“Upstream First?” – perhaps the most important question you should ask your Embedded Linux platform supplier.
Otherwise, you may be stuck in the following scenarios:
- the vendor never updates the BSP, and you are stuck using EOL Yocto and Kernel.
- you need features in a newer version of
systemd, Qt, or a host of other complicated software stacks and have no practical way to get there. - You need a USB peripheral driver only available in a newer kernel version
- And the most important reason …
… it is much easier to use Yoe with BSP support on upstream or at least recent releases.
Two examples:
https://www.toradex.com/blog/upstream-first-mainline-kernel-support-is-reality
