VDO.Ninja -- a great way to do video calls and record podcasts
How to test your VDO.Ninja setup
In preparation for a meeting or podcast recording, it is a good idea to test your setup before the meeting. A modern Chromium-based browser is recommended, and you will likely need to give the browser permission to use your audio and camera. A headset and quality microphone is also recommended.
Test with the following steps:
  1. Go to https://vdo.ninja/ and select “Create a Room”
  2. Click on the image button to generate a new room name.
  3. Click “Join the room as a Participant”.
  4. Join Room with Camera.
  5. Select your Video, Audio devices. Make sure the audio is directed to a headset, and the correct Mic is selected. If you select a computer microphone instead of a headset, the audio may be substandard.
  6. Click start. Your video should display.
  7. Click the settings button.
  8. Verify when you speak, the green audio level bar is moving.
  9. Click the Audio Output Test button, and verify you hear the test sound.
