https://www.kernel.org/doc/html/latest/maintainer/rebasing-and-merging.html
TLDR: don’t be afraid of merge commits, but avoid re-parenting and back merges when you can.
Quotes:
One thing to be aware of in general is that, unlike many other projects, the kernel community is not scared by seeing merge commits in its development history. Indeed, given the scale of the project, avoiding merges would be nearly impossible. Some problems encountered by maintainers result from a desire to avoid merges, while others come from merging a little too often.
History that has been exposed to the world beyond your private system should usually not be changed. Others may have pulled a copy of your tree and built on it; modifying your tree will create pain for them. If work is in need of rebasing, that is usually a sign that it is not yet ready to be committed to a public repository.
Do not reparent a tree without a good reason to do so. Just being on a newer base or avoiding a merge with an upstream repository is not generally a good reason.
Merging is a common operation in the kernel development process; the 5.1 development cycle included 1,126 merge commits - nearly 9% of the total. Kernel work is accumulated in over 100 different subsystem trees, each of which may contain multiple topic branches; each branch is usually developed independently of the others. So naturally, at least one merge will be required before any given branch finds its way into an upstream repository.
Many projects require that branches in pull requests be based on the current trunk so that no merge commits appear in the history. The kernel is not such a project; any rebasing of branches to avoid merges will, most likely, lead to trouble.
It is natural to want to merge the master branch into a repository; this type of merge is often called a “back merge”. Back merges can help to make sure that there are no conflicts with parallel development and generally gives a warm, fuzzy feeling of being up-to-date. But this temptation should be avoided almost all of the time.
Why is that? Back merges will muddy the development history of your own branch. They will significantly increase your chances of encountering bugs from elsewhere in the community and make it hard to ensure that the work you are managing is stable and ready for upstream. Frequent merges can also obscure problems with the development process in your tree; they can hide interactions with other trees that should not be happening (often) in a well-managed branch.
