Selecting a programming language
Excellent article on Go:
https://drewdevault.com/2021/04/02/Go-is-a-great-language.html#fn:1
This stands out:
Go is also notable for essentially inventing its own niche, and then helping that niche grow around it into an entirely new class of software design. I consider Go not to be a systems programming language — a title much better earned by languages like C and Rust. Rather, Go is the best-in-class for a new breed of software: an Internet programming language.
It took me a while to understand this. It was a mistake for Go to be marketed as a systems language. Any systems programmer would rightfully tell you that a language with a garbage collector and magic cooperative/pre-emptive threads is a non-starter for systems programming. But, what Go was really designed for, and is mainly used for, is not exactly systems programming. Internet-facing code has straddled the line between systems programming and high-level programming for a while: high-performance systems software would often be written in, say, C — which is definitely a systems programming language — but the vastness of the Internet’s problem space also affords for a large number of programs for which a higher-level programming languages are a better fit, such as Java, C#, etc — and these are definitely not systems programming languages. Go is probably the first language to specifically target this space in-between with this degree of success, and it kind of makes a new domain for itself in so doing: it is the first widely successful “Internet programming language”.
An “Internet programming language” – that is an excellent description, and why Go is an excellent choice for implementing IoT systems – both in the cloud and at the edge.
