Diagrams.net (draw.io)
I took another look at diagrams.net. Seems like a well established solution for block diagrams. It also supports a sketch mode so with a graphics tablet, you can easily mix standard shapes and hand sketches (see below for an example).
The reason for the transition from draw.io to diagrams.net is documented here.
Draw.io is integrated with a number of other apps – I’ve used the VSCode integration in the past.
There is also a desktop version (Electron based) which is handy. For Arch Linux, install drawio-desktop-bin from the AUR.
I’ve been comparing to a similar app named pencil. Some differences I’ve noticed:
  • draw.io can group items for easy duplicating
  • draw.io seems to have better controls for aligning elements to other elements.
One thing that is useful is to group objects inside other objects. In draw.io, you can turn any object into a group by selecting arrange->group in the menu – then everything inside is treated as a group. See example below:
I found another interesting tool
Back to using draw.io
I’ve been using Excalidraw for most drawings in recent history, but I’m back to draw.io for several reasons:
  • I need to do another presentation.
  • While the infinite canvas in Excalidraw is neat, practically I don’t end up reusing much.
  • I like the drawing better in draw.io – this is a person thing, just fits my style better. Arrows in block diagrams are so much better.
  • I like how draw.io draws look – a little more professional.
  • I like the included icon set in draw.io.
  • If I always start with a 900x500 (9”x5”) drawing, the resulting PNG export is always about the right size for emails, blog posts, etc without any scaling.
  • Unless I’m doing a presentation, I’ve reverted my idea to put a bunch of diagrams in one file on separate pages. Now I’m doing one file per drawing, and always exporting a PNG in the same directory. This allows me to quickly browse and find drawings. If I need to copy something, it is easy enough to open the file.
  • With my workflow of exporting a PNG with every drawing, I have images ready to go to include in my newsletter, etc.
  • Draw.io has a neat feature where you can embed the drawing in a PNG file. Then anyone can drag the PNG file into draw.io and edit it. So going forward, feel free to reuse/modify any of the images I’m posting in my newsletter, blog, etc.
  • Claude code works pretty well with Draw.io.
Tips for use
  • start with 900x500 (9”x5”) page size – this is about perfect for most media uses.
  • use 45pt text for titles
  • use 25pt text for text in slides
  • use 16pt text for icon/arrow labels
  • for arrow connectors, set width to 2 pt, rounded corners, and some color other than black
Also tried Canva
I also took at little diversion into Canva. It is a nice tool – very fast and produces nice results. It can also do presentations. For a bit, I was thinking this was the path forward, but then I realized draw.io can do about everything I need Canva for. Some other tradeoffs:
  • With draw.io, I own my data and can reuse it at any point in the future without depending on the cloud service.
  • At some point I’m sure I’d outgrow the Canva free plan, and not really look for more subscriptions to pay for indefinitely.
  • My default setup of draw.io exports PNGs at a perfect size for media. With Excalidraw and Canva, seems like I’m always having to set scaling factors in Markdown files.
  • Exporting PNGs allows me to browse drawings similar to the Canva
  • Canva includes a lot of images, templates, etc. – clearly the winner here.
  • I like the way draw.io connects items for diagramming.
