another change is that module mode is default for building now. So we should look at changing simpleiot to use this build mode.
Are you talking about the Go 1.16 module changes?
https://blog.golang.org/go116-module-changes
What changes do you suggest for the SIOT build?
right. I meants if we still used GOPATH method to build.
Good point – took a look and found we still had some GOPATH stuff that does not appear to be used, so I cleaned it out:
