A build system is a lot of small pieces — feeds, units, dependencies, task
steps, sandboxes. None of it is hard on its own. The hard part is holding all of
it in your head at once, which is exactly what humans are bad at and agents are
good at. The latest video shows how [yoe] uses
that: it ships Claude Code skills you install into your project, and wires a
diagnose step into the build loop.
This is a companion discussion topic for the original entry at https://yoebuild.org/blog/ai-integration/
