📚 Brian Kernighan: UNIX, C, AWK, AMPL, Go, Bell Labs, etc
Finished Brian’s book: UNIX, A History and a Memoir – excellent book – highly recommend! Bell Labs was an exceptional place and the world is different because of it. We can learn a lot from the culture. The ideas of openness, collaboration, freedom, etc were all ahead of its time. Today, some of this is likely manifest in open source projects today. However, the distraction factor is also much higher. The environment of Bell Labs where you could have collaboration and focus must have been amazing.
Some quotes that stood out to me (again, get the book and read it to get the full context):
  • This also led to our first rule of programming style: Write clearly – don’t be too clever.
  • He (Dick Hamming) used to say that Friday afternoons were for thinking great thoughts, so he sat back and thought, though he was always welcoming to visitors like me at any time.
  • By contrast (to university rankings which favored people with deep expertise in narrow fields), Bell Labs created a rand order for every researcher, from the bottom up. Each department head ranked his or her people; those rankings were merged by department heads within a center, and those in turn by the next two levels, so by the end everyone’s approximate position in the whole population was determined. A person who did great work in a narrow field might well be ranked highly by his or her immediate management, but no one further up would likely know of the work. Interdisciplinary work, on the other hand, stood out at higher levels because more managers would have seen it. The broader the collaborations, the more managers would know about it. The end result was an organization that strongly favored collaboration and interdisciplinary research. And because the managers who made the decisions had come up through the same process, they were inclined in the same direction.
  • As Doug McIlroy said, “Collegiality was the genius of the system. Nobody’s advancement depended on the relationship with just one boss.”
  • Ken Thompson wrote a significant part of the 1st Unix version in three weeks.
  • This is a good example of a general rule: if a program writes your code for you, the code will be more correct and reliable than if you write it yourself by hand. If the generator is improved, for example to produce better code, everyone benefits; by contrast, improvements to one hand-written program do no improve others. Tools like Yacc and Lex are excellent examples of this rule, and Unix provides many others as well. It’s always worth trying to write programs that write programs. As Doug McIlroy ways, “Anything you have to do repeatedly may be ripe for automation.”
  • How did this relatively small group of researchers from industry manage to produce so many influential books? I can see several reasons. First and foremost, people took writing seriously, they took pains with their own writing, and they were great critical readers of what other people wrote. Doug McIlroy was first among this group; no one else matched Doug’s ability to spot errors …
  • It may sound trivial, but I’m sure that the ability to make revisions so easily led to better writing, because it pretty much eliminated the overhead of making an up to date copy, and it completely eliminated middlemen like typists, editors and printers. Accuracy mattered for technical papers and for the Unix Programmer’s Manual, but control of the whole process especially mattered for books. For programming books, it was vital that the programs were typeset directly from the source code, so we could be sure that what was printed was correct, that it hadn’t been inadvertently changed by human intervention. (Sounds like modern continuous deployment …)
  • It’s worth noting that Sed, Awk, Make, Yacc and Lex all implement some flavor of the pattern-action paradigm. Programs in these languages consist of a sequence of patterns and actions; the basic operation is to check the input against each pattern and when a pattern is matched, perform the corresponding action. … The pattern-action paradigm is a natural way to think about computations that are primarily a sequence of tests and actions.
  • One comment in the Unix source: /* You are not expected to understand this */
  • part of the genius of Ken Thompson and Dennis Ritchie was their tasteful selection of existing good ideas, and their ability to see a general concept or a unifying theme that simplified software systems. People sometimes talk of software productivity in terms of the number of lines of code written; in the Unix world, productivity was often measured by the number of special cases or lines of code that were removed.
  • Pipes do not solve all connection problems, or course, but the fully general non-linear connections of Doug McIlroy’s original concept do not show up often in practice; linear pipelines are almost always good enough.
  • The Unix philosophy certainly doesn’t solve all the problems of programming, but it does provide a useful guide for approaching system design and implementation.
  • As Dick Hamming said, if you don’t work on important problems, it’s unlikely that you’ll do important work.
  • Technical management. Managers have to understand the work they manage. Management in Bell Labs research was technical all the way to the top, so they had a solid understanding of the work both within their own organization and across others. Department heads were expected to know what their people were doing in real detail, not for the purpose of arguing how great it was, but for being able to explain it to others and helping to make connections. At least in 1127 there were no turf wars; it was a cooperative and non-competitive environment where management supported their people, often collaborated, and never competed. I’m not sure that this was a universal experience, but it’s worth aiming for, and doing it well should be part of the reward mechanism for managers.
  • Although Bell Labs management was technically knowledgeable at all levels, AT&T’s upper management seemed removed from new technology and slow to adapt to change. For instance, in the early 1990s, Sandy Fraser, at that time the director of 1127, told AT&T executives that networking improvements would mean that long distance prices would come down from their then-current ten cents per minutes to one cent a minutes, and he was laughed at. Today’s price is pretty close to zero cents per minutes; Sandy was too conservative.
  • Bell Labs management was technically competent, and especially so in 1127, so it could access good work, and it was hands-off, so it didn’t push particular projects or approaches. In over 30 years at the Labs I was never told what to work on. Bruce Hannay, vice president of Research after Bill Baker, said in 1981 in Engineering and Science in the Bell System, “Freedom of choice is of utmost importance to the research scientist, because research is an exploration of the unknown and there are not road maps to tell what course to take. …”
  • The big secret to doing good research is to hire good people, make sure there are interesting things for them to work on, take a long view, and then get out of the way. It certainly wasn’t perfect, but Bell Labs research generally did this well.
  • “What we wanted to preserve was not just a good environment in which to do programming, but a system around which a fellowship could form. We know from experience that the essence of communal computer […] is not just to type programs into a terminal instead of a keypunch, but to encourage close communication.” – Denis Richie, “The Evolution of the Unix Time-sharing System.”
