I am starting to cringe every time I delve into a project that depends on a lot of NPM packages. For example:
gyp info using node@14.18.3 | linux | x64
gyp verb command rebuild []
gyp verb command clean []
gyp verb clean removing "build" directory
gyp verb command configure []
gyp verb check python checking for Python executable "python2" in the PATH
gyp verb `which` failed Error: not found: python2
gyp verb `which` failed at getNotFoundError (/home/cbrake/.meteor/packages/fourseven_scss/.3.13.0.h12rr5.cgxlt++os+web.browser+web.cordova/plugin.compileScssBatch.os/npm/node_modules/meteor/compileScssBatch/node_modules/which/which.js:13:12)
gyp verb `which` failed at F (/home/cbrake/.meteor/packages/fourseven_scss/.3.13.0.h12rr5.cgxlt++os+web.browser+web.cordova/plugin.compileScssBatch.os/npm/node_modules/meteor/compileScssBatch/node_modules/which/which.js:68:19)
gyp verb `which` failed at E (/home/cbrake/.meteor/packages/fourseven_scss/.3.13.0.h12rr5.cgxlt++os+web.browser+web.cordova/plugin.compileScssBatch.os/npm/node_modules/meteor/compileScssBatch/node_modules/which/which.js:80:29)
gyp verb `which` failed at /home/cbrake/.meteor/packages/fourseven_scss/.3.13.0.h12rr5.cgxlt++os+web.browser+web.cordova/plugin.compileScssBatch.os/npm/node_modules/meteor/compileScssBatch/node_modules/which/which.js:89:16
gyp verb `which` failed at /home/cbrake/.meteor/packages/fourseven_scss/.3.13.0.h12rr5.cgxlt++os+web.browser+web.cordova/plugin.compileScssBatch.os/npm/node_modules/meteor/compileScssBatch/node_modules/isexe/index.js:44:5
gyp verb `which` failed at /home/cbrake/.meteor/packages/fourseven_scss/.3.13.0.h12rr5.cgxlt++os+web.browser+web.cordova/plugin.compileScssBatch.os/npm/node_modules/meteor/compileScssBatch/node_modules/isexe/access.js:8:5
gyp verb `which` failed at FSReqCallback.oncomplete (fs.js:179:23)
gyp verb `which` failed python2 Error: not found: python2
gyp verb `which` failed at FSReqCallback.oncomplete (fs.js:179:23) {
gyp verb `which` failed code: 'ENOENT'
gyp verb `which` failed }
gyp verb check python checking for Python executable "python" in the PATH
gyp verb `which` succeeded python /usr/bin/python
gyp verb check python version `/usr/bin/python -c "import platform; print(platform.python_version());"` returned: "3.10.2\n"
gyp ERR! configure error
gyp ERR! stack Error: Python executable "/usr/bin/python" is v3.10.2, which is not supported by gyp.
gyp ERR! stack You can pass the --python switch to point to Python >= v2.5.0 & < 3.0.0.
gyp ERR! stack at failPythonVersion (/home/cbrake/.meteor/packages/fourseven_scss/.3.13.0.h12rr5.cgxlt++os+web.browser+web.cordova/plugin.compileScssBatch.os/npm/node_modules/meteor/compileScssBatch/node_modules/node-gyp/lib/configure.js:454:14)
gyp ERR! stack at /home/cbrake/.meteor/packages/fourseven_scss/.3.13.0.h12rr5.cgxlt++os+web.browser+web.cordova/plugin.compileScssBatch.os/npm/node_modules/meteor/compileScssBatch/node_modules/node-gyp/lib/configure.js:443:9
gyp ERR! stack at ChildProcess.exithandler (child_process.js:374:7)
gyp ERR! stack at ChildProcess.emit (events.js:400:28)
gyp ERR! stack at maybeClose (internal/child_process.js:1058:16)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
gyp ERR! System Linux 5.16.2-arch1-1
The stack of build tools you might find in any random NPM package is astounding …
