Go tip: how to set a return value in a deferred function
Learned something new today from the Applied Go Newsletter – you can set a return value in a deferred function used named parameters:
package main
import "fmt"
func outerFunction() (err error) {
	defer func() {
		// do some cleanup
		if true /* cleanup has failed */ {
			err = fmt.Errorf("cleanup failed")
	return err
func main() {
	fmt.Println(outerFunction())
Without a named parameter, there is no way for a deferred function to access the return values.
