Interesting presentation about distributed systems:
Peter does a good job a simplifying the programming task down to two categories:
- stuff that can be implemented in pure functions
- stuff that has uncertainties (interaction points) that must be implemented using imperative methods
This is a helpful framework for thinking about programming.
A few more notes:
- functional programming is powerful, but it can’t interact with the real world
- write most of the program in functional programming, and add small pieces of imperative programming only in those places that interact with the real world
- Lamda calculus
- final result of a reduction is the same for all reduction orders
- keep mostly pure with a few interaction points
- examples of interaction points
- mutable state
- non-determinism where you wait for several things
- failure
- Eventual consistency database replica example
- Removing interaction points
- eventual consistency, several ways
- use strong consistency (quorums). Give up performance
- use convergent consistency (CRDTs)
- use monotonic writes instead of arbitrary writes
- add information – order does matter
- convergent consistency
- reads observe previous writes
- successive reads observe increasing set of writes
- writes applied after observed reads
- better then eventual consistency
- Principles of Eventual Consistency by Sebastian Burckhardt (highly recommended book)
Elm seems to do a good job following these principles – interaction points with the real world (http, ports, etc) are very controlled and kept to a minimum.
