I thought of just trying to bring up my Coral dev board with something off the net. First thing I’ve attempted is following the instructions here: Quick start guide · mirzak/meta-coral Wiki · GitHub
Things are broken for the latest Arch packages. The build requires python V2 (python2.7 to be exact) but python2 is no longer supported in the mainstream Arch repositories. I had a little better luck with an Ubuntu 22.04 distro as its packages are not as cutting edge as Arch, but ran into a problem during the compile process which I have yet to troubleshoot. Just to get bitbake to run required modification of several python files in sources/poky/bitbake/lib/bb because of recent changes to Python 3.
Those instructions are based on Zeus release of yocto which is already EOL I think once we add it to yoe distro we might be getting a more modern version of support for the coral board
The Yocto images above will not compile on an up to date version of Arch without using docker. The Google provided Mandel OS image works but there are issues getting the Google demos running on my Coral board. The Coral dev board seems to be unusually picky about micro SD cards used for initial flashing. Be sure to have several on hand in case the first one doesn’t work. Also for Linux don’t follow google’s instructions for creating the uSD card, simply write the ‘flashcard_arm64.img’ file to the uSD card using dd.
Coral Dev board is booting Yoe and running 5.15 kernel
coral-dev login: root
Last login: Tue Dec 20 18:15:54 UTC 2022 on ttymxc0
root@coral-dev:~# cat /proc/version
Linux version 5.15.78-fslc+g97c2965ca430 (oe-user@oe-host) (aarch64-yoe-linux-gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0.20220819) #1 SMP PREEMPT Sun Nov 13 15:09:41 UTC 2022
