Comparison of RTC Chips
This post is a comparison of various RTC chips supported by Zephyr.
We get a list of supported chips from the Zephyr build system:
  • am1805
  • ambiq
  • ds1307
  • emul
  • fake
  • ifx_cat1
  • mc146818
  • pcf8523
  • pcf8563
  • rpi_pico
  • rv3028
  • sam
  • smartbond
  • stm32
  • numaker
  • rv8263
  • xmc4xxx
  • nxp_irtc
Many of these are embedded RTCs inside MCU chips. Initially, we’ll focus on external RTCs. Most of the below, except for RV-3028 require a separate external crystal.
Part # Manufacturer Cost (100 pcs) Interface Accuracy Power Notes
AM1805 Ambiq $0.65 I2C 2 ppm 22nA Watchdog timer with hardware reset, 256 bytes ram, auto-calibrates internal osc from xt to achieve lower power
DS1307 Analog Devices $3.23 I2C ??? 300nA
PCF8523 NXP $0.82 I2C ??? 150mA
RV-3028-C7 Micro Crystal $1.35 I2C ±1 ppm @ 25°C 45nA integrated RTC + Crystal in single module
RV-3032-C7 Micro Crystal $1.73 I2C -40°C to +85°C, ±2.5 ppm 160nA integrated RTC + Crystal in single module. Temperature compensated. Integrated temp sensor readable over I2C.
Supercap calculations
Sometimes it is desirable to run a RTC from a supercap so you don’t have to worry about issues with battery going bad, etc. Below is a comparison of one range of options. The life assumes we will discharge the cap from 3.3V to 1V @ 45nA. The formula is:
Cap (F) Part # Size (mm) Cost (qty: 100) Run time (days)
0.47 PHVL-3R9V474-R 9 x 17.3 x 14.5 $5.11 277
1.5 PHVL-3R9V155-R 9 x 17.3 x 22 $3.56 594
2.5 PHVL-3R9V255-R 11 x 21.3 x 23 $3.92 1,479
3.0 PHVL-3R9V305-R 9 x 17.3 x 32.5 $4.07 1,775
5.0 PHVL-3R9V505-R 11 x 21.3 x 32.5 $4.14 2964
That RV-3028 RTC is quite impressive! I hadn’t seen that chip before, thanks!
But there’s quite a few supercaps available at normal retail distributors, like Digi-Key, which come in quite a bit less expensive than your examples if you’re able to accept a bit higher ESR (equiv series resistance), which should be fine for an RTC circuit drawing <1uA. For example, CDA’s CE5R5105HF-ZJ is a 1F 5.5V coin shape supercap for $0.84/ea for qty 100, but the internal resistance is around 30ohms.
Am I misunderstanding something about supercap selection such that this CDA part wouldn’t be reasonable to choose for an RTC circuit?
We have the RV-3028 on a few prototypes now, and seems to be working well. Amazing level of integration and even has supercap charging built in!
Thanks for the pointer to the CE5R5105HF-ZJ. That looks like a great fit for an RTC cap.
I assume the 1000 hours means it will hold a charge for that long without self-discharging? Self-discharge is probably the dominant factor with a supercap as the RTC draw is so low.
1000 hours is 41 days.
For the PHVL-3R9V155-R, the lifetime is listed as 0.6 to 2 years:
I assume “endurance” and “lifetime” mean how long the supercap will keep a charge. If these are equivalent, then the more expensive caps do have a significant advantage if you have a scenario where you want to set the time during manufacturing, and have it be valid during installation up do a year later. If you don’t need that, then the cheaper ones seem like a good option.
While lifetime endurance is important, self-discharge is what I was really looking for. The leakage current for the 1.5F PHLV cap is only 2uA - which is relatively insignificant compared to the current consumed by most RTCs.
Affect of temperature on crystals
I met with a few of the Micro Crystal folks today and learned a lot. Namely, temperature significantly affects crystal accuracy. For the RV-3028-C7:
So at 60C, we have 40ppm instead of 1ppm.
On the other hand, the RV-3032-C7 has temperature compensation built-in, and is rated for ±2.5 ppm from -40°C to +85°C (the red line below).
Additionally, with the RV-3032-C7, you can read the built-in temperature sensor over I2C, eliminating the need for a separate temperature sensor on the board.
The RV-3032 draws more current (160nA vs 45nA in the RV3028), but it also has a built-in charge pump so it can charge super-caps up to 3V or 4.5V, allowing you to store more energy in the super-cap. Measurements here indicate the RV3028 only charges a super-cap up to 2.86V.
Whitepaper about RTC backup calculations
Some more information from Micro Crystal:
