Bubblewrap sandbox
I’ve been experimenting with a bubblewrap sandbox so I can run claude with --dangerously-skip-permissions. It seems Docker is overkill for sandboxing. Using all binaries/tools from a Docker container is helpful, but it seems you still need to cache a lot of stuff for various build environments.
There are a lot of security issues to work through, but here is the current draft:
#!/usr/bin/env bash
# cld — run `claude` inside a bubblewrap sandbox with
# --dangerously-skip-permissions. The sandbox exposes:
# RO: narrow allowlist of /etc files, /usr, /opt,
# ~/.gitconfig, ~/.local/bin, ~/.local/share/claude,
# ~/.claude/{CLAUDE.md,settings.json,skills,
# commands,plugins,.credentials.json}, ~/go/bin
# RW: $PWD (current working dir), the rest of ~/.claude,
# ~/.npm, ~/.cache/go-build, ~/go (minus bin)
# RW-ephemeral: ~/.claude.json is bound to a per-session tmp copy seeded
# from the real file; writes are discarded on exit so a compromised
# session cannot persist config (MCP servers, apiKeyHelper, trusted
# dirs, ...) that would execute on the next claude run.
# Net: shared with host (DNS via /etc/resolv.conf, CAs via /etc/ssl)
# Env: --clearenv + explicit allowlist. Host env vars (API keys,
# cloud creds, GITHUB_TOKEN, ...) do NOT leak into the sandbox.
# All other home files (ssh keys, other repos, dotfiles) are hidden
# behind a tmpfs.
# Residual risks (things this sandbox does NOT protect against):
# 1. Network exfiltration. --share-net is intentional so claude can
# reach the API, but it also means any readable data inside — source
# in $PWD, ~/go source/modules, and especially OAuth tokens in
# ~/.claude/.credentials.json (which claude must be able to read) —
# can be POSTed to an attacker-controlled host by a prompt-injected
# session. There is no egress filter.
# 2. Localhost SSRF. --share-net keeps the host's loopback interface,
# so anything listening on 127.0.0.1 on the host (databases, dev
# servers with auth disabled, metadata services on cloud VMs at
# 169.254.169.254, other sockets bound to lo) is reachable from
# inside the sandbox.
# 3. Git-hook persistence via $PWD. The project dir is bound RW, which
# includes .git/. A compromised session can write .git/hooks/post-*
# (or tamper with .git/config's core.hooksPath) so that the next
# git command you run *outside* the sandbox executes attacker code
# with your full user privileges.
# 4. Build/cache poisoning. ~/.npm, ~/.cache/go-build, and ~/go (minus
# bin) are all RW. Malicious packages dropped into the npm cache or
# tampered sources under ~/go/src / ~/go/pkg/mod will be picked up
# by future host-side `npm install` / `go build` runs.
# 5. Claude-side persistence via non-RO paths in ~/.claude. Only
# CLAUDE.md, settings.json, .credentials.json, skills/, commands/,
# and plugins/ are RO-overlaid; the rest of ~/.claude is RW. A
# compromised session can:
# - create or modify ~/.claude/settings.local.json to inject
# hooks that execute on the NEXT `claude` run outside the
# sandbox (the ephemeral .claude.json only closes the
# .claude.json path, not this one),
# - tamper with session transcripts / todos / shell-snapshots
# under ~/.claude/projects/ etc. to mislead future sessions.
# Consider adding settings.local.json to the RO-bind list if you
# ever create one.
# 6. In-sandbox process tampering. claude and any tools it runs share
# a PID namespace inside the sandbox, so a prompt-injected session
# can ptrace / signal / replace binaries reachable via its writable
# mounts. The host is protected by the namespace boundary, but
# nothing inside the sandbox is trusted relative to itself.
# What IS defended:
# - SSH keys, GPG keys, other repos, and unrelated dotfiles are hidden
# behind a tmpfs over $HOME.
# - Host env vars (API keys, AWS_*, GITHUB_TOKEN, ...) are dropped by
# --clearenv; only an explicit allowlist passes through.
# - ~/.claude.json writes are ephemeral, so a compromised session
# cannot persist MCP servers / apiKeyHelper / trusted dirs for the
# next run via that file.
# - ~/.local/bin and ~/go/bin are RO, so installed binaries cannot be
# swapped from inside.
# - --unshare-all (minus net) isolates PID/IPC/UTS/cgroup/user ns;
# --new-session blocks TIOCSTI terminal injection; --die-with-parent
# ensures the sandbox exits with the launcher.
# Usage: cld [claude args...]
# Must be invoked from inside the project directory you want claude
# to touch; that directory is bound RW into the sandbox.
set -euo pipefail
if ! command -v bwrap >/dev/null 2>&1; then
echo "cld: bubblewrap (bwrap) is not installed" >&2
exit 1
fi
if ! command -v claude >/dev/null 2>&1; then
echo "cld: 'claude' not found in PATH" >&2
exit 1
fi
cwd=$PWD
# Refuse to run at $HOME itself — binding $HOME RW would defeat the sandbox.
if [[ "$cwd" == "$HOME" ]]; then
echo "cld: refusing to run with CWD == HOME (would expose entire home dir)." >&2
echo " cd into a project subdirectory first." >&2
exit 1
fi
# Make sure RW bind targets exist so bind doesn't fail / silently create empties.
mkdir -p \
"$HOME/.claude" \
"$HOME/.npm" \
"$HOME/.cache/go-build" \
"$HOME/go/bin"
# Ephemeral ~/.claude.json: seed from the real file so onboarding/tips/
# recent-projects state carries in, but discard writes on exit.
claude_json_ephemeral=$(mktemp --tmpdir cld-claude-json.XXXXXX)
trap 'rm -f "$claude_json_ephemeral"' EXIT
if [[ -f "$HOME/.claude.json" ]]; then
cp "$HOME/.claude.json" "$claude_json_ephemeral"
fi
# Env var allowlist. Only these pass into the sandbox; everything else
# (API keys, AWS_*, GITHUB_TOKEN, etc.) is dropped by --clearenv.
env_args=(--setenv SANDBOX cld)
for v in HOME USER LOGNAME SHELL PATH TERM COLORTERM NO_COLOR \
LANG LC_ALL TZ \
EDITOR VISUAL PAGER \
HTTP_PROXY HTTPS_PROXY NO_PROXY ALL_PROXY \
http_proxy https_proxy no_proxy all_proxy; do
if [[ -n "${!v-}" ]]; then
env_args+=(--setenv "$v" "${!v}")
fi
done
# Narrow /etc allowlist (instead of binding /etc wholesale).
# Add files here if a tool inside the sandbox complains it can't find them.
etc_args=()
for f in \
/etc/resolv.conf \
/etc/hosts \
/etc/nsswitch.conf \
/etc/passwd \
/etc/group \
/etc/ssl \
/etc/ca-certificates \
/etc/pki \
/etc/localtime \
/etc/gitconfig \
/etc/ld.so.cache \
/etc/ld.so.conf \
/etc/ld.so.conf.d \
/etc/os-release \
/etc/profile \
/etc/bash.bashrc \
/etc/shells \
/etc/mime.types; do
etc_args+=(--ro-bind-try "$f" "$f")
done
bwrap \
--unshare-all --share-net \
--die-with-parent \
--new-session \
--clearenv \
--hostname cld-sandbox \
--ro-bind /usr /usr \
--ro-bind-try /opt /opt \
"${etc_args[@]}" \
--symlink usr/bin /bin \
--symlink usr/bin /sbin \
--symlink usr/lib /lib \
--symlink usr/lib /lib64 \
--proc /proc \
--dev /dev \
--tmpfs /tmp \
--tmpfs /var/tmp \
--tmpfs /run \
--tmpfs "$HOME" \
--bind "$HOME/.claude" "$HOME/.claude" \
--ro-bind-try "$HOME/.claude/CLAUDE.md" "$HOME/.claude/CLAUDE.md" \
--ro-bind-try "$HOME/.claude/settings.json" "$HOME/.claude/settings.json" \
--ro-bind-try "$HOME/.claude/.credentials.json" "$HOME/.claude/.credentials.json" \
--ro-bind-try "$HOME/.claude/skills" "$HOME/.claude/skills" \
--ro-bind-try "$HOME/.claude/commands" "$HOME/.claude/commands" \
--ro-bind-try "$HOME/.claude/plugins" "$HOME/.claude/plugins" \
--bind "$claude_json_ephemeral" "$HOME/.claude.json" \
--bind "$HOME/.npm" "$HOME/.npm" \
--bind "$HOME/.cache/go-build" "$HOME/.cache/go-build" \
--bind "$HOME/go" "$HOME/go" \
--ro-bind "$HOME/go/bin" "$HOME/go/bin" \
--ro-bind-try "$HOME/.gitconfig" "$HOME/.gitconfig" \
--ro-bind-try "$HOME/.local/bin" "$HOME/.local/bin" \
--ro-bind-try "$HOME/.local/share/claude" "$HOME/.local/share/claude" \
--bind "$cwd" "$cwd" \
--chdir "$cwd" \
"${env_args[@]}" \
claude --dangerously-skip-permissions "$@"
