Interesting that even though the author is focused on Rust, he does note a number of things Go is doing well. It’s all the little things that add up to the total experience.
Drew Devault came with this announcement on Hare system programming Language, I think the approach is good, they are improving C incrementally, I think the tilt to use strong point of go is also quite good. So now we have, rust , go, julia, zig and now hare to keep peeking into ![]()
Seems like Hare and Zig have a lot in common …
here is IEEE spectrum article on programming languages in 2022 and SQL seems to be demand
Interesting – this survey might be more from a engineering perspective (IEEE) vs SW developer, which tends to be JS heavy. Interesting that Python still came out at the top with this audience. Some places engineers may use Python: general scripting, KiCad, Juypter Notebook.
I’m still climbing back up the SQL curve, but it seems important. This quote from wikipedia article is interesting:
Originally based upon relational algebra and tuple relational calculus, …
Seems things based on Math are a little more grounded.
I’ve come to appreciate the simplicity of two dimensional tables compared to a deeply nested JSON object. Yes, the constraints of a flat table are more difficult to work with initially, but long term you reap many benefits in that tables are more flexible. Flat constraints also encourages simpler data structures, which is generally good. A few simple/flexible data structures is much better than a proliferation of complex data structures.
Why Zig in Ghostty
From this interview with the author of Ghostty:
"My answer to this makes everyone mad, because programmers want an answer that is based on some theory, or safety, or something, and my answer is just – I have fun writing Zig and I do not have fun reading or writing Rust, and that is my #1 motivating factor – if I’m going to type, read, and debug this stuff every single day, I want to have fun. And whenever I’ve experienced reading or writing Rust, all I’m doing is implementing traits, and jumping between files trying to figure out what **** is a trait. And I do not have fun doing that.
“I don’t think I could write Go again right now …”
The Roc language compiler is currently written in Rust, but they are switching to Zig:
This document is a nice review of the tradeoffs you get with different languages. There is no perfect language that does everything best – it is always tradeoffs.
It may seem like I’m bashing Rust a lot in this thread – perhaps I am
as I have an aversion to complexity unless it is really needed. That said, I use a large number of tools now that are written in Rust – they are fast, stable, and a pleasure to use. It seems Rust encourages a neat mindset that is not found in the previous generation of command-line tools written in C. Rust is obviously very good for many things.
This is really good!
Instead of asking “which language is best?” we need to ask “what is this language going to cost us?” Not just in salaries, but in velocity, in technical debt, in hiring difficulty, in operational complexity, in every dimension that actually determines whether you survive.
Reframe it from a technical debate to an economic one. And unlike identity, economics can be measured, compared, and decided without anyone’s ego being threatened.
Choosing a programming language is the single most expensive economic decision your company will make. It will define your culture, constrain your budget, determine your hiring pipeline, set your operational costs, and ultimately dictate whether you can move fast enough to win your market.
Some thoughts in different thread that are relevant to this topic:
Very detailed but good one if you want an informed opinion -
