2022.05 - “Qashqai”
github-actions released this 2 days ago
release-notes-from-changelog
GitHub action that extracts release notes from an existing changelog.
Changes in this version:
[2022.05] - 2022-05-31
Changed
- Update meta-ti recipes to SDK 08.02.00.005
- Let the user drive the update interval for CVE database
- Correctly handle file names containing colons in bitbake
- Fix firmware autoloading for rpi by creating
brcmfmac43455-sdio.raspberrypi,4-model-b.bin symlink - Update qemu to 7.0.0
= Upgrade musl to tip of trunk - Upgrade 250.5
- Use arm-versatile-926ejs KMACHINE for qemuarmv5
- Make git intercept global
- Upgrade GCC to 12.1
- Add openssh-sftp-server to openssh RDEPENDS
- Upgrade linux-firmware to 20220509
- Upgrade linux-raspberrypi to 5.15.38
- Various native recipes fixed to bulld with GCC 12
- Upgrade GDB to 12.1
- Build bash to use proper getcwd() on musl
- Fixes for meta-qt5/meta-intel build failures seen with GCC-12
- Enable using private fonts in wxwidgets
- Fix rare sysroot corruption issue during staging
- Add fspassno parameter to partition in wic
- Fix osc fetcher to support quering latest revision
- Update clang to 14.0.4
- Update mariadb to 10.7.4
- Move lzop from core to meta-oe
- Upgrade QT5 to latest 5.15.4 and fix with musl
- Disable lzo support by default in various recipes
- Fix native builds to use right linker paths in go bbclass
- Update linux-yocto to v5.10.114, v5.15.38
- Upgrade gstreamer to 1.20.2
- Upgrade go to 1.18.2
- Upgrade setuptools to 62.3.1
- Upgrade curl to 7.83.1
- Various recipe version bumps
Added
- Enable updater support for raspberrypi2 machine
meta-raspberrypinow supports enabling 1-wire bus on GPIO4 with
ENABLE_W1 = "1"inlocal.conf - Add meta-python to meta=gnome layer dependencies
- Add support for building python recipes which use hatchling
- Add recipe for cpulimit, openzfs, ulog2, libcoap, btrfsmaintenance
python3-web3, python3-lru-dict, python3-eth-account, python3-eth-abi
python3-parsimonious, python3-eth-rlp, python3-rlp, python3-hexbytes
python3-eth-keyfile, python3-eth-keys, python3-eth-utils
python3-eth-typing, python3-eth-hash, python3-decouple
python3-cytoolz, python3-toolz, python3-inotify, nodejs-oe-cache-native
overlayfs-progs, overlayfs-tools, python3-uinput, xfstests
python3-editables, python3-hatchling, python3-pathspec
python3-setuptools-scm-git-archive
Removed
- Remove meta-networking dependency on meta-python by re-arranging
recipe locations - Drop GPL-3.0 license from libgcrypt
- Remove uclibc remnants from DISTRO_FEATURES
- Removed recipes: speedtest-cli
- Remove libsrvg rv32 patch
