Neovim 0.9.0 isolated configurations
Neovim 0.9.0 introduced the ability to have isolated configs. For example to try LazyVim:
git clone https://github.com/LazyVim/starter ~/.config/LazyVim
NVIM_APPNAME=LazyVim nvim
NVIM_APPNAME                                    $NVIM_APPNAME
  The XDG directories used by Nvim can be further configured by setting the
  $NVIM_APPNAME environment variable. This variable controls the directory
  Neovim will look for (and auto-create) in the various XDG parent directories.
  For example, setting $NVIM_APPNAME to "neovim" before running Neovim will
  result in Neovim looking for configuration files in $XDG_CONFIG_HOME/neovim
  instead of $XDG_CONFIG_HOME/nvim.
  Note: Similarly to the $XDG environment variables, when
  $XDG_CONFIG_HOME/nvim is mentioned, it should be understood as
  $XDG_CONFIG_HOME/$NVIM_APPNAME.
  LOG FILE                                        log $NVIM_LOG_FILE E5430
  Besides 'debug' and 'verbose', Nvim keeps a general log file for internal
  debugging, plugins and RPC clients.
          :echo $NVIM_LOG_FILE
  By default, the file is located at stdpath("log")/log unless that path
  is inaccessible or if $NVIM_LOG_FILE was set before startup.
Speaking of LazyVim, it is amazing – more on that later …
+1 for lazyvim I have switched to using it few months back and never looked back and contrary to its name it’s fast too :slightly_smiling_face:
