“How often have I said to you that when you have eliminated the impossible, whatever remains, however improbable, must be the truth?”
― Arthur Conan Doyle, [The Sign of Four]
Debugging hardware or software problems is often a challenging exercise because you can’t see what is going on for many reasons. Some of them include:
- There are millions of lines of code running and you can’t understand or single step through all of them.
- You can’t see what is going on inside integrated circuits or complex PCB boards.
- Modern systems have many things happening concurrently, and sometimes it is the interaction of these where the problem lies.
- Modern computer systems run very fast.
- Humans tend to overlook the simple, obvious solutions.
When faced with debugging a problem in a complex system, it helps to narrow the scope of the problem. If possible, test things in isolation. Eliminate one option at a time until you are left with a limited subset of possibilities. What is left is likely the problem.
