Wordpress notes
We run several Wordpress sites on a Linode server. Lately MariaDB has been getting killed by the OOM (out of memory killer):
[1308796.534092] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/mariadb.service,task=mariadbd,pid=162181,uid=973
[1308796.534492] Out of memory: Killed process 162181 (mariadbd) total-vm:667280kB, anon-rss:27808kB, file-rss:128kB, shmem-rss:0kB, UID:973 pgtables:692kB oom_score_adj:0
[1308797.835946] systemd-journald[187]: Under memory pressure, flushing caches.
The main software components involved are MariaDB, Caddy2, and php-fpm.
The Linode metrics are interesting:
But are not very granular.
To get more insight into what is happening, I installed SIOT and pointed it to our portal instance so I can view the data with Grafana.
No smoking guns yet, but the php-fpm CPU usage looks interesting.
Got a few more events in the last 12h:
[root@web3 cbrake]# journalctl --since yesterday -u mariadb | grep "OOM killer"
Jan 19 14:15:54 web3 systemd[1]: mariadb.service: A process of this unit has been killed by the OOM killer.
Jan 19 14:17:57 web3 systemd[1]: mariadb.service: A process of this unit has been killed by the OOM killer.
Jan 19 18:34:54 web3 systemd[1]: mariadb.service: A process of this unit has been killed by the OOM killer.
Interestingly, php-fpm is consuming a lot of memory but mariadb is getting killed – hmm …
Looking at dmesg, it appears there are many php-fpm tasks. SIOT is adding the total from all those tasks and the OOM killer probably just looks at single tasks.
[72420.250119] Tasks state (memory values in pages):
[72420.250120] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
[72420.250126] [    186]     0   186    20808       56   176128      784          -250 systemd-journal
[72420.250132] [    188]     0   188     8683       24    81920      512         -1000 systemd-udevd
[72420.250138] [    251]   977   251     5534       64    86016      576             0 systemd-resolve
[72420.250141] [    252]   976   252    22950       69    90112      736             0 systemd-timesyn
[72420.250143] [    260]    81   260     2298       60    61440      160          -900 dbus-broker-lau
[72420.250146] [    261]    81   261     1094       53    49152      128          -900 dbus-broker
[72420.250151] [    262]     0   262    32905       49   167936     6656             0 firewalld
[72420.250153] [    263]     0   263     4493       64    73728      222             0 systemd-logind
[72420.250158] [    265]   980   265     4759       64    77824      256             0 systemd-network
[72420.250161] [    280]    33   280   317218      515   184320     2920             0 caddy2
[72420.250165] [    282]     0   282    66515      197   208896     1760             0 php-fpm
[72420.250168] [    283]     0   283     2775       64    65536      256         -1000 sshd
[72420.250173] [    287]     0   287     1495       32    49152       64             0 agetty
[72420.250175] [    288]     0   288     1374       32    53248       32             0 agetty
[72420.250178] [    337]  1003   337   316761     1964   221184     4214             0 siot
[72420.250180] [   9464]   973  9464   168356     5425   729088    32085             0 mariadbd
[72420.250183] [   9897]    33  9897   103392    13502   376832     6825             0 php-fpm
[72420.250185] [   9900]    33  9900   103241    13051   376832     6634             0 php-fpm
[72420.250188] [   9902]    33  9902   103382    12550   376832     7210             0 php-fpm
[72420.250191] [  11104]     0 11104     3630       32    73728      352             0 sshd
[72420.250196] [  11121]  1000 11121     3702       57    73728      416             0 sshd
[72420.250199] [  11122]  1000 11122     1944       32    53248      192             0 bash
[72420.250204] [  11128]  1000 11128     4516       32    73728      288             0 sudo
[72420.250206] [  11130]  1000 11130     4516       18    61440      256             0 sudo
[72420.250211] [  11131]     0 11131     2464       32    61440       96             0 su
[72420.250214] [  11133]     0 11133     1969       32    57344      192             0 bash
[72420.250216] [  11134]     0 11134     5109       28    81920      224             0 journalctl
[72420.250219] [  11135]     0 11135     1692       32    49152       64             0 less
[72420.250221] [  11137]    33 11137    83562     9405   303104     9033             0 php-fpm
[72420.250224] [  11139]    33 11139    78314     7718   266240     6014             0 php-fpm
[72420.250226] [  11141]    33 11141    79850    10173   278528     4691             0 php-fpm
[72420.250229] [  11143]    33 11143    84392     7472   311296    11491             0 php-fpm
[72420.250231] [  11145]    33 11145    83368    10080   303104     8195             0 php-fpm
[72420.250234] [  11147]    33 11147    83368    11570   303104     6691             0 php-fpm
[72420.250236] [  11149]    33 11149    79607     8385   278528     6563             0 php-fpm
[72420.250241] [  11151]    33 11151    79607     8382   278528     6211             0 php-fpm
[72420.250244] [  11152]    33 11152    79095    10519   274432     3907             0 php-fpm
[72420.250246] [  11155]    33 11155    77046     9562   253952     2759             0 php-fpm
[72420.250248] [  11156]    33 11156    72806     4711   221184     3079             0 php-fpm
[72420.250251] [  11159]    33 11159    72294     5933   217088     1479             0 php-fpm
[72420.250253] [  11160]    33 11160    72294     5741   217088     1575             0 php-fpm
[72420.250255] [  11163]    33 11163    72294     5989   217088     1380             0 php-fpm
[72420.250258] [  11164]     0 11164     2825      192    61440      128             0 sshd
[72420.250260] [  11166]    33 11166    72219     5967   217088     1188             0 php-fpm
[72420.250265] [  11168]    33 11168    70683     4875   204800     1124             0 php-fpm
[72420.250268] [  11170]    33 11170    70683     4927   204800     1092             0 php-fpm
[72420.250270] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/mariadb.service,task=mariadbd,pid=9464,uid=973
[72420.250356] Out of memory: Killed process 9464 (mariadbd) total-vm:673424kB, anon-rss:21572kB, file-rss:128kB, shmem-rss:0kB, UID:973 pgtables:712kB oom_score_adj:0
Recent activity:
[root@web3 cbrake]# journalctl --since -7d | grep "invoked oom-killer"
Feb 01 17:26:25 web3 kernel: systemd-timesyn invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 02 16:59:32 web3 kernel: sshd invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 02 17:00:05 web3 kernel: siot invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 03 14:01:19 web3 kernel: systemd invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 04 06:27:45 web3 kernel: siot invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 06 01:08:39 web3 kernel: php-fpm invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 06 01:09:01 web3 kernel: sshd invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=-1000
Feb 06 02:49:31 web3 kernel: mariadbd invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 06 02:50:02 web3 kernel: systemd-journal invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=-250
Feb 06 10:13:19 web3 kernel: siot invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 06 10:14:22 web3 kernel: mariadbd invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 07 06:46:47 web3 kernel: sshd invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 07 06:47:38 web3 kernel: systemd invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 07 06:48:39 web3 kernel: siot invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
Feb 07 06:48:47 web3 kernel: mariadbd invoked oom-killer: gfp_mask=0x140dca(GFP_HIGHUSER_MOVABLE|__GFP_COMP|__GFP_ZERO), order=0, oom_score_adj=0
php-fpm CPU spikes, but everything else looks pretty flat.
This problem could likely be solved very easily by adjusting the php-fpm setup, but I’m using this as an exercise to learn how to instrument things better. The next task is to collect metrics from Caddy:
Should I spin up a Prometheus instance, or add metrics scraping to SIOT? It would be nice to have everything in one system (SIOT), but Prometheus also has some nice advantages.
Antispam Bee
This plugin is amazing - it seems to knock out most spam on my site.
WordPress 7.0 released
