Outsource work to AI, not strategic thinking
Interesting thoughts from this discussion.
The bottom line is humans need to find things to do that AI can’t do. Is AI limited to just summarizing the Internet? I’m not sure, as it seems with larger models it is not doing things it was not explicitly trained to do. But I think the concept still holds.
Jonathan Stark: Yes. Well, it’s funny that you said chief of staff, because maybe I don’t understand what that title exactly means, having never had one. But you also said intern previously. And to me, the mental model, this is what maybe more so with soloists, I don’t know. But the mental model seems to be people trying to outsource the thinking, the high-level stuff that they’re actually good at, to an LLM versus the tedious administrative stuff.
Jonathan Stark: That no one probably wants to do at all. Right. And I absolutely use that intern metaphor all the time. It’s like an entry-level employee that needs to be treated with that kind of attitude, just from a security standpoint, from trusting the work output standpoint, from if they fall asleep on the job, because sometimes they just, like the server, nods off or falls over.
Interns versus chiefs of staff
Jonathan Stark: So they do need a little bit of handholding and management and babysitting. But it’s a lot less than doing the work of collating all of those inventory reports.
Shawn Yeager: Absolutely.
Jonathan Stark: Right. So, I think it’s a failure mode for someone who’s a high-level strategic thinker to try and outsource high-level strategic thinking to any of these models because it seems like they are trained on such a large pile of data that it’s almost for sure that they’re going to kind of regress to the mean.
Jonathan Stark: And strategy is almost like not allowed to do that, basically. It’s like, okay, you have to come up with some high-level approach to winning something by applying your strengths to weaknesses. It’s almost certainly going to be something no one else would have thought of or committed to, which you’re not going to find by summarizing the internet. By definition, it almost has to be novel.
Jonathan Stark: So just to wrap that, put a bow on that, the chief of staff thing, I don’t actually know what a chief of staff does, but it sounds like an executive level position. But if it’s an executive assistant, then okay. I’m not sure if the metaphor applies or not. If that’s true, then yes, I would agree. But if the chief of staff is someone that is applying a lot of judgment and has a lot of autonomy to make decisions on their own, I don’t know if it’s my favorite metaphor, but I’ve heard a lot of people using it.
