if we disable updater then then we can build SD card wic image. Updater for imx8 will need some work as it seems, which we expected.
I got image (without updater) built for imx8qm-var-som
For a challange I said lets try with
YOE_PROFILE ?= "yoe-musl-systemd-wayland"
and it all came along nicely. Ofcourse I have patches for meta-freescale proposed already for merge.
Great progress! Now, to figure out how load up an SD card for this thing …
Loaded yoe-simple-image wic file on a SD card and it boots:
Yoe Linux 2022.08 imx8qxp-var-som ttyLP3
imx8qxp-var-som login: root
root@imx8qxp-var-som:~#
Next, working on LVGL recipe for their demo app, and trying some other graphical stuff …
Build and installed yoe-kiosk-image, and weston/wayland is working. Also appears egl tests are working:
root@imx8qxp-var-som:~# export XDG_RUNTIME_DIR=/run
root@imx8qxp-var-som:~# export WAYLAND_DISPLAY=wayland-0
root@imx8qxp-var-som:~# weston-simple-dmabuf-egl
root@imx8qxp-var-som:~# weston-simple-egl
has EGL_EXT_buffer_age and EGL_EXT_swap_buffers_with_damage
302 frames in 5 seconds: 60.400002 fps
301 frames in 5 seconds: 60.200001 fps
The i.MX8X CPU I’m using here does not have a heatsink installed yet (it came with one). I’m not pushing it hard right now, and the case is warm – just under the threshold of being too hot to keep my finger on it for a long time – probably just under 50degC. MX8 devices will definitely need some thought in the thermal design, unlike the i.MX6UL which runs cool. Heatsinking to a metal case is probably a good option.
I have observed that all arm64 cores based CPUs run hotter compared to 32bit ones and I do agree a better heatsink mechanism would go long way.
VAR-SOM-MX8x support has been merged into yoe/master
. @collinbrake give it a try and let us know how it goes. I’ve added instructions for flashing SD card above. Will work on the updater next so we can program eMMC.
only have 4 cores on unit here:
The original image might still be in flash, you could try booting that and see if you see the same thing.
This is an interesting discussion:
Wifi is brcm
root@imx8qm-var-som:~# dmesg | grep brcm
[ 4.766997] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac4339-sdio.bin for chip 0x004339(17209) rev 0x000002
[ 5.006553] brcmfmac mmc2:0001:1: Falling back to user helper
[ 5.016806] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available(err=-11), device may have limited channels available
[ 5.027290] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Jun 26 2018 01:58:05 version 6.37.39.94 (r692107 CY)
root@imx8qm-var-som:~# lsmod
Module Size Used by
rfcomm 49152 16
hci_uart 20480 1
bnep 20480 2
brcmfmac 253952 0
cfg80211 307200 1 brcmfmac
brcmutil 16384 1 brcmfmac
bluetooth 372736 38 hci_uart,bnep,rfcomm
ecdh_generic 24576 1 bluetooth
cdns3 49152 0
xhci_hcd 135168 1 cdns3
ci_hdrc_imx 20480 0
ci_hdrc 61440 1 ci_hdrc_imx
phy_generic 16384 1
ehci_hcd 57344 1 ci_hdrc
udc_core 28672 2 cdns3,ci_hdrc
leds_gpio 16384 0
led_class 16384 1 leds_gpio
gpio_keys 20480 0
flexcan 24576 0
usbcore 245760 4 xhci_hcd,cdns3,ehci_hcd,ci_hdrc
fec 61440 0
usbmisc_imx 24576 1 ci_hdrc_imx
usb_common 16384 4 usbcore,cdns3,ci_hdrc,udc_core
mousedev 20480 0
can_dev 24576 1 flexcan
extcon_ptn5150 16384 0
ads7846 20480 0
spidev 20480 0
galcore 430080 23
ipv6 376832 50
autofs4 36864 0
Firmware
/lib/firmware/brcm
/lib/firmware/brcm/brcmfmac4339-sdio.txt
/lib/firmware/brcm/brcmfmac4339-sdio.bin
/lib/firmware/LICENCE.broadcom_bcm43xx
/lib/firmware/imx
/lib/firmware/imx/sdma
/lib/firmware/imx/sdma/sdma-imx7d.bin
/lib/firmware/imx/sdma/sdma-imx6q.bin
/lib/firmware/vpu
/lib/firmware/vpu/vpu_fw_imx8_dec.bin
/lib/firmware/vpu/vpu_fw_imx8_enc.bin
/lib/firmware/bcm
/lib/firmware/bcm/bcm4339.hcd
/lib/firmware/LICENSE.QualcommAtheros_ath10k
/lib/firmware/ath10k
ath10k firmware is unused I think on symphony board.
kernel modules
/lib/modules/4.14.98-imx8qm+g3405fb6/kernel/drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.ko
/lib/modules/4.14.98-imx8qm+g3405fb6/kernel/drivers/net/wireless/broadcom/brcm80211/brcmutil/brcmutil.ko
/lib/modules/4.14.98-imx8qm+g3405fb6/kernel/net/wireless/cfg80211.ko/lib/modules/4.14.98-imx8qm+g3405fb6/kernel/net/wireless/cfg80211.ko
Thanks for capturing this – so brcm is Broadcom …
The Yoe distribution now supports three of the Variscite i.MX8 SOMs:
- VAR-SOM-MX8
- VAR-SOM-MX8X
- VAR-SOM-MX8M-NANO (will be merged shortly)
Below is the nano running qtwebengine with Weston keyboard:
We can start weston with kiosk-shell. Follow these steps.
On a booted system
sed -e 's|^[#]shell=.*$|shell=kiosk-shell.so|g' /etc/xdg/weston/weston.ini
systemctl daemon-reload
systemctl restart weston
Now you can launch any app from ssh shell.
If you want to start an application and it will be in fullscreen mode.
Hello Mr. Brake, hello Mr. Raj
We are developing using the VAR_SOM_MX8 (nxp iMX8QM based variscite SoM + Symphony carrier board, exactly the dev kit you are showing into the picture).
I have seen you are among the few people developing with such a SoM so I have some questions for you.
For you information, we are releasing a product based on a custom solution (designed by us) derived from the NXP dev Kit iMX8QM-MEK but we want to migrate on a solution derived from VAR_SOM_MX8 + Synphony. We are stack on the following topics:
- how to indentify and enable the UART port for debugging the scfw;
- how to indentify and enable the UART port for debugging the core0 real time firmware;
- how to indentify and enable the UART port for debugging the core1 real time firmware;
Do you have such an info?
we will thank you in advance in any case.
Best regards
FG
+39 335 8350919
Photo of the Variscite MX8 SOMs we support in the Yoe Distribution – small, medium, and large!
- VAR-SOM-Mx8M-NANO (NXP i.MX 8M Nano, starts at $44)
- VAR-SOM-MX8X (NXP iMX8X, starts at $79)
- VAR-SOM-MX8 (NXP iMX8 QuadMax / QuadPlus, starts at $134)
All of these SOMs have been run in a single Variscite Symphony development baseboard, as well as in custom hardware. The work we do on one complements the others.
