monocypher, xorg-docs, xcursor-themes
python3-maturin, cyaml, pkcs11-provider - Devtool now supports git submodules for SRC_URI
- Add python recipe writing support to recipetool
- Add python maturin support
- Add project for jetson-orin-nano with NVME boot media
Removed
- Removed recipes - vte9, systemtap-uprobes
- Remove unused SRC_DISTRIBUTE_LICENSES variable
- Drop removed IMA option from linux-yocto
