Zephyr notes
We recently started looking at Zephyr for a STM32H7 based system. We have been using the ST32CubeIDE + FreeRTOS, a fairly obvious choice as it is built into the mainstream ST tools/IDE. Some notes on this stack:
  • easy to get started with a graphical tool to configure the chip
  • generate a lot of code, and again, easy to get started.
  • FreeRTOS integration is decent, but not tight with the STM32 SDK
  • Using third-party stacks like TinyUSB and LWIP are common, but the integration is not trivial.
  • the ST Cube generates a lot of XML which is not really human readable and difficult to store in Git if multiple people are making changes at the same time.
Zephyr is not heavily promoted on the ST website, but it is listed in their embedded software solutions document.
I have heard about Zephyr, so we recently decided to give it a try. In a day, one of the project engineers had Zephyr running on our custom hardware. In another couple of days, the Ethernet and HS USB were working.
Notes on Zephyr so far:
  • a tool command-line tool named west is used to set up a build, manage repos, flashing, etc.
  • It is a lot like Linux – everything is well integrated.
  • uses the KConfig build configuration system. This is nice as it allows very granular configuration of what is included in the build.
  • Device Tree is used to configure drivers. As some say, Zephyr porting to new hardware is 80% configuration, 20% code. It sometimes takes some work to figure out what config entries you need, but overall the process seems pretty nice. A declarative configuration like DTS forces a nice clean separation of code and configuration
  • Zephyr configuration is human-readable and very easy to store in Git, even with multiple developers making changes.
  • CMake/Ninja is used to build
  • ST Link automatically works for west flash
  • Zephyr HAL layers are in separate repos, but they are in the Zephyr github space and seem to follow very consistent guidelines (Issues are tracked in the main Zephyr repo, etc).
  • Zephyr provides a lot – ztest, zbus, etc.
The big difference I see between Zephyr and other solutions like FreeRTOS is that Zephyr takes responsibility for integrating the entire solution, instead of developing the core, washing their hands, and handing it off to chip vendors/users to do the integration. If a Chip vendor wants to play in the Zephyr space, then their hal layer is provided in the Zephyr github space and there is support in the main Zephyr west.yml for it.
As MCUs get more complex, it seems like something like Zephyr is needed to tame this complexity.
Zephyr has a really nice shell – tab completion works nicely. Most subsystems (network, i2c, etc) have shell config options. Additionally, most driver subsystems have debug levels so you can turn up the debugging levels just on that subsystem if there are problems.
zephyr build system generates build/compile_commands.json, which is used by the clangd language server. Seems to be working in neovim.
There are also .editorconfig and .clang-format files in the repo – well done!
this is powerful and more modern. I wonder if it can build with clang as compiler as well if it can then we have an inherent cross compiler on system and can simplify toolchain requirements.
I’ve been curious about the west build tool used in Zephyr. This page has the rationale for creating the tool and compares it to Git submodules and Repo:
https://docs.zephyrproject.org/latest/develop/west/why.html
Overall, I’m a little skeptical of inventing new tools to do superproject management, but in this case, it seems to make sense.
Comparison of development activity of various RTOS projects. It appears that Zephyr has one to two orders of magnitude more development activity than other projects. Part of the difference is likely that Zephyr is more than just a kernel and includes many drivers for i2c/SPI chips, MCUs peripherals, etc. Traditionally, MCU vendors would likely do some of this driver work internally and then package it with a RTOS kernel. The Zephyr model is completely different.
Note, these metrics are not perfect and likely don’t reflect everything that is going on, but give us some idea.
Zephyr
community-owned, managed by the Linux Foundation
License: Apache-2.0
(1,622 contributors)
FreeRTOS:
owned by Amazon
License: MIT
kernel (123 contributors):
TCP Library (56 contributors):
ThreadX
License: Microsoft
owned by Azure
(11 contributors)
Micrium/uC-OS
owned by SiLabs
License: Apache-2.0
uC-OS3 (7 contributors)
uC-OS2 (3 contributors)
uC-USBD (6 contributors)
uC-TCP-IP (4 contributors)
There are several other repos – the development level is likely similar …
I’ve been wondering how easy it will be to maintain old Zephyr projects – will current versions of West work with old versions of Zephyr? It is supposed to work:
Now arduino switches to Zephyr, another feather in its cap.
I think my prediction is coming true. “Zephyr is to RTOSes what Linux is/was to General purpose OSes and RISC-V is to ISAs”,
If this holds true, we might not see whole world using them but there wont be new ISAs or new RTOSes or OS kernels, as they have taken that mantle.
Math in DTS files
Learned you can do math in DTS files:
<&gpio1 (36 - 32) (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
In this example, we are using GPIO 36, which is in the second bank of GPIOS (gpio1).
Example of how Zephyr recognizes contributors
While the following is automated and in reality does not mean much compared to a personal note, it is still a nice touch.
In the Zephyr weekly newsletter, new contributors are also recognized:
An example of Zephyr custom workflow tooling
I’m not sure exactly what the following is used for, but it is always a good sign when projects are building tooling exactly for their needs on top of existing tooling. This is not reinventing the wheel or NIH (not-invented-here syndrome), but supplemental tooling.
https://merge-list.zephyrproject.io/
Zephyr RTOS gains Armv9-A enablement
