We are exploring using D-Bus for a project, so collecting some notes about it.
Overview
The D-bus specification is located:
https://dbus.freedesktop.org/doc/dbus-specification.html
This article is pretty good:
It appears D-Bus is fairly highly regarded:
Today, if we’d sit down and design a completely new IPC system incorporating all the experience and knowledge we gained with D-Bus, I am sure the result would be very close to what D-Bus already is.
From Lennart’s article, we can extract the following:
- D-Bus concepts
- buses
- system bus
- session bus
- object path – ex:
/org/freedesktop/login1/session/_7. Objects have one or more interfaces.- interfaces – contains the following members
- methods – functions
- signals
- properties
- buses
- Features
- access control
- rich type system
- discoverability
- introspection
- monitoring
- reliable multicasting
- service activation
- file descriptor passing
C library options:
- libdbus: original low-level implementation
- GDBus: newer implementation built around GObject. Uses code-generation.
- sd-bus: middle ground between libdbus and GDBus. Better performance.
- qtdbus: may be useful if you are writing Qt code.
