Someone pointed this out recently:
The author has a nice writeup:
This is very interesting to me as I’ve been looking for an embedded time series store for SIOT.
Since I’ve also been pondering the point data format in SIOT, I was very interested in the data types used in the this database. The below is from the tstorage-server wrapper that allows the Db to be used by multiple processes.
message TimeSeriesDatum {
string metric = 1;
repeated Label labels = 2;
double value = 3;
google.protobuf.Timestamp timestamp = 4;
From the Go API itself, we find the same thing:
type Row struct {
// The unique name of metric.
// This field must be set.
Metric string
// An optional key-value properties to further detailed identification.
Labels []Label
DataPoint
type DataPoint struct {
// The actual value. This field must be set.
Value float64
// Unix timestamp.
Timestamp int64
type Label struct {
Name string
Value string
The search API is simple:
type Reader interface {
// Select gives back a list of data points that matches a set of the given metric and
// labels within the given start-end range. Keep in mind that start is inclusive, end is exclusive,
// and both must be Unix timestamp. ErrNoDataPoints will be returned if no data points found.
Select(metric string, labels []Label, start, end int64) (points []*DataPoint, err error)
I’m guessing there is currently no indexing of labels (like InfluxDB tags).
Overall, looks like a very interesting project.
