Interesting article on distributed systems.
Back-pressure is about pushing work to the edges, letting the ends of the conversation find stability, rather than trying to optimise all of the links in-between in isolation. Congestion control is about using back-pressure to keep the queues in-between as empty as possible, to keep latency down, and to increase throughput by avoiding the need to drop packets.
Pushing work to the edges is how your system scales. We have spent a lot of time and a considerable amount of money on IP-Multicast, but nothing has been as effective as BitTorrent. Instead of relying on smart routers to work out how to broadcast, we rely on smart clients to talk to each other.
Pushing recovery to the outer layers is how your system handles failure. In the earlier examples, we needed to get the client, or the scheduler to handle the lifecycle of a task, as it outlived the time on the queue.
Error recovery in the lower layers of a system is an optimisation, and you can’t push work to the centre of a network and scale. This is the end-to-end principle, and it is one of the most important ideas in system design.
The end-to-end principle is why you can restart your home router, when it crashes, without it having to replay all of the websites you wanted to visit before letting you ask for a new page. The browser (and your computer) is responsible for recovery, not the computers in between.
This isn’t a new idea, and Erlang/OTP owes a lot to it. OTP organises a running program into a supervision tree. Each process will often have one process above it, restarting it on failure, and above that, another supervisor to do the same.
A protocol is the rules and expectations of participants in a system, and how they are beholden to each other. A protocol defines who takes responsibility for failure.
The problem with message brokers, and queues, is that no-one does.
The main task of the engineering analyst is not merely to obtain “solutions” but is rather to understand the dynamic behaviour of the system in such a way that the secrets of the mechanism are revealed, and that if it is built it will have no surprises left for [them]. Other than exhaustive physical experimentations, this is the only sound basis for engineering design, and disregard of this cardinal principle has not infrequently lead to disaster. – From “Analysis of Nonlinear Control Systems” by Dustan Graham and Duane McRuer, p 436
