AWS had an outage on Act 20th caused by a routine update for DynamoDB disrupted internal DNS services.
Root Cause
- The problem began when a routine API update for DynamoDB inadvertently disrupted internal DNS services, which translate domain names into IP addresses for AWS’s internal communication between services.
- This caused widespread DNS lookup failures, preventing various AWS components from locating the DynamoDB endpoints required to authenticate and store data.
- AWS confirmed that the fault was entirely internal, not due to cyberattacks or external interference.
Problems like this come from where we least expect them. Systems are only as reliable as the weakest link, and usually that is a human somewhere …
More analysis:
https://www.perplexity.ai/search/how-long-was-the-aws-outage-on-dkLfX4nCSgeepjSyuD3RFg?0=d#0
