I’ve switched to this – pretty amazing – gets vim a lot closer to VSCode for ease of configuration. Still working on getting auto-formatters on save working …
Ran into an issue where colors outside of tmux were light, and inside tmux where dark. The nvim background
setting can be used to force it to be consistent:
vim.opt.background = "light"
I was trying to use GitHub - ethanholz/nvim-lastplace: A Lua rewrite of vim-lastplace for my lua conversion away from vim scripts but for life of me I could not get it to work.
I tried lastplace as well, and does not seem to be working. Do you have Telescope installed? I wonder if this applies?
here is my plugin customizations
% cat lua/custom/plugins/init.lua
-- You can add your own plugins here or in other files in this directory!
-- I promise not to create any merge conflicts in this directory :)
-- See the kickstart.nvim README for more information
return {
{ -- Put cursor at last place
'ethanholz/nvim-lastplace',
config = function()
require('nvim-lastplace').setup {}
end,
require('onedark').setup {
toggle_style_list = {'dark', 'darker', 'cool', 'deep', 'warm', 'warmer', 'light'}, -- List of styles to toggle between
toggle_style_key = '<space>ts',
'nvim-neo-tree/neo-tree.nvim',
branch = "v2.x",
dependencies = {
"nvim-lua/plenary.nvim",
"nvim-tree/nvim-web-devicons", -- not strictly required, but recommended
"MunifTanjim/nui.nvim",
config = function ()
-- Unless you are still migrating, remove the deprecated commands from v1.x
vim.cmd([[ let g:neo_tree_remove_legacy_commands = 1 ]])
require('neo-tree').setup {}
end,
