khem
10
2022.02 - “Navajo-Churro”
[2022.02] - 2022-02-28
Changed
- Upgrade simpleiot to 0.0.42
- Enable network during compile/configure step of simpleiot
- Build kernel with initramfs for sifive/unmatched
- Use renamed terms for variables for inclusive language changes
- BB_ENV_PASSTHROUGH_ADDITIONS
- LICENSE_FLAGS_ACCEPTED
- SKIP_RECIPE
- CVE_CHECK_IGNORE
- LICENSE_EXCLUSION
- Use yocto URL for testing CONNECTIVITY_CHECK_URIS
- Switch to kirkstone ( yocto 3.5 ) codename across layers
- Only allow network access in do_fetch tasks
- Cleanup use of distutils in oe-core, replace with setuptools
- linux-yocto updated to v5.10.99, v5.15.22
- Update busybox to 1.35 release
- Enable threading in perl
- Update various gnome recipes to 41.1 release
- Upgrade strace to 5.16
- Switch raspberrypi4-64 to cortexa72 tune
- Upgrade ffmpeg to 5.0
- Upgrade meson to 0.61.1 and fix packages to build with this version
- Update PHP to 8.1.3
- Upgrade gstreamer to 1.20.0
- Use arm BSPs to use linux-yocto 5.15
- Update clang to 14.0.0-rc1
- Use LLVM binutils by default e.g. nm, strip, objcopy, objdump etc.
- Set precise BSD license in various recipes
- Upgrade glibc to 2.35
- Upgrade binutils to 2.38 release
- Upgrade gdb to 11.2
- Upgrade go to 1.17.7
- Upgrade musl to tip of master/f8bdc3048216f41eaaf655524fa286cfb1184a70
- Upgrade weston to 10.0.0
- Disable sse4.1 and sse4.2 in openCV on x86
- Upgrade linux-firmware to 20220209
- Bump bitbake version to 1.53.1
- Use 5.15 as default kernel for RPI machines
- Add support for gtkmm4
- Disable optimizations for libvorbis,x264,dcadec,graphviz on mips to avoid clang bug
- Migrate many python recipes to use wheels packaging format
- Upgrade ruby to 3.1.1
- Move distutils bbclasses to meta-python
Added
- Add example to generate username/password in image and local.conf
- Add recipe for python3-gammu, duktape, python3-picamera, seatd
googlebenchmark, python3-pytest-xdist, python3-pytest-xdist
python3-pytest-qt
- Introduce cortexa73-crypto tune
- Add the support for the Neoverse N2 core
- Add tune include for armv8.5a
- Add setuptoools Rust plugin
- Add class for PyO3 cross-compilation
- Add crate fetcher in bitbake
- Add recipe for 5.15 LTS linux-raspberrypi kernel
Removed
- Prelinker support
- Drop the redundant cortexa72-crc tune
- Remove recipes for mailx, libjs-jquery, python3-anyjson, python3-nose
- Remove libsegfault and catchsegv
- Remove bogus CMAKE_LDFLAGS_FLAGS definition from cmake toolchain file
khem
11
Repository: YoeDistro/yoe-distro · Tag: 2022.03 · Commit: baeae56 · Released by: github-actions[bot]
release-notes-from-changelog
GitHub action that extracts release notes from an existing changelog.
Changes in this version:
[2022.03] - 2022-03-30
Changed
- Fix multilib support in clang based toolchain
- Improve llvm-config detection logic in cross builds
- Enable llvm runtime for ppc32
- Disable altivec intructions when using clang on qemuppc
- Fix python module recipes to support PEP-517 packaging
- Update nodejs to 16.14.0 LTS
- Fix gyp to work with python 3.10+
- Upgrade linux-raspberrypi 5.15 to 5.15.30
- Bump riscv linux-mainline to 5.17
- Update linux-yocto to v5.10.107, v5.15.30
- Update SRC_URIs for brcm firmware in meta-riscv
- Show warning for obsolete license usage
- Improve deterministic builds for perl, quilt, and cups
- Upgrade SQlite3 to 3.38.0
- Replace non-SPDX license identifiers in OE-core
- Use SPDX license identifiers in recipetool
- Enable networking in all icecc tasks
- Rework INCOMPATIBLE_LICENSE wildcard and variable handling
- Improve ssh fetcher to support path handling
- Use SPDX license identifiers in all meta-openembedded layers and meta-intel
- Fix recipes in meta-openembedded needing legacy setuptools support
- Reduce default dependencies for native sysroot, drop libarchive and util-linux
- Drop opt-1 and opt-2 pyc files in native python to reduce number of files
- Fix build race in binutils/assembler docs
- Improve eSDK layer path assumptions to support more layouts
- Enable systemtap for RISCV64
- Use SPDX license naming convention in meta-clang, meta-odroid, meta-riscv
- Enable riscv64 builds for bcc,libbpf
- Remove depenendency for virtual/libgl where possible, use virtual/egl
- Fix recipes to build without X11 in distro features
- Improve PYPA_WHEEL detection for wheel packaging and cleanup pip_install_wheel
- Upgrade go to 1.17.8
- Upgrade rust to 1.59.0
- Update cmake to 3.22.3
- Add AGPL-3.0 wildcard to expand_wildcard_licenses
- Upgrade QT5 to v5.15.3-lts-lgpl
- Improve pip_install_wheel to not need PIP_INSTALL_DIST_PATH and PYPA_WHEEL
- Bitbake fixes for toaster support
- Fix several recipes for ppc64 builds
- Upgrade gstreamer to 1.20.1
- Fix global ppc/ppc64 sitefiles for musl and glibc differences
- Bump bitbake to 2.0.0
- Fix more recipes to use branch and protocol parameters in github SRC_URI
- Move petry python packaging infrastructure from meta-python to core layer
- Fix qemuppc64 recipes and booting with 5.15 kernel
- Adjust recipes for renaming flit_core → python_flit_core
- Fix rust packages to build for riscv32 and musl
- Update systemd to 250.4
- Fix several recipes to build when LIBDIR != lib by default, fixes ppc64
- Convert virtual/libgl to virtual/egl dependencies where possible
- Upgrade libtool to 2.4.7, needed few recipes to re-generate macros
- Update musl to latest master
- Fix rust toolchain for SDK environment
- Fix weston 10.x build for TI socs using sgx driver
- Add GLES3/GL headers to SGX DDK
Added
- Add poetry_core helper class for supporting poetry for python packages
- Add snapshot checksums for powerpc64le hosts
- Add support to build on FIPS enabled build hosts
- Added setuptools3_legacy bbclass to keep pre PEP-517 behavior
- Add nativesdk support to cargo and rust compiler tools
- Add Dockerfile in bitbake repo for building PR service
- Add MOUNT_COPYBIND_AVOID_OVERLAYFS env var to skip OverlayFS
- New recipes
- hstr, python3-qface, python3-path, python3-antlr4-runtime
- python3-crc32c, gosu,
Removed
- Drop AVAILABLE_LICENSES variable
- Remove the available_licenses() function from license.bbclass
khem
12
Latest
github-actions released this 5 hours ago
2022.04
dac745d
[2022.04] - 2022-05-01
Changed
- Use clang for python3 compilation and many other recipes
- Use internal version fo ffmpeg for omxplayer
- Update linux-rapberrypi to 5.15.34
- Add ability to specify CPUs to add to the isolcpus list for rpi-cmdline
- Upgrade uninative to 3.6 with gcc 12 support
- Upgrade linux-yocto/5.15 to v5.15.36, linux-yocto/5.10 to v5.10.112
- Fix gcc thread sanitizer against glibc 2.34
- Update python3 to 3.10.4
- Update tzdata to 2022a
- Fix specific version handling for ipk and deb package types
- Upgrade gtk4 to 4.6.2
- Various python module recipe upgrades
- Gnome and XFCE recipe upgrades
- Enable usrmerge feature distro wide
- Switch default docker build to use bullseye/debian-11
- Enable overlayfs to mount r/w parition on rootfs
- Bump simpleiot to 0.0.45
- Enable persistent logs across reboots
- Build own bmaptool-native and remove depending on build host for it
- Assorted recipe major version upgrade
- Allow auto detection of the correct graphics options in runqemu
- Use https with github for SRC_URIs in meta-riscv
- Fix several recipes to compile with GCC-12
- Upgrade Go compiler to 1.18
- Upgrade OpenSSH to 9.0p1
- Fix nativsdk builds for LLVM runtime
- Fix several recipes to buils on ppc/ppc64 with clang
- Fix several recipes to build properly with usrmerge distro feature
- Upgrade GCC to 11.3 release
- Fix several recipes to build with out X11
- Upgrade glibc to latest bugfixes on 2.35 release
- Upgrade rust compiler to 1.60
- Upgrade Clang to 14.0.3
- Enable xz compression in kmod
- Switch linux-raspberrypi to have compressed kernel modules
Added
- Add recipes for OpenThread
- Add recipes for idevicerestore, libadwaita, frr
- Add support for nezha-allwinner-d1 machine
- Add os-release-initrd package
- add UBOOT_ENTRYPOINT to match LOADADDR in linux-raspberrypi
- Add MCP3008 ADC overlay for RPI machines
- Add tune include for armv8.4a
- Add tunes for rv64 without compressed instructions
- Introduce git intercept script due to fakeroot issues in devshell
- Add recipe for musl-locales
Removed
- Drop meta-96boards layer, its unused
- Remove recipes for rpi-hwup-image and rpi-basic-image
- Drop GOBUILDMODE
- Remove invalid GLIBC_EXTRA_OECONF for ppc32
khem
13
2022.05 - “Qashqai”
Latest
github-actions released this 2 days ago
2022.05
0f34c2d
[2022.05] - 2022-05-31
Changed
- Update meta-ti recipes to SDK 08.02.00.005
- Let the user drive the update interval for CVE database
- Correctly handle file names containing colons in bitbake
- Fix firmware autoloading for rpi by creating
brcmfmac43455-sdio.raspberrypi,4-model-b.bin symlink
- Update qemu to 7.0.0
= Upgrade musl to tip of trunk
- Upgrade 250.5
- Use arm-versatile-926ejs KMACHINE for qemuarmv5
- Make git intercept global
- Upgrade GCC to 12.1
- Add openssh-sftp-server to openssh RDEPENDS
- Upgrade linux-firmware to 20220509
- Upgrade linux-raspberrypi to 5.15.38
- Various native recipes fixed to bulld with GCC 12
- Upgrade GDB to 12.1
- Build bash to use proper getcwd() on musl
- Fixes for meta-qt5/meta-intel build failures seen with GCC-12
- Enable using private fonts in wxwidgets
- Fix rare sysroot corruption issue during staging
- Add fspassno parameter to partition in wic
- Fix osc fetcher to support quering latest revision
- Update clang to 14.0.4
- Update mariadb to 10.7.4
- Move lzop from core to meta-oe
- Upgrade QT5 to latest 5.15.4 and fix with musl
- Disable lzo support by default in various recipes
- Fix native builds to use right linker paths in go bbclass
- Update linux-yocto to v5.10.114, v5.15.38
- Upgrade gstreamer to 1.20.2
- Upgrade go to 1.18.2
- Upgrade setuptools to 62.3.1
- Upgrade curl to 7.83.1
- Various recipe version bumps
Added
- Enable updater support for raspberrypi2 machine
meta-raspberrypi
now supports enabling 1-wire bus on GPIO4 with
ENABLE_W1 = "1"
in local.conf
- Add meta-python to meta=gnome layer dependencies
- Add support for building python recipes which use hatchling
- Add recipe for cpulimit, openzfs, ulog2, libcoap, btrfsmaintenance
python3-web3, python3-lru-dict, python3-eth-account, python3-eth-abi
python3-parsimonious, python3-eth-rlp, python3-rlp, python3-hexbytes
python3-eth-keyfile, python3-eth-keys, python3-eth-utils
python3-eth-typing, python3-eth-hash, python3-decouple
python3-cytoolz, python3-toolz, python3-inotify, nodejs-oe-cache-native
overlayfs-progs, overlayfs-tools, python3-uinput, xfstests
python3-editables, python3-hatchling, python3-pathspec
python3-setuptools-scm-git-archive
Removed
- Remove meta-networking dependency on meta-python by re-arranging
recipe locations
- Drop GPL-3.0 license from libgcrypt
- Remove uclibc remnants from DISTRO_FEATURES
- Removed recipes: speedtest-cli
- Remove libsrvg rv32 patch
khem
14
2022.06 - “Rygja”
Latest
github-actions released this 2 hours ago
2022.06
4e011c1
[2022.06] - 2022-07-04
Changed
- Bump bitbake to 2.0.1
- Build clang_rt.profile compiler-rt library when possible
- Use nftables instead of iptables by default in networkmanager
- Bump riscv linux-mainline to 5.18
- Update perl to 5.36.0
- Update systemd to 251.2
- Add zstd dependencies in gcc recipes
- Set RebootWatchdogSec to 60s as watchdog in systemd
- Major version upgrades for multiple recipes
- Compile ptests with parallelism, disable packages where it fails
- Fix networkmanager build when ppp is enabled
- Upgrade PHP to 8.1.7
- Switch polkit back to mozjs from duktape
- Upgrade strace to 5.18
- Upgrade alsa recipes to 1.2.7.1
- Upgrade major versions of assorted recipes
- Upgrade go to 1.18.3
- Upgrade mesa to 22.1.2
- Fix udev-extraconf lvm automount
- Upgrade python to 3.10.5
- Add support for Ignored CVEs in cve-check
- Enable xwayland in weston init
- Enable gnu-efi for riscv64
- Add SDK support to image-buildinfo
- Fix systemd to build without utmp support
- Upgrade linux-yocto to v5.10.119, v5.15.44
- Enable MDIO bus config in linux-yocto
Added
- Added recipes
libavtp, libtomcrypt, flite
- Add QB_KERNEL_CMDLINE to runqemu
Removed
khem
15
2022.07 - “Sakiz”
Latest
github-actions released this 1 hour ago
2022.07
fb41efb
[2022.07] - 2022-08-19
Changed
- Update clang to 14.0.6
- Fix compiler-rt build for ARMv5
- Fix native and nativesdk builds for armhf targets
- Fix absolute interpreter paths in php, libdbi-perl, libparse-yapp-perl
libdev-checklib-perl
- Update mariadb to 10.8.3
- Update qtwebengine to v5.15.10-lts and use chromium-87
- Update reference kernels linux-yocto/v5.10.134 v5.15.59
- Add recipe for linux-yocto 5.19
- Update gstreamer to 1.20.3
- Add selftest for shebang overflow
- Upgrade openssl to 3.0.4
- Fix multiple recipes for too long shebang
- Filter build paths on statically linked go arches
- Fix reproducibility issues in perf, gperf
- Fix recipes to build with kernel 5.19+
- Update wayland to 1.21.0
- Upgrade rust to 1.62.0
- Add ptests for curl
- Switch glmark2 build system to use meson
- Distribute sample-config-files with openvpn
- Remove logs from ltp installs, disable -mfpmath=sse on x86
- Fix kernel source handling when not using externalsrc
- Use the python3 ThreadPoolExecutor instead of the OE ThreadedPool
- Fix missing MLPREFIX in debug mappings in gcc runtime
- Use picobuild in python_pep517 class
- Backport a fix for gcc bug 105039
- Upgrade glibc to latest 2.35 branch and binutils to 2.38 branch tip
- Add PACKAGECONFIG for capstone in ruby recipe
- Fix gcc-runtime build when using gold linker
- Fix bunch of recipes to remove buildpath QA warnings
- Upgrade python3-picobuild to 0.2 fixes build of some of the
python_setuptools_build_meta inheriting recipes
- Add many unrelated/patched CVEs to ignore list in meta-oe
- Disable cache for g-ir-scanner in gobject-introspection-data class
- Fix newlib and baremetal toolchain builds when using gcc-12
- Update go to 1.19
- Update u-boot to 2022.07
- Update meson to 0.63.0
- Fix rust SDK generation
- Fix sanitizers build with glibc 2.36
- Fix several recipes for mount.h conflict in glibc 2.36
- Fix supplier field in create-spdx
- Use tools from cross-binutils in wic operations
- Fix LTP build with ld-is-gold in DISTRO_FEATURES
- Rework rust recipes to facilitate nativesdk builds
- Fix glibc builds with DEBUG_BUILD turned on
- Override LIC_FILES_CHKSUM for starfive_v2021.04 u-boot
- Update linux-raspberrypi to 5.15.56
- Backport patch to fix CYW43455 and various CVEs for bluez-firmware-rpidistro
- Fix the buildpaths issue in several recipes
- Fix insufficent entropy in sigtask file names
- Fix many packages for configure tests failing with clang-15
- Add fixes for packages to build with glibc 2.36
- Address linux 5.19 fails in multiple recipes
- Add memory pressure regulation in runqemu
- Update OPTEE to 3.18
- Specify -ffile-compilation-dir to omit absolute file paths in debug info
- Remove-libtool inherits from recipe namespace
- Update rust to 3.62.1
- Upgrade glibc to 2.36
- Resolve relative prefix-map filenames and symlinks in GCC
- Prepare several recipes to build with upcoming clang-15
- Switch debug source handling to use prefix map
Added
- Added recipes: libspiro, python3-picobuild, python3-oslash
python3-jsonrpcclient, python3-aiodns, python3-pycares
waylandpp, python-requests-unixsocket, sshpass
- Add support for visionfive board in meta-riscv
- Add QA check for shebangs
- Add buildpaths to WARN_QA by default
- Introduce UBOOT_MKIMAGE_KERNEL_TYPE
- Add cpu/io pressure regulation to bitbake runqueue
- Implement recipe and global classes in bitbake
- add Andeas RISCV ae350-ax45mp machine support
Removed
- Remove obsolete PEP517_BUILD_API
- Remove the ThreadedPool implementation in oe/utils
- Remove recipe for xf86-input-keyboard
- Remove historical movement of libz.so to /lib
- Remove CMAKE_ASM_FLAGS variable in toolchain file
- Drop v5.10 reference linux-yocto kernel recipes
- Remove largefile distro feature
khem
16
2022.08 - “Targhee”
Latest
github-actions released this 3 days ago
2022.08
0bee51b
[2022.08] - 2022-08-31
Changed
- Switch to poky for providing core layer and bitbake
- Fix fluentbit builds on 32bit machines without 64bit atomics
- Upgrade binutils to 2.39 release
- Clean sourced from workspace after devtool finish
- Update python3-setuptools to 65.x
- Add support for config snippet includes to ssh and sshd
- Address recipes with -Wimplicit-function-declaration as error in
pedantic-errors with clang 15
- Update optee to 3.18
- Update musl to tip of trunk
- Fix klibc with 5.19 kernel headers
- Fix RWX permission error in optee
- Update pipewire to v0.3.56
- Update u-boot and kernel recipe for starfive
- Upgrade gcc to 12.2.0
- Updated linux-yocto to v5.15.62, v5.19.3
- Fix rng-tools to drop wrong dependencies which delayed boot
- Fix several recipes for musl builds missing -D_GNU_SOURCE
- Several fixes for clang-15 found errors
- Enable SDL backend for host QEMU to allow UI option along with vnc
- Disable O2 in systemd when using clang for now
- Do not use llvm-strip system-wide for now due to bugs
- Enable installing libc++.so as linker script
- Fix libgcrypt ptests and install
- Update glibc to have mount.h conflicts solved on 2.36 release branch
- Fix several recipes to compile with clang-15 on musl
Added
- Add recipe for mdio-tools, usbmuxd, libusbmuxd, libimobiledevice,
libplist, gst-editing-services, uutils-coreutils, python3-asgiref
- Added clang-native class to build native compoennts with clang
- Add test for debuginfod
Removed
- Drop has-elf-tls option from rust-target-config
khem
17
2022.09 - “Uda” Latest
github-actions released this yesterday
2022.09
0ff0992
[2022.09] - 2022-09-30
Changed
- Move clang-native.bbclass to classes/ folder to unbreak other layers
- Fix function used in AC_CHECK_LIB multiple recipes, do not use ‘main’
- Fix type mismatches in multiple packages found with clang-15
- Add missing headers for function prototypes in many packages
- Fix buildpaths issues in several more recipes
- Pass -D_GNU_SOURCE to packages needing gnu extentions on musl
- Always set CC and LD for the kernel build
- Fix i686 toolchain relocation issues in gcc-multilib-config
- Fix npm to use https rather than http fetcher
- Fix rust crossbeam-utils for arches without atomics
- Update rust to 1.63.0 and fix build on musl
- Rework llvm handling in mesa
- Add llvm-config wrapper to improve flags handling
- Fix many recipes to build with clang-15
- Define wayland packageconfig for opengl-es-cts,vulkan-cts
- Major version upgrade for assorted recipes
- Upgrade bpftrace to 0.16.0
- Add rpidistro VLC and ffmpeg build
- Update K & R stype functions in autoconf
- Avoid bad checksum race issues in wget fetcher
- Add no-dns-fallback packageconfig to systemd
- Upgrade major version of clang compiler from 14.0.6 to 15.0.0
- Use gcc to build openssh and webkitgtk for now
- Move python3-lxml from meta-python → core
- Update raspberrypi-firmware to 20220830 snapshot
- Fix target rust with LLVM runtime
- Do not package gprofng.rc in binutils-cross-canadian
- Address sox intermittent build issue
- Fix wireless on Raspberry Pi 4
- Prefer += instead of :append operator in several recipes in core
- Fix weston and gstreamer-plugins-base imx recipes to build with clang
- Fix llvm-objdump crash seen on aarch64/musl golang compiler
- Fix xserver builds on IMX8
- Limit rpidistro-vlc,rpidistro-ffmpeg to rpi machines only
- Fix bunch of CVEs, refer to commits for details
- Update mozjs-91 91.13.0 and fix build with python 3.11
- Update clang to latest on 15.x release
- Fix buildpaths warning on more recipes e.g. exiv2, fltk
- Ubreak opensbi dependencies being added to u-boot for non-riscv
machines
- Enable ZSTD as default compression backend for opkg for yoe
- Enable clang for more applications which were marked non clangable
Notable recipes e.g. u-boot, python3
- Update simpleIOT to 0.5.0 release
- Fix compiler-rt-sanitizers builds on non-x86 builds
- Fix Yoe graphical images with musl to work on IMX8 devices
- Fixes for logger debug() calls
- Fix gcompat on aarch64
- Upgrade mesa to 22.2.0
- Mark simpleIOT builds on riscv32 incompatible since golang support does
not exist yet
- Fix recipes in meta-arm to build with clang-15
- Update clang to 15.0.2
- Logic in gtk-icon-cache class fixed for GTK4
- Update tzdata to 2022d
- Update rpm to 4.18.0-release
- Fix weston imx version packageconfig appending syntax error
Added
- New recipes
- Add layer setup tool in OE-Core
- Add documentation for numa machine feature
- Add support for a ARMv8 machine supporting multiple Raspberry Pi boards
- Add yoe-ptest-image target for ptests
- Add enable_loopback_networking() function in bitbake utilities
Removed
- Remove ypbind-mt on musl
- Remove unifex recipe
- Drop capstone support in ruby
- Remove mozjs-78 recipe
- Drop sqlite2 recipe
khem
18
- Releases
2022.10 - “Valachian”
Latest
Compare
Edit release
Delete release
github-actions released this 26 days ago
2022.10
6f91b40
[2022.10] - 2022-10-30
Changed
- Bump LAYERSERIES_COMPAT to langdate ( yocto 4.1 )
- Enforce using libgcc for fmt package for float128 support
- Allow creating src-pkgs when using clang compiler globally
- Update clang to 15.0.2 release tag
- linux-starfive-dev bumped to 6.0.0
- Tweak libcamera to build for Raspberry Pi
- Build u-boot-starfive outside source tree
- Improve manuals with reference to familiar tasks
- Assorted package version upgrades
- Update clang to 15.0.3
- Fix bpftrace on RISCV64
- Fix linux-hardkernel 4.9 with GCC 12
- Update documentation for oe-core
Added
- Add ptest support for bpftrace
- Add new recipe - rpi-libcamera-apps, python3-pytest-json-report
Perfetto, md4c
Removed
- Removed recipes: onboard
- Remove -ffile-compilation-dir from global clang options
khem
19
2022.11 - “Waziri”
Latest
Compare
Edit release
Delete release
github-actions released this 11 hours ago
2022.11
176b43d
[2022.11] - 2022-11-30
Changed
- Upgrade clang to 15.0.4
- Upgrade Nodejs to 16.18.1
- Fix libpcre dependent packages build e.g. ettercap
- Upgrade various python package versions
- Add opengl to REQUIRED_DISTRO_FEATURES for various packages
- Fix several packages build with python 11
- Enable ipv6 support in nginx
- Add build support to build golang compiler on ppc64le
- Add savedefconfig task in u-boot
- Upgrade openssl to 3.0.7
- Upgrade rust to 1.65.0
- Upgrade weston to 11.0.0
- Add libsoup-3.0 dependency to webkitgtk
- Upgrade systemd to 251.8
- Fix uboot on ae350-ax45mp
- Enable glvnd support in mesa
- Add selinux PACKAGECONFIG to several recipes in core
Added
- Added recipes - gtk-vnc, libglvnd, python3-brotli, minio
jwt-cpp, spice-gtk, python3-kmod, python3-aioserial
- Add libc testsuite for musl
- Add 7-Zip support in conversion types for image_types
- Add crate in own-mirrors
Removed
khem
20
2022.12 - “Xalda”
Latest
Compare
Edit: 2022.12 - “Xalda”
Delete: 2022.12 - “Xalda”
github-actions released this 20 hours ago
2022.12
5c025e9
[2022.12] - 2022-12-31
Changed
- Update clang to 15.0.6 and fix build for 32bit LFS64 systems
- Fix compiler and binutils tools options for kernel and u-boot
- Add protocol= explicitly to github SRC_URI for linux-odroid
- Add opengl to REQUIRED_DISTRO_FEATURES in recipes from meta-oe
- Add ipv6 in PACKAGECONFIG to libwebsockets
- Rename gcr to gcr-3 to accomodate gtk4 and dependencies
- Move GTK4 support to core from meta-oe/meta-gnome layers
- Improve reproduciblity patch in go compiler
- Avoid host contamination in go cross SDK compiler
- Update minimum python version needed to 3.8 on build hosts
- Fix several recipes for lfs64 support
- Ports gtk3+ to use meson
- Update rust compiler to 1.66.0
- Conevert bitbake to use argparse
- add -DUSE_X11 Flag to qtbase to work with latest mesa
- Use python3targetconfig in recipes to use right python for target
- Fix waf-samba to use target python3-config
- Fix openCV build with ffmpeg 5.1+
- Update qemu to 7.2.0
- Update cmake to 3.25.1
- Use rm from HOSTTOOLS in rm_work explicitly
- Update wireplumber to 0.4.13 and use dbus defaults
- Update XFCE recipes to 4.18.0 release
- Update python to 3.11.1
- Add rust to SDK toolchain language selection
- Update systemd to 252.4
- Fix several recipes to work with LFS64 functions removal from musl
- Update several gnome recipes to latest
- Update go compiler to 1.19.4
- Fix rust recipes to work with musl without LFS64 functions
Added
- New recipes - xdg-desktop-portal-wlr, basu, gnome-software,
xdg-desktop-portal, editorconfig, python3-rapidjson, tuna,
sip, python3-uefi-firmware, python3-linux-procfs, python3-schedutils,
gcr-4, python3-watchdogdev, appstream, libtraceevent, libtracefs,
flatpak, flatpak-xdg-utils, libslirp
- Add time64.conf to enable 64bit time_t on 32bit glibc systems
- Add x86-64-v3 tunes (AVX, AVX2, BMI1, BMI2, F16C, FMA, LZCNT, MOVBE, XSAVE)
Removed
- Drop OEBasic siggen from sstate signature
- Remove RRECOMMENDS to rng-tools for sshd package
- Remove SERIAL_CONSOLE variable
khem
21
Repository: YoeDistro/yoe-distro · Tag: 2023.01 · Commit: c4a205b · Released by: github-actions[bot]
[2023.01] - 2023-01-30
Changed
- Switch to using ‘mickledore’ for LAYERSERIES_COMPAT
- Fix clang recipes to work without LFS64 functions
- Use gcc to compile pixman on aarch64
- Fix several recipes for 64bit time_t on 32bit arches
- Update musl to latest tip ( drops LFS64 interfaces )
- Use binutils objcopy in BSP linux kernel builds
- Use gcc for all u-boot forks
- Upgrade usbguard to 1.1.2
- Switch qemux86-64 to x86-64-v3 tune
- Include “c” in IMAGE_LINGUAS for glibc
- Upgrade ruby for 3.2.0
- Upgrade curl to 7.87.0
- Switch ostree to use fuse3
- Fix QT5 builds with 64bit time_t
- Update concurrencykit to latest to support RISCV
- Update nezha (rv64 board) support
- Fix EGT recipe to work with clang in meta-atmel
- Improve sstate reuse of llvm-project-sources
- Fix meta-freescale BSP recipes to work with clang compiler
- Fix various python modules to migrate from picobuild to python3-build
- Fix freedom-u540 opensbi dependency loop in meta-riscv
- Improve shutdown handling and lockfile handling in bitbake at exit
- Set ac_cv_sys_file_offset_bits=64 for musl builds globally, enables
64-bit off_t on autotool based packages
- Unify rust patches into rust-source.inc
- Update linux-yocto kernels to v5.15.87 and v6.1.5
- Add libgcc to uninative-tarball
- Fix several recipes to work with powerpc32 architecture
- Bump linux-libc-headers to 6.1
- Add webp packageconfig knob for libtiff
- Upgrade rust to 1.66.1
- Improve reproducibility in clang build
- Apply C++17 portability fixes in several recipes
- Fix C++11(Alignof) issues in several packages
- Update clang to 15.0.7
- Update bcc to 0.26.0
- Fix create-spdx handling for clang
- Fix several recipes to work with upcoming GCC 13 compiler
- Fix Upstream-Status format of several patches
- Use 6.1 kernel for Qemu machines
- Upgrade binutils to 2.40
- Upgrade u-boot to 2023.01
Added
- Added recipes - xdg-desktop-portal-gtk, eog
libdecor, biodbc, python3-build, python3-pyproject-hooks
python3-reedsolo, lvgl-demo-fb, nv-codec-headers, webp-pixbuf-loader
gnome-chess
- Add GLIBC_64BIT_TIME_FLAGS on ppc/x86
- Introduce v6.1 reference linux-yocto kernel recipes
Removed
- Removed recipes - boost-url, python3-strict-rfc3339, python3-picobuild
- Remove package_tar.bbclass from classes-global
khem
22
- Releases
2023.02 - “Zaghawa”
Latest
Compare
Edit: 2023.02 - “Zaghawa”
Delete: 2023.02 - “Zaghawa”
2023.02
7173709
[2023.02] - 2023-02-28
Changed
- Update busybox to 1.36, disable SHA accelarators for 32bit x86
- Bundle libc++abi archive into static libc++.a, improves static linking
- Bump kernel to linux-yocto 6.1 for odroid devices
- Add ptest support for python3-pillow
- Fix several recipes to build with upcoming GCC13 release
- Upgrade mongodb to 4.4.18 and fix build with ccache enabled
- Fix recipes to use target python config for target during cross compile
- Pass MAXLINELENGTH to scons invocation, helps with large cmdline lengths
- Upgrade rust to 1.67.1
- Upgrade linux-raspberrypi to 5.15.90
- Add ptest support to gnuTLS
- Upgrade linux-yocto/5.15 to v5.15.91, linux-yocto/6.1 to v6.1.9
- Fix Yoe Updater to use correct boot device after upgrade
- Upgrade glibc to 2.37
- Fix several recipes to work with upcoming gcc 13 release
- Improve on target locale generation
- Fix clang recipe for multilib build
- Enable PIC for static archives with clang runtime libs
- Fix several recipes to build with clang-16/c++17
- Add ptest for minicoredumper
- Add PACKAGECONFIG for video-codecs in mesa
- Provide missing tools during cross compiling openmp
- Sync dtc tree with kernel for nezha/riscv
- Add a PACKAGECONFIG for arm_neon in graphene
- Upgrade gstreamer1.0 to 1.22.0
- Update go compiler to 1.20.1
- Fix wireless on model 3B and Zero W
- Use LLVM_ENABLE_RUNTIMES to build llvm runtime libs
- Speedup nodejs native compilation by not during cross builds
- Improve idle thread exception handling in bitbake
- Do not use xz parallelism options with zstd
- Enable systemd-time-wait-sync.service when timesycd is enabled
- Improve build-appliance-image target
- Upgrade Upgrade to 13.1
- Fix QEMU build with 6.2 kernel headers
- Fix ffmpeg build with vulkan
- Improve resulttool reporting
- Upgrade musl to latest tip of trunk
- Fix Upstream-Status for several patches
Added
- New recipes
- python3-pycups, extract-cert, rtkit, system-config-printer
rpi-eeprom, libdeflate, python-daemon, smemstat, linux-serial-test
libgpiod v2.0-rc2, python3-gpiod, plocate
- Add initial support for loongarch64 architecture
- Add artifact signing infrastructure class ( signing.bbclass )
- Add weston kiosk shell
Removed
- Remove rock-pi-4 MACHINE
- Remove image SPDX and index from deploydir
- Remove clang-offload-wrapper from clang, gone in clang 16 as well
- Remove glib site cached values
- Removed recipes
khem
23
2023.03 - “Acıpayam”
Latest
Edit: 2023.03 - “Acıpayam”
Delete: 2023.03 - “Acıpayam”
github-actions released this 28 minutes ago
2023.03
955ef9e
[2023.03] - 2023-02-30
Changed
- Upgrade raspberrypi kernel to 5.15.103
- Upgrade linux-yocto to v6.1.20
- Upgrade openSBI to 1.2 and fix cyclic dependency for fitImage based boards
- Create machine-id with “uninitialized” text
- Upgrade simpleIOT to 0.9.0 release
- Refresh fixes for android-tools
- Upgrade linux-hardkernel to 4.9.337
- Upgrade nodejs to 18.14.2
- Enable mesa-demos build with userland graphics drivers on rpi
- Enable kms plugin for visionfive2
- Fix gdb intermittent build issue
- Allow overwrite of QB_CPU for qemux86
- Add PROVIDES and RPROVIDES for virtual/opencl-icd
- Enable --enable-new-dtags in binutils for DT_RUNPATH
- Add missing binutils dependency in glibc
- Yoe updater now supports tmpfs as well as persistent overlays
- Add yoe-installer-image to create SD card installer for eMMC
- Switch to using ext4.xz for rootfs in updater
- Update arm optee-os to 3.20.0
- Upgrade bpftrace to 0.17.0
- Fix serveral recipes in meta-freesclale to build world
- Enable parallel execution of ptest images and fix ptest dependencies
- Handle spaces within user $PATH in SDK installers
- Upgrade systemd to 253.1
- Upgrade visionfive2-firmware to VF2_v2.10.4
- Fix nodejs build on older build hosts eg. centos8
- Move android-tools from meta-clang to meta-oe
- Update openssh to 3.1.0
- Update matchbox recipes to latest
- Upgrade networkmanager to 1.42.4
- Upgrade clang to 16.0.0
- Fix building various packagegroups in meta-openembedded
- Use python3-unittest-automake-output in python recipes for ptest integration
- Fix qtpdf with clang-native from 16.0.0 release
- Update android-tools to 29.0.6.r14
- Disable warnings as errors when building glibc
- Update mesa to 23.0.0
- respect IMAGE_LINK_NAME in seftests
- Upgrade RPI kernel to 6.1
- Fix some linkshared regression introduced in go 1.20
- Upgrade openssh to 9.3p1
- Fix rpi specific vlc and ffmpeg with clang16
- Update clang to 16.0.1
- Fix libunwind compile failures on 32-bit arm with Clang 16
Added
- Add kernel specific KERNEL_OBJDUMP variable
- Add VOLATILE_TMP_DIR variable
- Add support for visionfive2 board
- Add recipes - python3-rich, xdg-dbus-proxy, libavif, dav1d
pgpool2, python3-unittest-automake-output, debugedit, reboot-mode
python3-executing, python3-pure-eval, python3-stack-data
exfatprogs
- Add yoe updater support for MX8-VAR-SOM symphony board
- Add ptest support for mbedTLS
- Add buildstats-summary script
- Add support for loongarch64
- Add find-debuginfo support back
Removed
- Removed recipes - quagga, jhi, exfat-utils
khem
24
2023.04 - “Balkhi”
Latest
Compare
Edit: 2023.04 - “Balkhi”
Delete: 2023.04 - “Balkhi”
github-actions released this last week
2023.04
1801832
[2023.04] - 2023-04-29
Changed
- Fix meta-clang towards meeting yocto layer compatible status
- Fix clang packaging issue where installing clang-tools
would pull in whole compiler
- Simplify imx-boot container
- Add 6.1 linux-ti-staging
- Update tzdata 2023c
- Make EXCLUDE_FROM_WORLD boolean
- Fix recipes to build with upcoming 2.72 autconf release
- Remove double protocol= from SRC_URIs in meta-oe
- Correct the license information for several recipes in meta-oe
- Update several gnome recipes to 44.0
- Add ptest images for meta-oe, meta-python, meta-perl
- Update rust to 1.68.1
- Add missing dependency on glib-2.0-native in several recipes
- Add fixes to several recipes to build with autoconf 2.72
- Update clang to llvmorg-16.0.1 release
- Fix bindgen-cli and python3-pyruvate to work with new crate
updated class
- Fix upstream patch status in meta-webserver, meta-perl, meta-xfce
meta-gnome, and meta-multimedia
- Improve cargo-update-recipe-crates to specify two different versions
of same crate in given recipe
- Use 3.20 version for OPTEE components
- Update VisionFive2 firmware to 2.11.5
- Upgrade pipewire to 0.3.68
- Fix recipes to build with multilib on
- Switch beaglebone and beagle-x15 to bb.org kernel/u-boot
- Add support for creating bootable SD card for visionfive2 board
- Use 6.2 for linux-ti-mainline kernel
- Use shlex instead of deprecated pipe in python scripts
- Upgrade u-boot to 2023.04
- Update ffmpeg to 6.0
- Update musl to latest trunk
- Update rust to 1.68.2
- Update FSL u-boot to 2023.04 release
- Update QT5 to v5.15.9-lts-lgpl
- Add new Assimp submodule to qt3d
- Fix visionfive2 wic file generation
- Upgrade systemd 253.1 → 253.3
- Fix several ptests to work on musl systems
- Fix runtime dependencies for clang scanbuild
- Update linux-yocto to v6.1.25, v5.15.108, v6.1.24
- Fix bunch pf ptests on musl to fix core-image-ptests-fast
Added
- Add new CVE database fetcher cve-update-nvd2-native
- Added new recipes:
- libpcsc-perl, polkit-gnome, libnfs, adw-gtk3, etcd-cpp-apiv3
- Add ptests for libtinyxml2, python3-lorem, python3-path and dc
bitwise
- Enable hashserve distro-wide for yoe
- Add support for Raspberry Pi Camera Module v3
khem
25
2023.05 - “Coopworth”
Latest
github-actions released this 2 minutes ago
2023.05
25573f9
[2023.05] - 2023-05-30
Changed
- Upgrade clang to 16.0.4+
- Fix stale SRC_URI locations in several meta-openembedded recipes
- Drop crosssdk suffix from virtual binutils, gcc, go and clang recipes
- Fix SRC_URI locations for several recipes in meta-openembedded
- Switch to using upcoming debian “bookworm” based container for building
- Enable LoongArch support in clang
- Upgrade lvgl recipes and support wayland and fbdev backends
- Fix buildpath QA errors in many meta-openembedded recipes
- Fix recipes to build without gobject-introspection-data
- Upgrade Gstreamer to 1.22.2
- Update musl to 1.2.4
- Add CPE_NAME to /etc/os-release
- Set minimum required target kernel to 5.15
- Upgrade rust compiler to 1.69.0
- Upgrade QEMU to 8.0.0 and fix ppc32 emulation bug
- Default to https git protocol where possible in SRC_URI
- Add --libfiles option to llvm-config
- Add systemd unit file for etcd
- Uprev libplist to 2.3.0, fix several dependent recipes to
support API changes from 2.3.0
- Fix rpi-libcamera-apps recipe for ARM64
- Fix linux-bb.org to build with gcc 13
- Fix several recipes in meta-oe to remove TMPDIR in output packages
- Update libfmt to version 10 and fix dependencies to support new APIs
- Use autoconf-archive-native as m4 macros dependencies during build
instead of target autoconf-archive during build
- Enable zbb manip extensions for rv32/rv64 in ffmpeg build
- Fix few of buildpath issues in meta-openembedded recipes
- Simplify MACHINEOVERRIDES definitions for rpi
- Add missing run-time dependencies in several ptython module recipes
- Mandate gobject-introspection-data DISTRO_FEATURE
- Let clang override the llvm provided by OE-Core
- Remove unused patch files in core and meta-openembedded layers
- Add ptest support to hiredis and uprev to 1.1.0
- Upgrade go compiler to 1.20.4
- Upgrade binutils to latest top of 2.40 branch
- Upgrade zfs to latest master which is 2.1.11+
- Requires gobject-introspection-data DISTRO_FEATURE in dependent recipes
- Update curl to 8.1.1
- Update busybox to 1.36.1
- Upgrade to GCC 13.1
Added
- New recipes
- etcd, python3-tomlkit, python3-pytest-mock, python3-calver
python3-trove-classifiers, python3-platformdirs, python3-uswid
python3-pefile, libcbor, psutils, libpaper, serial, libisoburn
libisofs, paprefs, openfortivpn, networkmanager-fortisslvpn
mbpoll, python3-bleak
Removed
- Drop MIPS Edgerouter support
- Removed recipes
- xorriso, python3-async, linux-yocto 5.15
- Drop lzop from linux-imx defaults
khem
26
2023.06 - “daglic”
Latest
Compare
Edit: 2023.06 - “daglic”
Delete: 2023.06 - “daglic”
github-actions released this 44 minutes ago
2023.06
a2a2f92
[2023.06] - 2023-06-30
Changed
- Add missing run-time dependencies in several python recipes
- Stop using PYTHON_PN in several python recipes
- Add 44.2 gnome recipes
- Fix REQUIRED_DISTRO_FEATURES gobject-introspection-data in several recipes
- Upgrade linux-yocto/6.1 to v6.1.35
- Document SPLASH_IMAGES variable
- Do not search host paths for find_program() in cmake.bbclass
- Don’t force PAHOLE=false in linux-yocto
- Upgrade OpenSSL 3.1.1
- Enable fullscreen and disable startup-msg in psplash
- Fix spdx license parsing
- Make built-in libtraceevent plugins from perf cohabit with external libtraceevent
- Fix vulkan-samples build on 32-bit platforms
- Make OpenSBI FW_TEXT_START=0x40000000 specific to jh7110
- Use python3 in oe-stylize
- Upgrade wireshark to 4.0.x
- remove -fcanon-prefix-map in scp-firmware recipe
- Use IMAGE_LINK_NAME in updater and yoe-initramfs-image
- Upgrade gstreamer1.0 to 1.22.3
- Update rust to 1.70.0
- Switch meta-qt6 to 6.5 branch instead of 6.5.1 point release branch
- Update clang to 16.0.6 tag
- Fix enabling lld as distro linker in clang.bbclass
- Upgrade go compiler to 1.20.5
- Fix recipes to build issues found using lld linker
- Drop setting ARM_INSTRUCTION_SET explicitly, it can build in thumb mode
and upgrade to 8.2.7
- Use BFD linker for libgcc and glibc explicitly
- Replace Yocto .h by .png splashscreen in psplash
- Add weston user to wayland and render groups
- Upgrade libubootenv to 0.3.4
- Fix several recipes to link with LLD linker
- Use llvm-strip system-wide for STRIP utility for RISCV targets
- Fix ntpd systemd service type forking → simple
- Fix OpenSBI build for visionfive2 SBC
- Upgrade GDB to 13.2
- Drop using tunctl in runqemu/qemu-helper
- Upgrade python to 3.11.3
- Upgrade mesa to 23.1.1
- Fix gn to build with gcc-13
- Backport fix for linking failures using LLD linker for RISCV
- Migrate to use markdown format for READMEs in meta-openembedded
- Fix vpu and pvr-graphics build and packaging issues on visionfive2
- Bump LLVM in core layer to 16.0.6
- Fix several recipes to build when LLD is default distro linker
- Add Upstream-Status tags to meta-openembedded, meta-rpi, meta-odroid
meta-freescale, meta-clang and meta-yoe layers
- Add support for mbedTLS v3.x
- Bump QT6 packages to 6.5.3
- Fix weston booting issues on visionfive2 SBC and update to use
StarFive SDK v3.0.4 components
- Improve patch-status layer filtering in insane.bbclass QA checks
- Update rpi kernel to 6.1.34
- Enable glx/opengl support in gstreamer1.0-plugins-base
- Update python3 to 3.11.4
Added
- Added recipes - python3-ninja-syntax, python3-lazy, python3-classes
python3-pypng, stopit, vulkan-validation-layers, python3-meson-python
- Add support for loongarch64 to initramfs
- Add QT6 layer and enable it for var-som-mx8
- Add LGPL-3.0-with-zeromq-exception to common-licenses
- Add python_mesonpy class
- Add new project for VisionFive2
- Add support for Variscite VAR-SOM-MX8M-NANO
- Add layer- override support
- Enable largefile and 64bit time_t support systemwide for 32 bit platforms
Removed
khem
27
2023.07 - “exmoor”
Latest
Compare
github-actions released this 4 minutes ago
2023.07
63c5485
[2023.07] - 2023-07-31
Changed
- Fix parallel build issue with external modules on visionfive2
- Move xcb-util-cursor from meta-oe to core layer
- Upgrade ostree to 2023.5
- Upgrade bcc to 0.28.0
- Update visionfive2 SDK components to V3.1.5
- Upgrade openCV to 4.8.0
- Upgrade bpftrace to 0.18.0
- Upgrade linux-raspberrypi to 6.1.38
- Update linux-yocto 6.1 to v6.1.38 and 6.4 to v6.4.3
- Upgrade bluez5 5.66 → 5.68
- Enable JIT on RISCV64 for webkitgtk
- Add -Wl,–undefined-version when using lld for few recipes
- Upgrade opkg to 0.6.2
- Upgrade go compiler to 1.20.6
- Improve pybootchartgui rendering
- Add -mbranch-protection=standard for all aarch64
- Configure gcc without --enable-standard-branch-protection
- Upgrade qemu to 8.0.3
- Upgrade linux-firmware to 20230625
- Add rust selftests
- Fix network restrictions for glibc-testsuite ptests
- Add the disable-wifi overlay for RPI machines
- Improve glibc testing over nfs root
- Upgrade GCC to 13.2 release
- Upgrade autoconf to 2.72c
- Fix freertos-variscite compile failure when do_compile is rerun
Added
- Added recipes - python3-pyqt5, python3-pyqt5-sip, python3-pyqt-builder
wtmpdb, lastlog2
- Yoe logo in psplash
Removed
khem
29
2023.08 - “Faeroes”
Latest
Compare
2023.08
dab87cc
[2023.08] - 2023-08-31
Changed
- Move projects to toplevel conf directory
- Implement new project detection logic in envsetup
- Upgrade Simple IoT to v0.12.2
- Fix dependencies for yoe-kiosk-browser
- Convert CVE_CHECK_IGNORE to CVE_STATUS in meta-openembedded
- Fix cross builds for python3-pyaudio
- Enable wayland/x11/opengl configs based corresponding distro features in mesa-pvr
- Move libadwaita to core layer
- Move gcr3 to meta-oe
- Upgrade systemd to 254
- Upgrade FSL graphics stack to 6.4.11.p1.2 BSP release
- Use libgpiod 1.x for VAR-SOM based projects e.g. var-som-mx8
- Switch Qemu based projects to use QT6 instead of QT5
- Upgrade musl to tip of trunk
- Upgrade binutils to 2.41 release
- Fix syntax error in image_types_sparse
- Bump libcamera to latest tip of trunk
- Fix conversion errors in cve_check
- Fix poco ptests run
- Fix ptests runs on qemu inside container
- Do not use lld on riscv with binutils 2.41
- More LLD fixes e.g. elfutils and gnu-efi
- Use yoe-kiosk-image instead of yoe-qt5-image for CI
- Bump libcamera-apps to latest
- Do not use internal assembler with clang for qtbase
- Restart yoe-kiosk-browser service on failure
- Update linux-yocto/6.4 to v6.4.11 and 6.1 to v6.1.46
- Pass /dev/vhost-net to build container from envsetup
- Upgrade openssh to 9.3p2
- Upgrade go compiler to 1.20.7
- Fix recipe_sysroot_check_ld_is_lld to not trigger on allarch recipes
- Fix rust features for vfpv3d16
- Adjust commman to work with interface renaming with
kernel 6.4 and systemd 254
- Switch RPI4 to use QT6
- Wrap more bitbake commands in container e.g. bitbake-getvar
- Enable i2c and disable rpi boot logo for rpi4-64
- Add needed host SDK bits for QT6 to yoe-kiosk-image
- Define SRCREV_FORMAT for recipes with multiple git SRC_URIs
- Upgrade to glibc 2.38
- Upgrade openSSL to 3.1.2
- Fix unnessary clang rebuild when enabling MULTILIBS
- Add ptests to librelp and run them by default in meta-oe ptest image
- Upgrade mariadb to 10.11.5
- Fix musl build for riscv32
- Allow building some native recipes with ccache
- Do not use LLD linker to build go-runtime on aarch64, subsequent
apps linking with this go-runtime crashes go linker
- Switch from GNU-TLS to openssl transport by default on rsyslog
- Update to latest on QT6 6.5 LTS
- Improve taskhash reproducibility in bitbake/siggen
- Add new srcrev fetcher API to fetch2
- Disable perl support in perf
- Do not define TESTIMAGE_AUTO for qemu machines
- Fix allarch override syntax in cmake class
- Fix recipes to work on arm without neon systems
- Update contribution guidelines
- Upgrade cmake to 3.27.4
- Increase python thread stack size to 2M on musl
Added
- Added recipes
- webkitgtk3, libnvme, python3-telnetlib3, mstpd, bolt
python3-types-psutil, python3-types-setuptools, qad
ttf-google-fira, python3-oauth2client, python3-schedule
spice-guest-vdagent, aml, phodav, gnome-boxes, libosinfo
gnome-remote-desktop, libcacard, usbids, qcbor
python3-sdbus, libfaketime, python3-piccata, python3-gspread
- Add script to generate kernel CVE_STATUS entries for linux-yocto
- Add packageconfig to support colored logs in journald
- Add DOCKER_PORTS variable in setenv to forward ports between docker and host
- Add GCP fetcher to list of supported protocols
- Add yocto sstate mirror as default backup for public sstate feeds
- Add MESON_TARGET to meson class which can be defined in recipes
- Add DOCKER_EXTRA_ARGS to envsetup to pass custom options to docker
- Add vfat image type
Removed
- Remove version-going-backwards from build QA errors
- Remove unused AUTHOR variable from recipes in meta-openembedded
and core
khem
30
2023.09 - “Galway”
Latest
Compare
2023.09
cc16647
[2023.09] - 2023-09-30
Changed
- Reset DOCKER_REPO inside interactive docker shell
- Add glibc 2.38 stable updates
- Switch glib-networking to use gnuTLS for TLS needs
- Fix KCONFIG_CONFIG_COMMAND in menuconfig task
- Fix python, tcl ptest runs on musl
- Fix multilib builds of few packages in meta-oe
- Fix several packages to build for non-neon arm targets
- Fix multilib support in clang to search lib32
- Fix fetching bcc recipe to not modify .gitconfig on build host
- Explicitly disable JIT in webkitgtk for armv7* with softfp
- Fix rust targets for ppc64 architecture
- Improve loongarch support in go compile and gcc toolchain
- Update linux-yocto/6.4 to v6.4.14 and 6.1 to v6.1.51
- Upgrade qemu to 8.1.0
- Review CVE_STATUS for kernel vulnerablity list
- Fix several ptests in core to work on musl
- Upgrade weston to 12.0.2
- Switch to using “nanbield” layer series compat
- Update VisionFive2 SDK to V3.6.1
- Fix -fstack-protector GCC on aarch64
- Mark RISCV32 incompatible architecture in goarch.bbclass
- Upgrade coreutils to 9.4
- Add ptest support to mariadb
- Enable 64 bit shell arithmetic in busybox, helps 64bit time_t
- Fix build race in piglit and groff
- Use mtime checks instead of inotify in bitbake
- Use 64 bit integers across all targets in perl
- Upgrade clang to 17.0 major release series
- Upgrade gnome recipes to 45.0
- Update linux-raspberrypi kernel to 6.1.54
- Update OpenSSL to 3.1.3
- Improve oeqa/runtime/parselogs
- Enable yocto sstate feed server
- Upgrade to systemd 254.4
- Reduce debuf info size of webkitgtk3 and webkitgtk
- Fix mesa to build with LLVM 17
- Fix recipes to build with kernel 6.5
- Add missing upstream status for all recipes in meta-openembedded
- Update nodejs to 20.5.1
- Bump VF2 SDK to v3.7.5
Added
- Added new recipes
- microcom, vsomeip, libei, python3-apiflask
python3-webargs, python3-flask-httpauth, python3-apispec
python3-flask-marshmallow, webrtc-audio-processing, python3-flask-jwt-extended
tecla, python3-pyu2f, python3-uritools, python3-beartype, musl-legacy-error
python3-spdx-tools, python3-flask-cors, python3-boto3, python3-botocore
python3-nacl
- Add gpt-hybrid partition layout to wic
- Enable generating spdx manifest by default
Removed
