Many of us have powerful workstations/computers running a good bit of the time that could be doing more useful work. We don’t have to deploy everything to the cloud. Tasks to consider running locally include:
- backup scripts
- maintenance scripts
- CI/CD processes – especially those that require a lot of CPU power to run
We often don’t set up local services because it is tedious, and we don’t have a good way to automate it – especially across different users. If you are already using Ansible for server deployment, consider also using it to set up Systemd user services on your local machine. The advantages of this include:
- don’t need root
- automatically start when you log in
- can leverage all your Ansible/Systemd knowledge you already have at the user account level
- potentially more secure as workstations are behind firewalls and not directly accessible on the Internet
A few notes/tips:
- user systemd services are stored in
~/.config/systemd/user - add
--userto systemd commands. Examples:systemctl --user start myservicejournalctl --user -f -u myservice
- use
%hto expand to home directory in systemd services. - use the
default.targetin user services
Example Systemd user service.
backup.service:
[Unit]
Description=backup service
[Service]
Environment=GOOGLE_APPLICATION_CREDENTIALS=%h/keys/backup-key.json
ExecStart=%h/bin/backup -retentionService
RestartSec=10
Restart=always
[Install]
WantedBy=default.target
Restart=always
[Install]
Local Ansible Playbook
A local role playbook might look something like:
local.yml:
- name: Playboop for localhost
hosts: localhost
roles:
- backup-retention
And to run: ansible-playbook local.yml
Because it is localhost, no inventory file is needed.
Deploying to your local computer is the simplest scenario possible. And when possible, keep-it-simple!
