2023.06 - “daglic”
Compare
Edit: 2023.06 - “daglic”
Delete: 2023.06 - “daglic”
 github-actions released this 44 minutes ago
release-notes-from-changelog
GitHub action that extracts release notes from an existing changelog.
Changes in this version:
[2023.06] - 2023-06-30
Changed
- Add missing run-time dependencies in several python recipes
 - Stop using PYTHON_PN in several python recipes
 - Add 44.2 gnome recipes
 - Fix REQUIRED_DISTRO_FEATURES gobject-introspection-data in several recipes
 - Upgrade linux-yocto/6.1 to v6.1.35
 - Document SPLASH_IMAGES variable
 - Do not search host paths for find_program() in cmake.bbclass
 - Don’t force PAHOLE=false in linux-yocto
 - Upgrade OpenSSL 3.1.1
 - Enable fullscreen and disable startup-msg in psplash
 - Fix spdx license parsing
 - Make built-in libtraceevent plugins from perf cohabit with external libtraceevent
 - Fix vulkan-samples build on 32-bit platforms
 - Make OpenSBI FW_TEXT_START=0x40000000 specific to jh7110
 - Use python3 in oe-stylize
 - Upgrade wireshark to 4.0.x
 - remove -fcanon-prefix-map in scp-firmware recipe
 - Use IMAGE_LINK_NAME in updater and yoe-initramfs-image
 - Upgrade gstreamer1.0 to 1.22.3
 - Update rust to 1.70.0
 - Switch meta-qt6 to 6.5 branch instead of 6.5.1 point release branch
 - Update clang to 16.0.6 tag
 - Fix enabling lld as distro linker in clang.bbclass
 - Upgrade go compiler to 1.20.5
 - Fix recipes to build issues found using lld linker
 - Drop setting ARM_INSTRUCTION_SET explicitly, it can build in thumb mode
and upgrade to 8.2.7 - Use BFD linker for libgcc and glibc explicitly
 - Replace Yocto .h by .png splashscreen in psplash
 - Add weston user to wayland and render groups
 - Upgrade libubootenv to 0.3.4
 - Fix several recipes to link with LLD linker
 - Use llvm-strip system-wide for STRIP utility for RISCV targets
 - Fix ntpd systemd service type forking → simple
 - Fix OpenSBI build for visionfive2 SBC
 - Upgrade GDB to 13.2
 - Drop using tunctl in runqemu/qemu-helper
 - Upgrade python to 3.11.3
 - Upgrade mesa to 23.1.1
 - Fix gn to build with gcc-13
 - Backport fix for linking failures using LLD linker for RISCV
 - Migrate to use markdown format for READMEs in meta-openembedded
 - Fix vpu and pvr-graphics build and packaging issues on visionfive2
 - Bump LLVM in core layer to 16.0.6
 - Fix several recipes to build when LLD is default distro linker
 - Add Upstream-Status tags to meta-openembedded, meta-rpi, meta-odroid
meta-freescale, meta-clang and meta-yoe layers - Add support for mbedTLS v3.x
 - Bump QT6 packages to 6.5.3
 - Fix weston booting issues on visionfive2 SBC and update to use
StarFive SDK v3.0.4 components - Improve patch-status layer filtering in insane.bbclass QA checks
 - Update rpi kernel to 6.1.34
 - Enable glx/opengl support in gstreamer1.0-plugins-base
 - Update python3 to 3.11.4
Added
- Added recipes - python3-ninja-syntax, python3-lazy, python3-classes
python3-pypng, stopit, vulkan-validation-layers, python3-meson-python - Add support for loongarch64 to initramfs
 - Add QT6 layer and enable it for var-som-mx8
 - Add LGPL-3.0-with-zeromq-exception to common-licenses
 - Add python_mesonpy class
 - Add new project for VisionFive2
 - Add support for Variscite VAR-SOM-MX8M-NANO
 - Add layer- override support
 - Enable largefile and 64bit time_t support systemwide for 32 bit platforms
Removed
- Removed recipes - u-boot-bb.org
 - Drop QT5 layer
